Topic "local shell execution from /script"
mjraley
I am looking at integrating winscp into existing batch jobs.
In windows default FTP client and the moveit freely FTPS client the ftp macro interprets ! to mean start a command shell and run some local command such as "!myprogram.exe" inside the session.
Argueably I can do these before and after the session, but
The GUI mode allows custom commands to execute locally or remotely
but it's not apparent how to or if I can start a local command shell from script. Confused
This is not supported yet.
Austin
tracker.
First post, while I am at it, what a great program.
hmmm, its great that you can schedule in windows. The problem I am facing is I am transferring files using WINSCP (batch) by windows scheduler followed by another task which runs my "program.exe" the only thing is I don't know of an option that ensures scheduled tasks are complete or I need to find a way to make sure WINSCP has finished the transfer of the desired file's before "program.exe" is executed. Question
If anyone has suggestions on a better free task scheduler, or another solution I am all ears.
Thanks Austin
You can put both your tasks to single .bat file and schedule that.
