Topic "SFTP timestamp off by 5 hours"
PwrSurge
I'm trying to synchronize a directory from my WinXP machine via SFTP-2 to a Win2003 server running Foxit WAC and for some reason, the timestamp for the files uploaded to the Win2k3 server is behind by exactly 5 hours. Both servers are in the same time zone and correctly set to Eastern Standard Time (GMT -5). I tried the 3 timezone options in WinSCP and none fix the issue and Server timezone offset does not work (only works for SCP)
Help!
PwrSurge
Help!
As a followup to this issue, i would like to confirm that it's only the timestamp for files uploaded to the Win2003 server which are affected. Downloaded files are transferred correctly. Furthermore, I installed freeSSHd on a seperate port in the Win2003 server and timestamps are correctly transferred for both uploads and downloads so it looks like a compatibility issue with Foxit WAC server.
It rather looks like a bug in the Foxit WAC server Smile
Can you confirm that you have this issue on your end as well?
Serge
Serge
Also, could you please make the server offset feature work for SFTP as well?
Serge
No, I haven't tried that. I do not have Foxit WAC server.
You can download a free demo version of Foxit WAC server limited to 2 concurrent users at http://www.foxitsoftware.com/wac/server_intro.php
Regards,
Serge
I have tried the demo and I do not see the problem. For me all files have correct timestamps with WinSCP default settings.
