Topic "winscp.exe command line login timeout in /console mode batch"
Mark Martin
I am using winscp version 405. I tried using version 407 and experienced the same problem. I am running command line Dos batch files in /console mode.
I have looked through all the Directions and examples. I can not find any
refereces to increasing the login timeout to be greater than 15 seconds in batch files. Is there a way to increase the login timeout to be greater than 15 seconds in a command line console mode batch file? The files do work when they can get connected before 15 seconds expire. Sometimes the server and the network are a little slow and the batch jobs time out.
The next version will allow setting the timeout from script. Meanwhile this FAQ may help you.
