Topic "FTP over explicit TLS/SSL ?"
guest
Do you have any plans to add this protocol to the program. I would really like to use the sync feature, but I need it to work with my server.
It is on TODO list already. But I cannot tell when it will be implemented.
Thank you for considering this feature! I hope it will be soon!
BijuGC
@Topic FTPS
prikryl wrote:
~Biju wrote:
http://en.wikipedia.org/wiki/Comparison_of_FTP_clients
say FileZilla have FTPS (FTP over SSL) and secure-FTP (FTP over SSH)
So why cant we borrow it, just like we did for FTP
Sure, we can. It just means to integrate OpenSSL into WinSCP. Which means bloat of binary size Sad
Why not consider a plugin style architecture for WinSCP, with a strip down stand alone exe file. And the install version should come with other protocol like FTP, FTPS, WebDAV.
I have thought about it too. But I like the fact WinSCP is just a single file that works as is.
Can you please give us an update on this feature?
Sorry, nothing new.
LonelyPixel
I just upgraded from 3.8 to 4.0.7 as I found out that it supports FTP, too, now. This is great because the FTP client I used before always nagged me with a "License reminder" and expired from time to time forcing me to an upgrade. Wink Sadly WinSCP doesn't support FTP/SSL yet which keeps me from recommending it to my clients as FTP client. I already do recommend it as SFTP client though.
You say OpenSSL would bloat the binary. By how much? My 3.8 binary is 1.2 MB, the 4.0.7 binary is 4.8 MB. PHP's OpenSSL DLLs are 1.4 MB. I don't think that would hurt too much considering the current size increase already.
EXE size of 3.8 was 4.0 MB. You refer to compressed standalone binary, which is 1.25 MB in 4.1.
lonelypixel
Ah, okay, I just looked at what I found on my disk. Right, I had a single binary before and now used the multi-language installer.
Just checking. Do you have an estimated timeframe as to when this feature will be implemented?
Not yet.
Sarma M.N
I am trying send a file through SFTP to a destination. But they say that I will be able to send out file only if my software has Implicity SSL/SSO Connection enabled.
I am using WinSCP and please help me how can I send out the file. Your prompt response would be greatly appreciated.
Thanks in advance.
WinSCP does not support SSL at all.
Just checking again. Do you have an estimated timeframe as to when this feature will be implemented?
No. But I have raised its priority.
Thank you!
Nina
Hello Martin,
thanks for your great work!
I would really like to see this feature in WinSCP!
I have to use FileZilla for some of my projects, but I don't like it half as much as your program.
PS: I would also appreciate a Linux version. Wink
what do you suggest best ftps client since winscp doesn't even support ftps becuase size will inceased?
Better a client with more protocol supports that some MO more size.
I was just wondering if you made any progress on implementing FTP over SSL (explicit) in WinSCP?
I really like your tool, but this is required in my environment so it would be great to have.
Not yet.
Schnulla
I also really need this feature because the
only secure transfer on Hosteurope Webpacks
is via "FTP over explicit TLS" Sad
It is implemented already.
Schnulla
wooooohaaaaaaaaa man you are the best!!! Very Happy
BIG THANKS!! Very Happy
Schnulla
Is there already a binary snapshot available to download? Smile
Thx!
Not yet.
Do you have an estimated time as to when the new version with this feature will be released?
Thank you for implementing the feature!!!!!!!!!!!!!!!!!
Not yet. Month, two or three... Smile
cruisen
Thank you. I am also waiting to use winscp for ftp over TLS!
R00st3r
I am following this thread and need FTP over Implicit SSL as well. It's been almost a year now that users have been asking for this feature. Do you have an ETA on when this might be released?
One or two months I hope. But I cannot promise that.
spig
Any news on this yet? It's been a long time, and there's plenty of people looking for FTPS support. Even a beta would be useful!
Beta will be out within a month.
Christian W.
Now this feature request is older than 1 year and the community is waiting for it.
I just want to say, here are more people waiting for that than the preveous speaker.
You have my support!
chemmix
I'm waiting too
Schnulla
First I want to say thanks for
implementing this in v.4.2.1! Very Happy
It works fine here!
Question: Does FTP over explicit SSL
in WinSCP only encrypt the login and
password data or is also the file
transfer secured? Thanks Smile
(I ask this because in SmartFTP it is
possible to secure the file transfer
and the login process separately).
Both. I have updated documentation to cover that.
Schnulla
Good to know, thanks!
Vincenzo
I've just a simple question, because I didn't reach to find this information on the WinSCP website.
Is there a way to use scripts with this new functionnality on the protocol FTP with SSL/TLS ?
If yes what's the correct parameter to use / specify ?
Thanks for you job,
Best regards
Vincenzo
Not yet. This request is being tracked already.
Yet this FAQ will show you workaround.
Ben White
I am trying to use FTP with TLS Explicit encryption to a proftpd server.
I am getting the following error from WinSCP
Retrieving directory listing...
TYPE A
200 Type set to A
PORT 192,168,1,7,16,69
200 PORT command successful
LIST
150 Opening ASCII mode data connection for file list
SSL connection established
425 Unable to build data connection: Operation not permitted
Here is the error log from the proftpd server
May 01 18:45:20 mod_tls/2.3[2419]: starting TLS negotiation on data connection
May 01 18:45:21 mod_tls/2.3[2419]: did NOT reuse SSL session for data connection
May 01 18:45:21 mod_tls/2.3[2419]: Client did not reuse SSL session, rejecting data connection (see TLSOption NoSessionReuseRequired)
May 01 18:45:22 mod_tls/2.3[2419]: unable to open data connection: TLS negotiation failed
Is there a setting that forces WinSCP to reuse the same SSL session?
Any ideas how I can fix this?
I really don't want to use FileZilla
WinSCP cannot reuse the SSL session. You may remove the requirement on the server-side as workaround.
ken_f_ca
When will 4.2 move from Beta to Production? We're not allowed to inplement Beta code in our enviroment.
Thank-you for all your efforts adding this feature.
Ken
implementing this in v.4.2.1! :D
It works fine here!
transfer secured? Thanks :)
Sorry, I'm not going to promise any dates.
Shashank
HOw to figure out me whether Winscp supports TLS1.1 or TLS1.0 ??
TLS 1.0 only atm.
Does WinScp support "FTP over explicit TLS/SSL" FTP protocol. I am using version 4.2.9(build 938)
If yes, how can I use it.
I was looking at the FTP dropdown and it has the following 4:-
1.No Encryption
2.SSL/TLS Implicit encryption
3.SSL explicit encryption
4.TLS explicit encryption
Thanks[/list]
You have to know if you need to use TLS or SSL. If you do not know, try TLS first.
Gues
Hello
Thanks for the response.
I have tried all the 3 options and it doesn't work.
Are you able to connect with any other FTP client? Do you have anyone to ask, what kind of connection you are supposed to use with that server?
Yes, I can connect with Filezilla and Core FTP LE. Filezilla has the "FTP over explicit TLS/SSL" FTP Protocol.
In Core FTP LE, the setting is:
Connection Type: Auth SSL
SSL Options:- Checked SSL Listing, SSL Transfer, Open SSL
Checked PASV
So can you post a log file from both Filezilla and WinSCP?
burger
I'm a different person than the OP trying to get FTPES FTP over explicit TLS/SLL working, but here are my logs.
I tried WinSCP with both Explicit TLS and Explicit SSL, no luck.. here are the logs
I really wanted to use WinSCP to automate.. but it looks like it won't work.
Hopefully this will help you add this feature..
******** Explicit SSL
. 2011-02-17 10:10:44.570 --------------------------------------------------------------------------
. 2011-02-17 10:10:44.570 WinSCP Version 4.3.1 (Build 1099) (OS 6.1.7600)
. 2011-02-17 10:10:44.570 Login time: Thursday, February 17, 2011 10:10:44 AM
. 2011-02-17 10:10:44.570 Session name: me@somewhere.net_ssl_ex
. 2011-02-17 10:10:44.570 Host name: ftp.myhost.net (Port: 21)
. 2011-02-17 10:10:44.571 User name: myusername(Password: Yes, Key file: No)
. 2011-02-17 10:10:44.571 Tunnel: No
. 2011-02-17 10:10:44.571 Transfer Protocol: FTP
. 2011-02-17 10:10:44.571 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2011-02-17 10:10:44.571 Proxy: none
. 2011-02-17 10:10:44.571 FTP: FTPS: Explicit SSL; Passive: Yes [Force IP: No]
. 2011-02-17 10:10:44.571 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-02-17 10:10:44.571 Cache directory changes: Yes, Permanent: Yes
. 2011-02-17 10:10:44.571 DST mode: 1
. 2011-02-17 10:10:44.571 --------------------------------------------------------------------------
. 2011-02-17 10:10:44.609 Connecting to ftp.myhost.net ...
. 2011-02-17 10:10:44.609 m_pSslLayer changed state from 0 to 1
. 2011-02-17 10:10:44.609 m_pSslLayer changed state from 1 to 2
. 2011-02-17 10:10:44.626 m_pSslLayer changed state from 2 to 4
. 2011-02-17 10:10:44.628 Connected with ftp.myhost.net, negotiating SSL connection...
< 2011-02-17 10:10:44.662 220 Microsoft FTP Service
> 2011-02-17 10:10:44.662 AUTH SSL
< 2011-02-17 10:10:44.696 234 AUTH command ok. Expecting TLS Negotiation.
. 2011-02-17 10:10:44.928 SSL_connect: error in SSLv3 read server hello B
. 2011-02-17 10:10:44.928 Can't establish SSL connection
. 2011-02-17 10:10:44.928 Disconnected from server
. 2011-02-17 10:10:44.929 Connection failed.
. 2011-02-17 10:10:44.929 Got reply 1004 to the command 1
* 2011-02-17 10:10:44.936 (ESshFatal) Connection failed.
* 2011-02-17 10:10:44.937 SSL_connect: error in SSLv3 read server hello B
* 2011-02-17 10:10:44.937 Can't establish SSL connection
* 2011-02-17 10:10:44.937 Disconnected from server
* 2011-02-17 10:10:44.937 Connection failed.
* 2011-02-17 10:10:44.937 AUTH command ok. Expecting TLS Negotiation.
******** Explicit TLS
. 2011-02-17 10:10:54.065 --------------------------------------------------------------------------
. 2011-02-17 10:10:54.066 WinSCP Version 4.3.1 (Build 1099) (OS 6.1.7600)
. 2011-02-17 10:10:54.066 Login time: Thursday, February 17, 2011 10:10:54 AM
. 2011-02-17 10:10:54.066 --------------------------------------------------------------------------
. 2011-02-17 10:10:54.066 Session name: me@ftp.myhost.net_tls_exp
. 2011-02-17 10:10:54.066 Host name: ftp.myhost.net (Port: 21)
. 2011-02-17 10:10:54.066 User name: myusername(Password: Yes, Key file: No)
. 2011-02-17 10:10:54.066 Tunnel: No
. 2011-02-17 10:10:54.066 Transfer Protocol: FTP
. 2011-02-17 10:10:54.066 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2011-02-17 10:10:54.066 Proxy: none
. 2011-02-17 10:10:54.066 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: No]
. 2011-02-17 10:10:54.066 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-02-17 10:10:54.066 Cache directory changes: Yes, Permanent: Yes
. 2011-02-17 10:10:54.066 DST mode: 1
. 2011-02-17 10:10:54.091 Connecting to ftp.myhost.net ...
. 2011-02-17 10:10:54.091 m_pSslLayer changed state from 0 to 1
. 2011-02-17 10:10:54.091 m_pSslLayer changed state from 1 to 2
. 2011-02-17 10:10:54.103 m_pSslLayer changed state from 2 to 4
. 2011-02-17 10:10:54.105 Connected with ftp.myhost.net, negotiating SSL connection...
< 2011-02-17 10:10:54.137 220 Microsoft FTP Service
> 2011-02-17 10:10:54.137 AUTH TLS
< 2011-02-17 10:10:54.172 234 AUTH command ok. Expecting TLS Negotiation.
. 2011-02-17 10:10:54.210 SSL_connect: error in SSLv3 read server hello B
. 2011-02-17 10:10:54.210 Can't establish SSL connection
. 2011-02-17 10:10:54.210 Disconnected from server
. 2011-02-17 10:10:54.210 Connection failed.
. 2011-02-17 10:10:54.210 Got reply 1004 to the command 1
* 2011-02-17 10:10:54.218 (ESshFatal) Connection failed.
* 2011-02-17 10:10:54.218 SSL_connect: error in SSLv3 read server hello B
* 2011-02-17 10:10:54.218 Can't establish SSL connection
* 2011-02-17 10:10:54.218 Disconnected from server
* 2011-02-17 10:10:54.218 Connection failed.
* 2011-02-17 10:10:54.218 AUTH command ok. Expecting TLS Negotiation.
********** Filezilla
Status: Resolving address of ftp.myhost.net
Status: Connecting to x.x.x.x:21...
Status: Connection established, waiting for welcome message...
Trace: CFtpControlSocket::OnReceive()
Response: 220 Microsoft FTP Service
Trace: CFtpControlSocket::SendNextCommand()
Command: AUTH TLS
Response: 234 AUTH command ok. Expecting TLS Negotiation.
Status: Initializing TLS...
Trace: CTlsSocket::Handshake()
Trace: CTlsSocket::ContinueHandshake()
Trace: CTlsSocket::OnSend()
Trace: CTlsSocket::OnRead()
Trace: Handshake successful
Trace: Cipher: AES-128-CBC, MAC: SHA1
Status: Verifying certificate...
Command: USER myusername
Status: TLS/SSL connection established.
Response: 331 Password required for myusername.
Command: PASS *********
Response: 230 User logged in.
Command: SYST
Response: 215 Windows_NT
Command: FEAT
Response: 211-Extended features supported:
Response: LANG EN*
Response: UTF8
Response: AUTH TLS;TLS-C;SSL;TLS-P;
Response: PBSZ
Response: PROT C;P;
Response: CCC
Response: HOST
Response: SIZE
Response: MDTM
Response: 211 END
Command: OPTS UTF8 ON
Response: 200 OPTS UTF8 command successful - UTF8 encoding now ON.
Command: PBSZ 0
Response: 200 PBSZ command successful.
Command: PROT P
Response: 200 PROT command successful.
Status: Connected
Trace: CFtpControlSocket::ResetOperation(0)
Trace: CControlSocket::ResetOperation(0)
Trace: CFileZillaEnginePrivate::ResetOperation(0)
Status: Retrieving directory listing...
Trace: CFtpControlSocket::ChangeDirSend()
Command: PWD
Response: 257 "/" is current directory.
Trace: CFtpControlSocket::ParseSubcommandResult(0)
Trace: CFtpControlSocket::ListSubcommandResult()
Trace: state = 1
Trace: CFtpControlSocket::TransferSend()
Trace: state = 1
Command: TYPE I
Response: 200 Type set to I.
Trace: CFtpControlSocket::TransferParseResponse()
Trace: code = 2
Trace: state = 1
Trace: state = 2
Command: PASV
Response: 227 Entering Passive Mode (216,154,194,28,21,27).
Trace: code = 2
Trace: state = 2
Trace: state = 4
Command: LIST
Trace: CTransferSocket::OnConnect
Response: 150 Opening BINARY mode data connection.
Trace: code = 1
Trace: state = 4
Trace: state = 5
Trace: Session resumed
Trace: CTransferSocket::OnReceive(), m_transferMode=0
Trace: CTransferSocket::TransferEnd(1)
Trace: CFtpControlSocket::TransferEnd()
Response: 226 Transfer complete.
Trace: code = 2
Trace: state = 7
Trace: state = 3
Trace: CFtpControlSocket::ListSend()
Trace: state = 4
Status: Calculating timezone offset of server...
Command: MDTM Test.txt
Response: 213 20110214163927
Trace: CFtpControlSocket::ListParseResponse()
Status: Timezone offsets: Server: -18000 seconds. Local: -21600 seconds. Difference: -3600 seconds.
Status: Directory listing successful
***** Core FTP Pro
WinSock 2.0
Mem -- 4,194,303 KB, Virt -- 2,097,024 KB
Started on Thursday February 17, 2011 at 10:17:AM
Resolving ftp.myhost.net...
Connect socket #948 to 216.154.194.28, port 21...
AUTH SSL
TLSv1, cipher TLSv1/SSLv3 (AES128-SHA) - 128 bit
USER myusername
PASS **********
230 User logged in.
SYST
215 Windows_NT
Keep alive off...
PWD
PBSZ 0
PROT P
PASV
227 Entering Passive Mode (216,154,194,28,21,47).
LIST
Connect socket #1008 to 216.154.194.28, port 5423...
150 Opening ASCII mode data connection.
Transferred 49 bytes in 0.011 seconds
**** good luck..
Thanks for your post. This issue is being tracked already.
LALILU
Hi
I have the same Problem with the Version 4.3.2 (Build 1201).
Here are the LogFiles from WinSCP and FileZilla:
WinSCP:
WinSCP Version 4.3.2 (Build 1201) (OS 5.1.2600 Service Pack 2)
Login time: Mittwoch, 16. Mrz 2011 12:54:50
Session name: ************************
Host name: ************** (Port: 21)
User name: *************** (Password: Yes, Key file: No)
Tunnel: No
Proxy: none
FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: Yes]
DST mode: 1
Verbinde mit *************** ...
Verbunden mit *****************, Etabliere SSL Verbindung...
220 FTP Server ready.
AUTH TLS
234 AUTH TLS successful
SSL Verbindung hergestellt. Erwarte die Willkommensnachricht...
USER *************
331 Password required for **************
PASS *************
230 User ************* logged in
SYST
215 UNIX Type: L8
FEAT
211-Features:
 LANG en-US.UTF-8;en-US*
 MDTM
 MFMT
 TVFS
 AUTH TLS
 UTF8
 MFF modify;UNIX.group;UNIX.mode;
 MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
 PBSZ
 PROT
 REST STREAM
 SIZE
211 End
OPTS UTF8 ON
200 UTF8 set to on
PBSZ 0
200 PBSZ 0 successful
PROT P
200 Protection set to Private
Verbunden
Using FTP protocol.
Doing startup conversation with host.
PWD
257 "/htdocs" is the current directory
Getting current directory name.
Rufe Verzeichnisinhalt ab...
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (************).
LIST -a
Konnte Verzeichnisinhalt nicht abrufen
TYPE A
200 Type set to A
PASV
LIST
(ECommand) Fehler beim Anzeigen des Verzeichnisses "/htdocs".
Startup conversation with host finished.
FileZilla:
Status:   Resolving address of ***************
Status:   Connecting to ************...
Status:   Verbindung hergestellt, warte auf Willkommensnachricht...
Antwort:   220 FTP Server ready.
Befehl:   AUTH TLS
Antwort:   234 AUTH TLS successful
Status:   Starte TLS...
Status:   berprfe Zertifikat...
Befehl:   USER **************
Status:   TLS/SSL Verbindung hergestellt-
Antwort:   331 Password required for ************
Befehl:   PASS *************
Antwort:   230 User *********** logged in
Befehl:   SYST
Antwort:   215 UNIX Type: L8
Befehl:   FEAT
Antwort:   211-Features:
Antwort:    LANG en-US.UTF-8;en-US*
Antwort:    MDTM
Antwort:    MFMT
Antwort:    TVFS
Antwort:    AUTH TLS
Antwort:    UTF8
Antwort:    MFF modify;UNIX.group;UNIX.mode;
Antwort:    MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
Antwort:    PBSZ
Antwort:    PROT
Antwort:    REST STREAM
Antwort:    SIZE
Antwort:   211 End
Befehl:   OPTS UTF8 ON
Antwort:   200 UTF8 set to on
Befehl:   PBSZ 0
Antwort:   200 PBSZ 0 successful
Befehl:   PROT P
Antwort:   200 Protection set to Private
Status:   Verbunden
Status:   Empfange Dateilisten...
Befehl:   PWD
Antwort:   257 "/htdocs" is the current directory
Befehl:   TYPE I
Antwort:   200 Type set to I
Befehl:   PASV
Antwort:   227 Entering Passive Mode (*************).
Befehl:   MLSD
Antwort:   150 Opening ASCII mode data connection for MLSD
Antwort:   226 Transfer complete
Status:   Dateiauflistung abgeschlossen
Fehler:   Connection closed by server
Is this a new Bug?
I would need complete log files (without obfuscating the IP addresses at least). You can email them to me, if you do not want to post them publicly.
LALILU_
Allright. Here the complete Logs.
WinSCP:
Login time: Montag, 21. M�rz 2011 15:08:07
Session name: HostServer/...
Host name: ... (Port: 21)
User name: ... (Password: Yes, Key file: No)
Tunnel: No
Proxy: none
DST mode: 1
Verbinde mit ... ...
Verbunden mit ..., Etabliere SSL Verbindung...
AUTH TLS
USER myusername
331 Password required for ...
PASS *************
230 User myusername logged in
SYST
215 UNIX Type: L8
FEAT
211-Features:
 MDTM
 MFMT
 TVFS
 AUTH TLS
 UTF8
 PBSZ
 PROT
 REST STREAM
 SIZE
211 End
OPTS UTF8 ON
200 UTF8 set to on
PBSZ 0
PROT P
Verbunden
Using FTP protocol.
PWD
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (...).
LIST -a
TYPE A
200 Type set to A
PASV
LIST
FileZilla:
Status:   Resolving address of ...
Status:   Connecting to ...
Befehl:   AUTH TLS
Status:   �berpr�fe Zertifikat...
Befehl:   USER myusername
Antwort:   331 Password required for ...
Antwort:   230 User myusername logged in
Befehl:   SYST
Befehl:   FEAT
Antwort:    MDTM
Antwort:    MFMT
Antwort:    TVFS
Antwort:    AUTH TLS
Antwort:    UTF8
Antwort:    PBSZ
Antwort:    PROT
Antwort:    SIZE
Antwort:   211 End
Befehl:   PBSZ 0
Befehl:   PROT P
Status:   Verbunden
Befehl:   PWD
Befehl:   TYPE I
Befehl:   PASV
Antwort:   227 Entering Passive Mode (...).
Befehl:   MLSD
Damn. Sorry. Here the correct one.
WinSCP:
Login time: Montag, 21. M�rz 2011 15:14:25
Tunnel: No
Proxy: none
DST mode: 1
Verbinde mit ...
AUTH TLS
USER ...
PASS *************
230 User  ... logged in
SYST
215 UNIX Type: L8
FEAT
211-Features:
 MDTM
 MFMT
 TVFS
 AUTH TLS
 UTF8
 PBSZ
 PROT
 REST STREAM
 SIZE
211 End
OPTS UTF8 ON
200 UTF8 set to on
PBSZ 0
PROT P
Verbunden
Using FTP protocol.
PWD
TYPE A
200 Type set to A
PASV
LIST -a
TYPE A
200 Type set to A
PASV
LIST
FileZilla:
Status:   Connecting to ......
Befehl:   AUTH TLS
Befehl:   USER ...
Antwort:   230 User ... logged in
Befehl:   SYST
Befehl:   FEAT
Antwort:    MDTM
Antwort:    MFMT
Antwort:    TVFS
Antwort:    AUTH TLS
Antwort:    UTF8
Antwort:    PBSZ
Antwort:    PROT
Antwort:    SIZE
Antwort:   211 End
Befehl:   PBSZ 0
Befehl:   PROT P
Status:   Verbunden
Befehl:   PWD
Befehl:   TYPE I
Befehl:   PASV
Befehl:   MLSD
Thanks. I do not see anything wrong in the log files. May I have a test account on your server?
LALILU
Hi Martin,
i sent an email with the testaccount in a pgp encrypted file.
Armin
LALILU wrote:
Hi Martin,
Armin
Hi Martin,
have you found any solutions with my FTP-Server?
Regards
Armin
LALILU
Anonymous wrote:
LALILU wrote:
Hi Martin,
Armin
Hi Martin,
Regards
Armin
Hi Martin,
thanks for your effort. Ill found it on your tracker. Im using your WinSCP a few years and this is the first problem i have with it. Really nice work! Ill do a donation for you soon.
Regards
Armin
war59312
Hey,
Any chance on supporting http://scarybeastsecurity.blogspot.com/2009/02/vsftpd-210-released.html now?
I know you mentioned above to turn it off server side.
I have and it works as mentioned.
But was hoping it could finally be supported now?
Will
war59312 wrote:
I didn't have a luck resolving this yet. Will give it another try soon.
war59312
Nice, thanks for looking into it.
And thanks for unbanning my account. Odd how it bans you if use a bad keyword in your post. Too strong of a spam filter it seems.
amraam
I just wanted to mention that I would need this feature as well. This is the only thing that forces me to use FileZilla (whose interface I don't like) parallely to WinSCP.
So while Chris Evans thinks not many people need FTP over SSL I need it because my webhoster offers no other secure connection methods.
Numirium
Hi, pls, do you plan to add support for reusing? "Server side workaround" sounds horribly Smile.
In some situations is this workaround impossible and is feel as security flaw by my clients.
LALILU
Hi prikryl,
did you had an experience about this problem?
Greets
Armin
Auth
Hi,I have an email account with 3web.com.two days ago I joeind Bell sympatico. I can receive email on my account but I can not send emails out. I did not start a new email account with sympatico.I like to use 3web.com instead.Would you know the way to make 3web mail on Sympatico.I use Window live mail.Thank you
LALILU
Hi Martin,
i´ve still got this problem.
Here are the part from my logfile where i loose the TLS-connection:
. 2015-08-03 15:32:12.547 Data connection opened
. 2015-08-03 15:32:12.547 Trying reuse main TLS session ID
. 2015-08-03 15:32:12.547 TLS layer changed state from none to connected
. 2015-08-03 15:32:12.573 Session ID reused
. 2015-08-03 15:32:12.573 TLS layer changed state from connected to aborted
. 2015-08-03 15:32:12.573 Disconnected from server
. 2015-08-03 15:32:12.573 Data connection closed
. 2015-08-03 15:32:12.573 Could not retrieve directory listing
. 2015-08-03 15:32:12.573 Got reply 1004 to the command 2
. 2015-08-03 15:32:12.573 Ignoring old TransferEnd message
. 2015-08-03 15:32:12.573 Connection was lost, asking what to do.
. 2015-08-03 15:32:12.573 Asking user:
. 2015-08-03 15:32:12.573 Lost connection. ("Disconnected from server","Could not retrieve directory listing")
* 2015-08-03 15:32:15.408 (ESshFatal) **Lost connection.**
* 2015-08-03 15:32:15.408 Disconnected from server
* 2015-08-03 15:32:15.408 Could not retrieve directory listing
You´ve got any idea?
Regards
LALILU
Hi Martin,
now we´ve solved the problem by using the option "TLSOptions NoSessionReuseRequired" at the server-config.
Maybe you can find a workaround for this issue if someone cannot change his configuration on the server.
Regards
Thanks for this information!
