Topic "FAR + ConMan + WinSCP plugin in Vista x64 crash on F4"
Tomzi
Hi!
I know, I know, I might be the only person on the planet with this problem, and my guess is that it's not a WinSCP plugin issue, nevertheless I thought I should inform you.
Thing is, I use FAR 1.70 (build 2087) with WinSCP plugin 1.6 beta and ConMan 2.35. When I use it on 32-bit XP it works fine, on Vista Business x64, however, it crashes whenever I press F4 on any file. Without either conman or WinSCP this bug doesn't present itself, I just can't have them both. It seems to me that ConMan and WinSCP don't like each other under Vista x64 (dunno about x86).
Things don't look bright for me if this is a ConMan bug, as ConMan doesn't seem to be alive anymore, last version is from 2005. Even though it's old, it's a very useful plugin, I don't think I could return to plain FAR anymore.
I'm sure you've got better things to do, but any chance of you looking into the matter?
Tomzi
Forgot to mention: all other plugins were removed, WinSCP 1.5.1 plugin produces the same error, and compatibility mode settings don't solve it.
May I have your email email or alternatively, can you mail me? So I can send you a debug version eventually.
Tomzi
Mail sent.
Tomzi
Tomzi wrote:
Mail sent.
I sent an e-mail to the address I found on http://www.prikryl.cz/eng/contact.php Hope you'll get it.
Maros Rajnoch
Hello all,
I have the same issue. I use:
far 1.70 build 2087
conman 2.32
winscpfar 1.60
MS WIN Vista 64-bit
when selecting winscp pluggin, the FAR is going down. maybe there's some kind of DEP issue. Sometimes the FAR is going down while starting.
BTW: Tomzi, where did you get conman version 2.35?
Tomzi
Sorry, my mistake. I'm using ConMan 2.32 too. Thanks for pointing that out.
Tomzi wrote:
I sent an e-mail to the address I found on http://www.prikryl.cz/eng/contact.php . Hope you'll get it.
I have already replied, sorry for delay.
Tomzi
Aren't bug 158 and bug 157 the same?
Sure. Thanks Smile
jmanungu
If you are still having trouble to get your WinScp work in vista 64 bit resolution, there is a recommendable version that you can download at: http://www.oldapps.com/WinSCP.php?old_winscp=23 which have 32 and 64 bits resolution.
Joseph M.
Do not use these. Too old and too buggy.
Px
Problem become bigger under Windows 7 x64, now Far under Conman closes on launch, if WinSCP plugin is presented. After one launch Far without Conman, you can start Far under Conman, but it still crash in editor
PS: what progress on native version under Far 2.0? Smile
No progress yet Sad
Px
prikryl wrote:
No progress yet Sad
Sad
May I ask - why?
Pascal/Delphi headers available for a while, one of the plugin developers ported almost all his plugins from ansi to unicode, and even made x64 versions with Free Pascal Compiler. His sources available here - http://code.google.com/p/far-plugins/source/browse/#svn/trunk
Px wrote:
May I ask - why?
Lack of time.
