Topic "Variant array index out of bounds"
Yvan
As I run the sftp client, an error message appears: 'Error listing directory "/home/myname" ', with description 'Variant array index out of bounds'.
This does not seem to create problems at this stage, and the apparently correct remote directory listing appears. However, when I try to transfer a file (from a remote unix server to a local Windows XP) , it says that it 'cannot open remote file', with the same description as before (Variant array index out of bounds). The same happen if I try to copy from local to remote (cannot create remote file, same description).
Please, post a log file.
Yvan
. WinSCP Version 3.1.0 (Build 165)
. Login time: lundi 4 aot 2003 13:34:55
. Session name: mimosa
. Host name: mimosa.univ-mrs.fr (Port: 22)
. User name: velenik (Password: No, Key file: No)
. Transfer Protocol: SFTP
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: C:\Documents and Settings\Yvan\Mes documents, Remote directory: /home/velenik/, Update: No, Cache: Yes
. Looking up host "mimosa.univ-mrs.fr"
. Connecting to 193.50.130.3 port 22
. Server version: SSH-1.99-OpenSSH_3.5p1
. We claim version: SSH-2.0-PuTTY-Local: Jul 14 2003 13:14:02
. Host key fingerprint is:
. ssh-rsa 1024 63:d8:0a:d3:a9:a3:32:23:47:20:4c:da:0f:80:8a:fc
! Using username "velenik".
. Keyboard-interactive authentication refused
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. Changing directory to "/home/velenik/".
> Type: SSH_FXP_REALPATH, Size: 23, Number: 16
< Type: SSH_FXP_NAME, Size: 47, Number: 16
> Type: SSH_FXP_OPENDIR, Size: 22, Number: 267
< Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> Type: SSH_FXP_CLOSE, Size: 13, Number: 516
< Type: SSH_FXP_STATUS, Size: 24, Number: 516
. Listing directory "/home/velenik".
> Type: SSH_FXP_OPENDIR, Size: 22, Number: 779
< Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< Type: SSH_FXP_NAME, Size: 11329, Number: 1036
> Type: SSH_FXP_READDIR, Size: 13, Number: 1292
. Reading symlink "Mail".
> Type: SSH_FXP_READLINK, Size: 27, Number: 1555
> Type: SSH_FXP_STAT, Size: 27, Number: 1809
< Type: SSH_FXP_NAME, Size: 12021, Number: 1292
< Type: SSH_FXP_NAME, Size: 59, Number: 1555
< Type: SSH_FXP_STATUS, Size: 29, Number: 1809
. Error status: 2, Message: 1809, Server: No such file, Language: ?
* (ECommand) Error reading symlink 'Mail'.
* No such file or directory.
* Error code: 2
* Error message from server: No such file (?)
* Request code: 17
. Reading symlink ".kde".
> Type: SSH_FXP_READLINK, Size: 27, Number: 2067
> Type: SSH_FXP_STAT, Size: 27, Number: 2321
< Type: SSH_FXP_NAME, Size: 41, Number: 2067
< Type: SSH_FXP_STATUS, Size: 29, Number: 2321
. Error status: 2, Message: 2321, Server: No such file, Language: ?
* (ECommand) Error reading symlink '.kde'.
* Error code: 2
* Request code: 17
. Reading symlink "nsmail".
> Type: SSH_FXP_READLINK, Size: 29, Number: 2579
> Type: SSH_FXP_STAT, Size: 29, Number: 2833
< Type: SSH_FXP_NAME, Size: 29, Number: 2579
< Type: SSH_FXP_STATUS, Size: 29, Number: 2833
. Error status: 2, Message: 2833, Server: No such file, Language: ?
* (ECommand) Error reading symlink 'nsmail'.
* Error code: 2
* Request code: 17
. Reading symlink "Desktop_old".
> Type: SSH_FXP_READLINK, Size: 34, Number: 3091
> Type: SSH_FXP_STAT, Size: 34, Number: 3345
< Type: SSH_FXP_NAME, Size: 49, Number: 3091
< Type: SSH_FXP_STATUS, Size: 29, Number: 3345
. Error status: 2, Message: 3345, Server: No such file, Language: ?
* (ECommand) Error reading symlink 'Desktop_old'.
* Error code: 2
* Request code: 17
. Reading symlink ".oldDCOPserver_latpcmi22.cmi.univ-mrs.fr".
> Type: SSH_FXP_READLINK, Size: 63, Number: 3603
> Type: SSH_FXP_STAT, Size: 63, Number: 3857
< Type: SSH_FXP_NAME, Size: 129, Number: 3603
< Type: SSH_FXP_STATUS, Size: 29, Number: 3857
. Error status: 2, Message: 3857, Server: No such file, Language: ?
* (ECommand) Error reading symlink '.oldDCOPserver_latpcmi22.cmi.univ-mrs.fr'.
* Error code: 2
* Request code: 17
. Reading symlink "local".
> Type: SSH_FXP_READLINK, Size: 28, Number: 4115
> Type: SSH_FXP_STAT, Size: 28, Number: 4369
< Type: SSH_FXP_NAME, Size: 51, Number: 4115
< Type: SSH_FXP_STATUS, Size: 29, Number: 4369
. Error status: 2, Message: 4369, Server: No such file, Language: ?
* (ECommand) Error reading symlink 'local'.
* Error code: 2
* Request code: 17
. Reading symlink ".mozilla".
> Type: SSH_FXP_READLINK, Size: 31, Number: 4627
> Type: SSH_FXP_STAT, Size: 31, Number: 4881
< Type: SSH_FXP_NAME, Size: 51, Number: 4627
< Type: SSH_FXP_STATUS, Size: 29, Number: 4881
. Error status: 2, Message: 4881, Server: No such file, Language: ?
* (ECommand) Error reading symlink '.mozilla'.
* Error code: 2
* Request code: 17
> Type: SSH_FXP_READDIR, Size: 13, Number: 5132
. Reading symlink "wwwlog".
> Type: SSH_FXP_READLINK, Size: 29, Number: 5395
> Type: SSH_FXP_STAT, Size: 29, Number: 5649
* (ECommand) Error reading symlink 'wwwlog'.
* Variant array index out of bounds
. Reading symlink ".openoffice".
> Type: SSH_FXP_READLINK, Size: 34, Number: 5907
* (ECommand) Error reading symlink '.openoffice'.
. Reading symlink ".netscape".
> Type: SSH_FXP_READLINK, Size: 32, Number: 6163
* (ECommand) Error reading symlink '.netscape'.
. Reading symlink ".oldDCOPserver_eupalidos.cmi.univ-mrs.fr".
> Type: SSH_FXP_READLINK, Size: 63, Number: 6419
* (ECommand) Error reading symlink '.oldDCOPserver_eupalidos.cmi.univ-mrs.fr'.
. Reading symlink "sem_probastat".
> Type: SSH_FXP_READLINK, Size: 36, Number: 6675
* (ECommand) Error reading symlink 'sem_probastat'.
. Reading symlink ".gimp-1.2".
> Type: SSH_FXP_READLINK, Size: 32, Number: 6931
* (ECommand) Error reading symlink '.gimp-1.2'.
< Type: SSH_FXP_NAME, Size: 5903, Number: 5132
> Type: SSH_FXP_CLOSE, Size: 13, Number: 7172
< Type: SSH_FXP_NAME, Size: 127, Number: 5395
< Type: SSH_FXP_STATUS, Size: 29, Number: 5649
* (ECommand) Error listing directory "/home/velenik".
. Startup conversation with host finished.
. Changing directory to "tex".
> Type: SSH_FXP_REALPATH, Size: 26, Number: 7440
< Type: SSH_FXP_NAME, Size: 57, Number: 5907
* (ECommand) Error changing directory to "tex".
* Cannot get real path for '/home/velenik/tex'.
. File: "/home/velenik/fichier.txt"
. Copying "/home/velenik/fichier.txt" to local directory started.
. Ascii transfer mode selected.
. Opening remote file.
> Type: SSH_FXP_OPEN, Size: 42, Number: 7683
< Type: SSH_FXP_NAME, Size: 51, Number: 6163
* (EVariantBadIndexError) Variant array index out of bounds
. Asking user:
. Cannot open remote file '/home/velenik/fichier.txt'. ("Variant array index out of bounds")
* (EScpSkipFile) Cannot open remote file '/home/velenik/fichier.txt'.
* (EAbort) Operation aborted
. Closing connection.
Thanks for the log. I have no clue yet. I'll be back shortly.
Anyone else having the problem?
