Topic "open multiple connections at once"
larsen
it would be nice if I could select multiple stored sessions at once by using ctrl and or shift (as selecting files in windows explorer). When I then press login, WinSCP should open a window that holds all sessions (or perhaps optionally open a separate window for each one of it).
That way, I could easily open connections to all my servers when something needs to be done on all of them.
Cheers
Lars
OK, added to TODO list, with low priority, unless more people asks for that.
larsen
thx =)
Nacho
Please add me to the list of suplicants in this one Smile
Nacho
Unix User
Can I connect to 2 servers at same time (UAT and PROD) and have one on left side and other on right side so I can compare/transfer files between them.
No.
rookie
Is there a tool that can do this: that is recommended?
server<=>server OR server<=> local
or is there a plug in to add
larsen
As this is almost three years old and I just wanted to post that request again please add me a second time to the list ;-)
glauber
prikryl wrote:
No.
You can transfer files between servers (using temporary storage in your workstation). It may not be very obvious, but it works. Connect to both servers, then highlight the file you want to copy, and use "Duplicate" in the File menu, to send it to the other server.
g
Also please read FAQ.
Superole
I see that this thread is quite old, but I need exactly what the original post asks for.
So if this feature is still on a low-pri todo list, please add me to the list of requesters.
Very Happy
Thanks for your post. This request is being tracked here:
http://winscp.net/tracker/show_bug.cgi?id=424
shq
taky bych ocenil tuhle featurku
ComeHereByGoogle
It would be very nice to have that feature Smile
grikag
Is there a simpler way to open multiple sessions?
STGdb
Something like FastSCP would be nice (transfer between hosts and not store temporary data on my local system). Could be a security issue...
coolhandluke
This would be a very nice feature i can't believe it's not already there.
What feature exactly?
