Topic "Upload of text files using command line"
Me
I setup WINSCP to transfer a txt file to a sftp server. The file is transferred but the format changes. Are there any option to specify transfer mode and file system (win/unix) in command mode? I can't find any info about it.
I use the sample file for scripting and start it from SQL server on a Windows server. FTP server is using Globalscape SFTP server and I believe it is a Windows server, though I'm not sure.
I use
option batch on
open xxx:yyy@zz.zz.zz.zz
put e:\data\1.txt
close
Need to know how I can force BIn instead of ascii, which is used by default. That was the problem.
Please read documentation.
arwind
I was using scripting file to automation copy file from PC A to PC B. It's running well, but when PC A using PORT that scripting not running.
That script :
option batch on
open abcd:abcdefg@202.66.66.1:5550
cd /usr/local/
option transfer binary
lcd c:\
get *
close
please help me! Sad
arwind
Do you mean that it does not work, when you need to specify port number in script? What protocol is the server using?
