Topic "Slight annoyance when saving a session with a new name"
Here's a step-by-step guide to illustrate this - easier than trying to describe it first.
- Save a session with name - doesn't matter what options you have selected.
- Now, let's say we want to save another session with almost identical settings as for a11, so at the WinSCP Login dialogue, highlight the a11 session, click Edit, then click Save. You get the Save session as dialogue. We want to call this new session So, in the name field, highlight the letter 'a' and overtype it with 'z'. Dang!, the field contents are changed to
- The easy workaround is, when the Save session as dialogue comes up, don't highlight and overtype the 'a', just move the cursor to the start of the field, type the 'z' and then remove the 'a'. (Told you it was only a slight annoyance!)
Seeing this with WinSCP 4.0.7.
Many thanks, Andy
Thanks for your post. This issue has been added to tracker.
