Topic "Continuous 'tail' command"
lhannay
I have set up 'tail --lines 50 myfilename' as a custom command and it works great. However, when I try to make it continuous, i.e. by adding the '-f' or '--follow' option it doesn't work; instead it aborts with a timeout error.
Is there any way to get the tail command to be more than a one-shot deal?
Larry
No, it is not possible.
Danny D
While trying to do the same (tail -f "!") I came across the same problem and found this thread.
What I'd like to to is to monitor log files with one click. Right now the only solution is to open a Putty session, browse to the path of the file in question and then tail -f.
I could imagine tree solutions:
1. Pipe the output of "tail -f" into the terminal window
2. Add a "follow" feature to the internal editor of WinSCP
3. Allow the user to set up an external tail program (e.g. http://www.baremetalsoft.com/baretail/index.php), just like an external editor
Would there be any chance to have one of the solutions above added to the wish list? I have no particular preference regarding the solution.
Hm, thinking about it: a "add Putty session here" in the context menu of folders would also be a nice addition (just like "Command Prompt Here" on Windows).
Danny
This is impossible for technical reasons.
This request has been added to tracker.
There's no way to tell PuTTY (or SSH terminal in general) in which directory it should start.
