Topic "not just scp,sftp ... why not use the tool for explorer (alternative)"
FORESTHUS
Laughing Rolling Eyes Question
Sorry, but I do not understand what you mean Embarassed
FORESTHUS
well I meant if it possible to have 2 windows in your tool with 2 diff paths on the windows-pc. or even if it possible 2 get 2 connections of sftp.
that would be real cool.
Wink Laughing
You may open second instance of WinSCP. Anyway next version will enable you to open as many connections you need and select between them.
zabak
I understand what he meant: WinSCP might be a great tool to replace FAR or Total Commander if we were able to use two local sessions instead of one local and one remote - same as Far with WinSCP plug-in.
