Topic "bug: removing focus on drag and drop"
hello guys,
if i copy a file from a SFTP(v3) server to a local folder by using drag and drop and change the actual folder of the windows-explorer-window (i dragged and dropped to), the files downloaded to the temporary folder are not being moved to the desired destination.
1. choose file on sftp server
2. drag and drop to folder in windows explorer
3. change folder in windows explorer while winscp is copying
4. after copy-job is finished, you can't see the file in the desired folder
is use winxp sp2 with winscp 3.8.2
greetings from germany
This cannot be fixed when using the temporary directory.
You may use WinSCP drag&drop shell extension to avoid the problem.
