Topic "winscp.com -> 'cd' option, dir's w/spaces prompts error msg"
ssstonebraker
Here is the command i'm using (when at command prompt)
cmd.exe /c echo put "file.xml" | winscp.com /command "open xxx@yyyy" "option transfer binary" "cd /Dir1 wSpace/SubDir"
"cd /Dir1 wSpace/SubDir" is the problem...When i use that at the command prompt i get the message: "too many parameters for cd"
I'm not sure how to modify the cd option to use a directory w/spaces.
...Any ideas? Thank you!
(Version 4.0.4 Build 346)
ssstonebraker
I've read through the entire FAQ, nothing seems to cover this... i wish the people that set up this FTP didn't uses spaces in the directory name =(.
Do you mean that you have tried all the hints, but none of them works?
ssstonebraker
I'm saying i can't find anything that covers how to deal with a directory w/spaces when using the cmd.exe and winscp.com in a single command
OK, the FAQ deals with uploading files with spaces. Just replace the "put" command with "cd" and file name with directory name...
