Topic "Exit %errorlevel%s vs. logged "Status/error code"s"
gotdoxies
I've been using WinSCP v3.8.2 for over a year with great satisfaction. Yestereday I upgraded t 4.0.7 to see if that would take care of the disparity described below. It didn't.
I run the GUI WinSCP from the command line within a DOS batch job under "Windows XP." I test for the exit %errorlevel% right after WinSCP finishes, and just recently I've started to get
%errorlevel%s = 1 sporadically (had been consistently = 0 for ages). When I check the log for these jobs, WinSCP reports one or more instances of "Status/error code: 0" which seems inconsistent.
I have seen other instances where the exit %errorlevel% = 0 but in the log, there will be a couple instances of "Status/error code: 0" however one instance of "Status/error code: 3" which again seems inconsistent.
I haven't found a complete listing of exit %errorlevel%s or "Status/error code"s, but such a listing would be very helpful. I need a way to test the success or failure of my batch SFTP's with certainty. Right now I am using
x:\...\winscp.exe [various switches and logged output]
if %errorlevel%==1 goto failed
find "Status/error code: 0" x:\...\sftp.log
if %errorlevel==1 goto failed
goto success
but I'm concerned that there are other values that come into play that I'm not testing for. Any clarification would be appreciated.
-Tom
WinSCP log is low-level one. It logs any single action requested. The fact that single action failed does not mean that whole operation has failed. E.g. before any upload, WinSCP would try to check for existence of partial file, so it can resume transfer. In most situations the partial file would not exists. Hence, there will be an error in the log. But the upload would probably succeed.
To summarize that, "Status/error code" message in the log has nothing to do with exit code of WinSCP. They are SFTP protocol response codes. They does not even use the same numeric range (the same codes means different events).
WinSCP exit codes are explained in documentation. In fact there are basically only two, success/error. You'll find SFTP status codes in SFTP specification, but they are mostly useless for you.
You may post a log for session that had error exit code, so we can find an operation causing the problem.
gotdoxies
Thanks for the very thorough and quick reply. Very helpful. Below is the log from a job that appears to have run correctly yet had an exit errorlevel = 1. A ~100GB file was transmitted, and the target and source matched exactly in filesize down to the bit, so I believe the transfer completed successfully despite the exit errorlevel. The log is long. I am forced to replace all identifying text with x's. The calling batch job echoes the errorlevel at the end. Thanks, Tom
SFTP Operation in Progress ...
. 2008-03-09 14:41:55.546 --------------------------------------------------------------------------
. 2008-03-09 14:41:55.546 WinSCP Version 3.8.2 (Build 330) (OS 5.2.3790 Service Pack 2)
. 2008-03-09 14:41:55.546 Login time: Sunday, March 09, 2008 2:41:55 PM
. 2008-03-09 14:41:55.546 Session name: xxxxxxxx
. 2008-03-09 14:41:55.546 Host name: xxx.xxx.xxx (Port: 22)
. 2008-03-09 14:41:55.546 User name: xxxxxxx (Password: Yes, Key file: No)
. 2008-03-09 14:41:55.546 Transfer Protocol: SFTP
. 2008-03-09 14:41:55.546 SSH protocol version: 2 only; Compression: Yes
. 2008-03-09 14:41:55.546 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-03-09 14:41:55.546 Ciphers: blowfish,aes,3des,WARN,des; Ssh2DES: No
. 2008-03-09 14:41:55.546 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-03-09 14:41:55.546 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-03-09 14:41:55.546 SFTP Bugs: -,-,-
. 2008-03-09 14:41:55.546 Proxy: none
. 2008-03-09 14:41:55.546 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-03-09 14:41:55.546 Shell: default, EOL: 0
. 2008-03-09 14:41:55.546 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-03-09 14:41:55.546 Cache directory changes: Yes, Permanent: Yes
. 2008-03-09 14:41:55.546 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-03-09 14:41:55.546 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-03-09 14:41:55.546 Looking up host "xxx.xxx.xxx"
. 2008-03-09 14:41:55.687 Connecting to xxx.xxx.xxx.xx port 22
. 2008-03-09 14:41:56.156 Server version: SSH-1.99-OpenSSH_3.9p1
. 2008-03-09 14:41:56.156 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2008-03-09 14:41:56.156 Using SSH protocol version 2
. 2008-03-09 14:41:56.156 Doing Diffie-Hellman group exchange
. 2008-03-09 14:41:56.265 Doing Diffie-Hellman key exchange
. 2008-03-09 14:41:56.390 Host key fingerprint is:
. 2008-03-09 14:41:56.390 ssh-rsa 1024 5e:a6:fc:76:75:70:62:50:e7:c5:ee:49:a1:cc:1b:b1
. 2008-03-09 14:41:56.390 Initialised Blowfish client->server encryption
. 2008-03-09 14:41:56.390 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 14:41:56.390 Initialised zlib (RFC1950) compression
. 2008-03-09 14:41:56.390 Initialised Blowfish server->client encryption
. 2008-03-09 14:41:56.390 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 14:41:56.390 Initialised zlib (RFC1950) decompression
! 2008-03-09 14:41:56.390 Using username "xxxxxxx".
. 2008-03-09 14:41:56.453 Session password prompt (xxxxxxx@xxx.xxx.xxx's password: )
. 2008-03-09 14:41:56.453 Using stored password.
! 2008-03-09 14:41:56.453 Authenticating with pre-entered password.
. 2008-03-09 14:41:56.453 Sent password
. 2008-03-09 14:41:58.328 Access granted
. 2008-03-09 14:41:59.671 Opened channel for session
. 2008-03-09 14:41:59.859 Started a shell/command
. 2008-03-09 14:41:59.859 --------------------------------------------------------------------------
. 2008-03-09 14:41:59.859 Using SFTP protocol.
. 2008-03-09 14:41:59.859 Doing startup conversation with host.
> 2008-03-09 14:41:59.859 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2008-03-09 14:42:01.703 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2008-03-09 14:42:01.703 SFTP version 3 negotiated.
. 2008-03-09 14:42:01.703 We believe the server has signed timestamps bug
. 2008-03-09 14:42:01.703 We will use UTF-8 strings for status messages only
. 2008-03-09 14:42:01.703 Limiting packet size to OpenSSH limit of 262148 bytes
. 2008-03-09 14:42:01.703 Getting current directory name.
. 2008-03-09 14:42:01.703 Getting real path for '.'
> 2008-03-09 14:42:01.703 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2008-03-09 14:42:01.734 Type: SSH_FXP_NAME, Size: 65, Number: 16
. 2008-03-09 14:42:01.734 Real path is '/cos1/hpss/x/x/xxxxxxx'
. 2008-03-09 14:42:01.734 Startup conversation with host finished.
. 2008-03-09 14:42:01.734 Cached directory change via "/cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full" to "/cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full".
. 2008-03-09 14:42:01.734 Getting current directory name.
. 2008-03-09 14:42:01.734 Copying 1 files/directories to remote directory "/cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full"
. 2008-03-09 14:42:01.734 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: N (102400); CalcS: No; Mask: 2008-03-09_xxxxxxxxxxxxxx_Copy.bkf
. 2008-03-09 14:42:01.734 TM: B; ClAr: No; ExclM(No):
. 2008-03-09 14:42:01.734 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2008-03-09 14:42:01.734 File: "F:\backup\2008-03-09_xxxxxxxxxxxxxx_Copy.bkf"
. 2008-03-09 14:42:01.734 Copying "F:\backup\2008-03-09_xxxxxxxxxxxxxx_Copy.bkf" to remote directory started.
. 2008-03-09 14:42:01.734 Binary transfer mode selected.
. 2008-03-09 14:42:01.734 Opening remote file.
> 2008-03-09 14:42:01.734 Type: SSH_FXP_OPEN, Size: 117, Number: 259
< 2008-03-09 14:42:03.484 Type: SSH_FXP_HANDLE, Size: 13, Number: 259
> 2008-03-09 14:42:03.500 Type: SSH_FXP_WRITE, Size: 4121, Number: 774
. 2008-03-09 14:56:35.455 Initiating key re-exchange (too much data sent)
. 2008-03-09 14:56:35.455 Doing Diffie-Hellman group exchange
. 2008-03-09 14:56:35.455 Doing Diffie-Hellman key exchange
. 2008-03-09 14:56:35.533 Initialised Blowfish client->server encryption
. 2008-03-09 14:56:35.533 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 14:56:35.533 Initialised zlib (RFC1950) compression
. 2008-03-09 14:56:35.564 Initialised Blowfish server->client encryption
. 2008-03-09 14:56:35.564 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 14:56:35.564 Initialised zlib (RFC1950) decompression
. 2008-03-09 15:08:52.640 Initiating key re-exchange (too much data sent)
. 2008-03-09 15:08:52.655 Doing Diffie-Hellman group exchange
. 2008-03-09 15:08:52.686 Doing Diffie-Hellman key exchange
. 2008-03-09 15:08:52.765 Initialised Blowfish client->server encryption
. 2008-03-09 15:08:52.765 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 15:08:52.765 Initialised zlib (RFC1950) compression
. 2008-03-09 15:08:52.811 Initialised Blowfish server->client encryption
. 2008-03-09 15:08:52.811 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 15:08:52.811 Initialised zlib (RFC1950) decompression
. 2008-03-09 15:24:22.910 Initiating key re-exchange (too much data sent)
. 2008-03-09 15:24:22.910 Doing Diffie-Hellman group exchange
. 2008-03-09 15:24:22.957 Doing Diffie-Hellman key exchange
. 2008-03-09 15:24:23.035 Initialised Blowfish client->server encryption
. 2008-03-09 15:24:23.035 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 15:24:23.035 Initialised zlib (RFC1950) compression
. 2008-03-09 15:24:23.066 Initialised Blowfish server->client encryption
. 2008-03-09 15:24:23.066 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 15:24:23.066 Initialised zlib (RFC1950) decompression
. 2008-03-09 15:34:34.621 Initiating key re-exchange (too much data sent)
. 2008-03-09 15:34:34.652 Doing Diffie-Hellman group exchange
. 2008-03-09 15:34:34.668 Doing Diffie-Hellman key exchange
. 2008-03-09 15:34:34.730 Initialised Blowfish client->server encryption
. 2008-03-09 15:34:34.730 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 15:34:34.730 Initialised zlib (RFC1950) compression
. 2008-03-09 15:34:34.777 Initialised Blowfish server->client encryption
. 2008-03-09 15:34:34.777 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 15:34:34.777 Initialised zlib (RFC1950) decompression
. 2008-03-09 15:44:50.619 Initiating key re-exchange (too much data sent)
. 2008-03-09 15:44:50.666 Doing Diffie-Hellman group exchange
. 2008-03-09 15:44:50.666 Doing Diffie-Hellman key exchange
. 2008-03-09 15:44:50.744 Initialised Blowfish client->server encryption
. 2008-03-09 15:44:50.744 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 15:44:50.744 Initialised zlib (RFC1950) compression
. 2008-03-09 15:44:50.791 Initialised Blowfish server->client encryption
. 2008-03-09 15:44:50.791 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 15:44:50.791 Initialised zlib (RFC1950) decompression
. 2008-03-09 15:55:35.203 Initiating key re-exchange (too much data sent)
. 2008-03-09 15:55:35.203 Doing Diffie-Hellman group exchange
. 2008-03-09 15:55:35.250 Doing Diffie-Hellman key exchange
. 2008-03-09 15:55:35.328 Initialised Blowfish client->server encryption
. 2008-03-09 15:55:35.328 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 15:55:35.328 Initialised zlib (RFC1950) compression
. 2008-03-09 15:55:35.360 Initialised Blowfish server->client encryption
. 2008-03-09 15:55:35.360 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 15:55:35.360 Initialised zlib (RFC1950) decompression
. 2008-03-09 16:06:14.807 Initiating key re-exchange (too much data sent)
. 2008-03-09 16:06:14.838 Doing Diffie-Hellman group exchange
. 2008-03-09 16:06:14.854 Doing Diffie-Hellman key exchange
. 2008-03-09 16:06:14.932 Initialised Blowfish client->server encryption
. 2008-03-09 16:06:14.932 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 16:06:14.932 Initialised zlib (RFC1950) compression
. 2008-03-09 16:06:14.963 Initialised Blowfish server->client encryption
. 2008-03-09 16:06:14.963 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 16:06:14.963 Initialised zlib (RFC1950) decompression
. 2008-03-09 16:15:47.328 Initiating key re-exchange (too much data sent)
. 2008-03-09 16:15:47.328 Doing Diffie-Hellman group exchange
. 2008-03-09 16:15:47.375 Doing Diffie-Hellman key exchange
. 2008-03-09 16:15:47.453 Initialised Blowfish client->server encryption
. 2008-03-09 16:15:47.453 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 16:15:47.453 Initialised zlib (RFC1950) compression
. 2008-03-09 16:15:47.500 Initialised Blowfish server->client encryption
. 2008-03-09 16:15:47.500 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 16:15:47.500 Initialised zlib (RFC1950) decompression
. 2008-03-09 16:25:26.022 Initiating key re-exchange (too much data sent)
. 2008-03-09 16:25:26.022 Doing Diffie-Hellman group exchange
. 2008-03-09 16:25:26.069 Doing Diffie-Hellman key exchange
. 2008-03-09 16:25:26.147 Initialised Blowfish client->server encryption
. 2008-03-09 16:25:26.147 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 16:25:26.147 Initialised zlib (RFC1950) compression
. 2008-03-09 16:25:26.179 Initialised Blowfish server->client encryption
. 2008-03-09 16:25:26.179 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 16:25:26.179 Initialised zlib (RFC1950) decompression
. 2008-03-09 16:35:17.904 Initiating key re-exchange (too much data sent)
. 2008-03-09 16:35:17.904 Doing Diffie-Hellman group exchange
. 2008-03-09 16:35:17.936 Doing Diffie-Hellman key exchange
. 2008-03-09 16:35:18.014 Initialised Blowfish client->server encryption
. 2008-03-09 16:35:18.014 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 16:35:18.014 Initialised zlib (RFC1950) compression
. 2008-03-09 16:35:18.061 Initialised Blowfish server->client encryption
. 2008-03-09 16:35:18.061 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 16:35:18.061 Initialised zlib (RFC1950) decompression
. 2008-03-09 16:49:23.359 Initiating key re-exchange (too much data sent)
. 2008-03-09 16:49:23.406 Doing Diffie-Hellman group exchange
. 2008-03-09 16:49:23.406 Doing Diffie-Hellman key exchange
. 2008-03-09 16:49:23.484 Initialised Blowfish client->server encryption
. 2008-03-09 16:49:23.484 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 16:49:23.484 Initialised zlib (RFC1950) compression
. 2008-03-09 16:49:23.546 Initialised Blowfish server->client encryption
. 2008-03-09 16:49:23.546 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 16:49:23.546 Initialised zlib (RFC1950) decompression
. 2008-03-09 17:00:57.339 Initiating key re-exchange (too much data sent)
. 2008-03-09 17:00:57.370 Doing Diffie-Hellman group exchange
. 2008-03-09 17:00:57.370 Doing Diffie-Hellman key exchange
. 2008-03-09 17:00:57.448 Initialised Blowfish client->server encryption
. 2008-03-09 17:00:57.448 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 17:00:57.448 Initialised zlib (RFC1950) compression
. 2008-03-09 17:00:57.495 Initialised Blowfish server->client encryption
. 2008-03-09 17:00:57.495 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 17:00:57.495 Initialised zlib (RFC1950) decompression
. 2008-03-09 17:11:37.066 Initiating key re-exchange (too much data sent)
. 2008-03-09 17:11:37.066 Doing Diffie-Hellman group exchange
. 2008-03-09 17:11:37.113 Doing Diffie-Hellman key exchange
. 2008-03-09 17:11:37.191 Initialised Blowfish client->server encryption
. 2008-03-09 17:11:37.191 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 17:11:37.191 Initialised zlib (RFC1950) compression
. 2008-03-09 17:11:37.222 Initialised Blowfish server->client encryption
. 2008-03-09 17:11:37.222 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 17:11:37.222 Initialised zlib (RFC1950) decompression
. 2008-03-09 17:23:10.405 Initiating key re-exchange (too much data sent)
. 2008-03-09 17:23:10.405 Doing Diffie-Hellman group exchange
. 2008-03-09 17:23:10.452 Doing Diffie-Hellman key exchange
. 2008-03-09 17:23:10.530 Initialised Blowfish client->server encryption
. 2008-03-09 17:23:10.530 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 17:23:10.530 Initialised zlib (RFC1950) compression
. 2008-03-09 17:23:10.577 Initialised Blowfish server->client encryption
. 2008-03-09 17:23:10.577 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 17:23:10.577 Initialised zlib (RFC1950) decompression
. 2008-03-09 17:34:01.946 Initiating key re-exchange (too much data sent)
. 2008-03-09 17:34:01.946 Doing Diffie-Hellman group exchange
. 2008-03-09 17:34:01.993 Doing Diffie-Hellman key exchange
. 2008-03-09 17:34:02.071 Initialised Blowfish client->server encryption
. 2008-03-09 17:34:02.071 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 17:34:02.071 Initialised zlib (RFC1950) compression
. 2008-03-09 17:34:02.102 Initialised Blowfish server->client encryption
. 2008-03-09 17:34:02.102 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 17:34:02.102 Initialised zlib (RFC1950) decompression
. 2008-03-09 17:45:04.065 Initiating key re-exchange (too much data sent)
. 2008-03-09 17:45:04.065 Doing Diffie-Hellman group exchange
. 2008-03-09 17:45:04.065 Doing Diffie-Hellman key exchange
. 2008-03-09 17:45:04.143 Initialised Blowfish client->server encryption
. 2008-03-09 17:45:04.143 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 17:45:04.143 Initialised zlib (RFC1950) compression
. 2008-03-09 17:45:04.190 Initialised Blowfish server->client encryption
. 2008-03-09 17:45:04.190 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 17:45:04.190 Initialised zlib (RFC1950) decompression
. 2008-03-09 17:57:03.858 Initiating key re-exchange (too much data sent)
. 2008-03-09 17:57:03.905 Doing Diffie-Hellman group exchange
. 2008-03-09 17:57:03.905 Doing Diffie-Hellman key exchange
. 2008-03-09 17:57:03.983 Initialised Blowfish client->server encryption
. 2008-03-09 17:57:03.983 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 17:57:03.983 Initialised zlib (RFC1950) compression
. 2008-03-09 17:57:04.015 Initialised Blowfish server->client encryption
. 2008-03-09 17:57:04.015 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 17:57:04.015 Initialised zlib (RFC1950) decompression
. 2008-03-09 18:08:14.632 Initiating key re-exchange (too much data sent)
. 2008-03-09 18:08:14.632 Doing Diffie-Hellman group exchange
. 2008-03-09 18:08:14.679 Doing Diffie-Hellman key exchange
. 2008-03-09 18:08:14.757 Initialised Blowfish client->server encryption
. 2008-03-09 18:08:14.757 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 18:08:14.757 Initialised zlib (RFC1950) compression
. 2008-03-09 18:08:14.789 Initialised Blowfish server->client encryption
. 2008-03-09 18:08:14.789 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 18:08:14.789 Initialised zlib (RFC1950) decompression
. 2008-03-09 18:18:56.082 Initiating key re-exchange (too much data sent)
. 2008-03-09 18:18:56.082 Doing Diffie-Hellman group exchange
. 2008-03-09 18:18:56.129 Doing Diffie-Hellman key exchange
. 2008-03-09 18:18:56.207 Initialised Blowfish client->server encryption
. 2008-03-09 18:18:56.207 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 18:18:56.207 Initialised zlib (RFC1950) compression
. 2008-03-09 18:18:56.238 Initialised Blowfish server->client encryption
. 2008-03-09 18:18:56.238 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 18:18:56.238 Initialised zlib (RFC1950) decompression
. 2008-03-09 18:34:56.038 Initiating key re-exchange (too much data sent)
. 2008-03-09 18:34:56.038 Doing Diffie-Hellman group exchange
. 2008-03-09 18:34:56.085 Doing Diffie-Hellman key exchange
. 2008-03-09 18:34:56.163 Initialised Blowfish client->server encryption
. 2008-03-09 18:34:56.163 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 18:34:56.163 Initialised zlib (RFC1950) compression
. 2008-03-09 18:34:56.210 Initialised Blowfish server->client encryption
. 2008-03-09 18:34:56.210 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 18:34:56.210 Initialised zlib (RFC1950) decompression
. 2008-03-09 18:49:19.712 Initiating key re-exchange (too much data sent)
. 2008-03-09 18:49:19.759 Doing Diffie-Hellman group exchange
. 2008-03-09 18:49:19.759 Doing Diffie-Hellman key exchange
. 2008-03-09 18:49:19.837 Initialised Blowfish client->server encryption
. 2008-03-09 18:49:19.837 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 18:49:19.837 Initialised zlib (RFC1950) compression
. 2008-03-09 18:49:19.869 Initialised Blowfish server->client encryption
. 2008-03-09 18:49:19.869 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 18:49:19.869 Initialised zlib (RFC1950) decompression
. 2008-03-09 19:00:56.177 Initiating key re-exchange (too much data sent)
. 2008-03-09 19:00:56.177 Doing Diffie-Hellman group exchange
. 2008-03-09 19:00:56.177 Doing Diffie-Hellman key exchange
. 2008-03-09 19:00:56.255 Initialised Blowfish client->server encryption
. 2008-03-09 19:00:56.255 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 19:00:56.255 Initialised zlib (RFC1950) compression
. 2008-03-09 19:00:56.286 Initialised Blowfish server->client encryption
. 2008-03-09 19:00:56.286 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 19:00:56.286 Initialised zlib (RFC1950) decompression
. 2008-03-09 19:10:27.745 Initiating key re-exchange (too much data sent)
. 2008-03-09 19:10:27.792 Doing Diffie-Hellman group exchange
. 2008-03-09 19:10:27.792 Doing Diffie-Hellman key exchange
. 2008-03-09 19:10:27.870 Initialised Blowfish client->server encryption
. 2008-03-09 19:10:27.870 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 19:10:27.870 Initialised zlib (RFC1950) compression
. 2008-03-09 19:10:27.917 Initialised Blowfish server->client encryption
. 2008-03-09 19:10:27.917 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 19:10:27.917 Initialised zlib (RFC1950) decompression
. 2008-03-09 19:22:07.725 Initiating key re-exchange (too much data sent)
. 2008-03-09 19:22:07.725 Doing Diffie-Hellman group exchange
. 2008-03-09 19:22:07.772 Doing Diffie-Hellman key exchange
. 2008-03-09 19:22:07.850 Initialised Blowfish client->server encryption
. 2008-03-09 19:22:07.850 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 19:22:07.850 Initialised zlib (RFC1950) compression
. 2008-03-09 19:22:07.882 Initialised Blowfish server->client encryption
. 2008-03-09 19:22:07.882 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 19:22:07.882 Initialised zlib (RFC1950) decompression
. 2008-03-09 19:31:40.997 Initiating key re-exchange (too much data sent)
. 2008-03-09 19:31:40.997 Doing Diffie-Hellman group exchange
. 2008-03-09 19:31:41.044 Doing Diffie-Hellman key exchange
. 2008-03-09 19:31:41.122 Initialised Blowfish client->server encryption
. 2008-03-09 19:31:41.122 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 19:31:41.122 Initialised zlib (RFC1950) compression
. 2008-03-09 19:31:41.154 Initialised Blowfish server->client encryption
. 2008-03-09 19:31:41.154 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 19:31:41.154 Initialised zlib (RFC1950) decompression
. 2008-03-09 19:41:15.254 Initiating key re-exchange (too much data sent)
. 2008-03-09 19:41:15.254 Doing Diffie-Hellman group exchange
. 2008-03-09 19:41:15.301 Doing Diffie-Hellman key exchange
. 2008-03-09 19:41:15.363 Initialised Blowfish client->server encryption
. 2008-03-09 19:41:15.363 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 19:41:15.363 Initialised zlib (RFC1950) compression
. 2008-03-09 19:41:15.410 Initialised Blowfish server->client encryption
. 2008-03-09 19:41:15.410 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 19:41:15.410 Initialised zlib (RFC1950) decompression
. 2008-03-09 19:52:20.451 Initiating key re-exchange (too much data sent)
. 2008-03-09 19:52:20.451 Doing Diffie-Hellman group exchange
. 2008-03-09 19:52:20.467 Doing Diffie-Hellman key exchange
. 2008-03-09 19:52:20.529 Initialised Blowfish client->server encryption
. 2008-03-09 19:52:20.529 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 19:52:20.529 Initialised zlib (RFC1950) compression
. 2008-03-09 19:52:20.576 Initialised Blowfish server->client encryption
. 2008-03-09 19:52:20.576 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 19:52:20.576 Initialised zlib (RFC1950) decompression
. 2008-03-09 20:02:55.647 Initiating key re-exchange (too much data sent)
. 2008-03-09 20:02:55.647 Doing Diffie-Hellman group exchange
. 2008-03-09 20:02:55.663 Doing Diffie-Hellman key exchange
. 2008-03-09 20:02:55.726 Initialised Blowfish client->server encryption
. 2008-03-09 20:02:55.726 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 20:02:55.726 Initialised zlib (RFC1950) compression
. 2008-03-09 20:02:55.772 Initialised Blowfish server->client encryption
. 2008-03-09 20:02:55.772 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 20:02:55.772 Initialised zlib (RFC1950) decompression
. 2008-03-09 20:13:14.234 Initiating key re-exchange (too much data sent)
. 2008-03-09 20:13:14.234 Doing Diffie-Hellman group exchange
. 2008-03-09 20:13:14.281 Doing Diffie-Hellman key exchange
. 2008-03-09 20:13:14.359 Initialised Blowfish client->server encryption
. 2008-03-09 20:13:14.359 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 20:13:14.359 Initialised zlib (RFC1950) compression
. 2008-03-09 20:13:14.406 Initialised Blowfish server->client encryption
. 2008-03-09 20:13:14.406 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 20:13:14.406 Initialised zlib (RFC1950) decompression
. 2008-03-09 20:24:01.994 Initiating key re-exchange (too much data sent)
. 2008-03-09 20:24:02.010 Doing Diffie-Hellman group exchange
. 2008-03-09 20:24:02.041 Doing Diffie-Hellman key exchange
. 2008-03-09 20:24:02.119 Initialised Blowfish client->server encryption
. 2008-03-09 20:24:02.119 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 20:24:02.119 Initialised zlib (RFC1950) compression
. 2008-03-09 20:24:02.166 Initialised Blowfish server->client encryption
. 2008-03-09 20:24:02.166 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 20:24:02.166 Initialised zlib (RFC1950) decompression
. 2008-03-09 20:35:44.984 Initiating key re-exchange (too much data sent)
. 2008-03-09 20:35:44.984 Doing Diffie-Hellman group exchange
. 2008-03-09 20:35:45.031 Doing Diffie-Hellman key exchange
. 2008-03-09 20:35:45.109 Initialised Blowfish client->server encryption
. 2008-03-09 20:35:45.109 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 20:35:45.109 Initialised zlib (RFC1950) compression
. 2008-03-09 20:35:45.141 Initialised Blowfish server->client encryption
. 2008-03-09 20:35:45.141 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 20:35:45.141 Initialised zlib (RFC1950) decompression
. 2008-03-09 20:49:26.342 Initiating key re-exchange (too much data sent)
. 2008-03-09 20:49:26.357 Doing Diffie-Hellman group exchange
. 2008-03-09 20:49:26.357 Doing Diffie-Hellman key exchange
. 2008-03-09 20:49:26.435 Initialised Blowfish client->server encryption
. 2008-03-09 20:49:26.435 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 20:49:26.435 Initialised zlib (RFC1950) compression
. 2008-03-09 20:49:26.451 Initialised Blowfish server->client encryption
. 2008-03-09 20:49:26.451 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 20:49:26.451 Initialised zlib (RFC1950) decompression
. 2008-03-09 21:02:16.153 Initiating key re-exchange (too much data sent)
. 2008-03-09 21:02:16.199 Doing Diffie-Hellman group exchange
. 2008-03-09 21:02:16.199 Doing Diffie-Hellman key exchange
. 2008-03-09 21:02:16.278 Initialised Blowfish client->server encryption
. 2008-03-09 21:02:16.278 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 21:02:16.278 Initialised zlib (RFC1950) compression
. 2008-03-09 21:02:16.324 Initialised Blowfish server->client encryption
. 2008-03-09 21:02:16.324 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 21:02:16.324 Initialised zlib (RFC1950) decompression
. 2008-03-09 21:10:11.499 Waiting for data timed out, asking user what to do.
. 2008-03-09 21:10:11.499 Asking user:
. 2008-03-09 21:10:11.499 Host has not answered for 15 seconds.
. 2008-03-09 21:10:11.499 Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. 2008-03-09 21:10:11.499 Attempt to close connection due to fatal exception:
* 2008-03-09 21:10:11.499 Terminated by user.
. 2008-03-09 21:10:11.499 Closing connection.
. 2008-03-09 21:10:13.499 --------------------------------------------------------------------------
. 2008-03-09 21:10:13.499 WinSCP Version 3.8.2 (Build 330) (OS 5.2.3790 Service Pack 2)
. 2008-03-09 21:10:13.499 Login time: Sunday, March 09, 2008 9:10:13 PM
. 2008-03-09 21:10:13.499 Session name: xxxxxxx
. 2008-03-09 21:10:13.499 Host name: xxx.xxx.xxx (Port: 22)
. 2008-03-09 21:10:13.499 User name: xxxxxxx (Password: Yes, Key file: No)
. 2008-03-09 21:10:13.499 Transfer Protocol: SFTP
. 2008-03-09 21:10:13.499 SSH protocol version: 2 only; Compression: Yes
. 2008-03-09 21:10:13.499 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-03-09 21:10:13.499 Ciphers: blowfish,aes,3des,WARN,des; Ssh2DES: No
. 2008-03-09 21:10:13.499 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-03-09 21:10:13.499 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-03-09 21:10:13.499 SFTP Bugs: -,-,-
. 2008-03-09 21:10:13.499 Proxy: none
. 2008-03-09 21:10:13.499 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-03-09 21:10:13.499 Shell: default, EOL: 0
. 2008-03-09 21:10:13.499 Local directory: default, Remote directory: /cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full, Update: No, Cache: Yes
. 2008-03-09 21:10:13.499 Cache directory changes: Yes, Permanent: Yes
. 2008-03-09 21:10:13.499 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-03-09 21:10:13.499 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-03-09 21:10:13.499 Looking up host "xxx.xxx.xxx"
. 2008-03-09 21:10:13.499 Connecting to xxx.xxx.xxx.xx port 22
. 2008-03-09 21:10:13.515 Server version: SSH-1.99-OpenSSH_3.9p1
. 2008-03-09 21:10:13.515 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2008-03-09 21:10:13.515 Using SSH protocol version 2
. 2008-03-09 21:10:13.515 Doing Diffie-Hellman group exchange
. 2008-03-09 21:10:13.561 Doing Diffie-Hellman key exchange
. 2008-03-09 21:10:13.640 Host key fingerprint is:
. 2008-03-09 21:10:13.640 ssh-rsa 1024 5e:a6:fc:76:75:70:62:50:e7:c5:ee:49:a1:cc:1b:b1
. 2008-03-09 21:10:13.640 Initialised Blowfish client->server encryption
. 2008-03-09 21:10:13.640 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 21:10:13.640 Initialised zlib (RFC1950) compression
. 2008-03-09 21:10:13.640 Initialised Blowfish server->client encryption
. 2008-03-09 21:10:13.640 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 21:10:13.640 Initialised zlib (RFC1950) decompression
! 2008-03-09 21:10:13.671 Using username "xxxxxxx".
. 2008-03-09 21:10:13.671 Session password prompt (xxxxxxx@xxx.xxx.xxx's password: )
. 2008-03-09 21:10:13.686 Using stored password.
! 2008-03-09 21:10:13.686 Authenticating with pre-entered password.
. 2008-03-09 21:10:13.686 Sent password
. 2008-03-09 21:10:28.687 Waiting for data timed out, asking user what to do.
. 2008-03-09 21:10:28.687 Asking user:
. 2008-03-09 21:10:28.687 Host has not answered for 15 seconds.
. 2008-03-09 21:10:28.687 Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. 2008-03-09 21:10:28.687 Attempt to close connection due to fatal exception:
* 2008-03-09 21:10:28.687 Terminated by user.
. 2008-03-09 21:10:28.687 Closing connection.
. 2008-03-09 21:10:30.687 --------------------------------------------------------------------------
. 2008-03-09 21:10:30.687 WinSCP Version 3.8.2 (Build 330) (OS 5.2.3790 Service Pack 2)
. 2008-03-09 21:10:30.687 Login time: Sunday, March 09, 2008 9:10:30 PM
. 2008-03-09 21:10:30.687 Session name: xxxxxxx
. 2008-03-09 21:10:30.687 Host name: xxx.xxx.xxx (Port: 22)
. 2008-03-09 21:10:30.687 User name: xxxxxxx (Password: Yes, Key file: No)
. 2008-03-09 21:10:30.687 Transfer Protocol: SFTP
. 2008-03-09 21:10:30.687 SSH protocol version: 2 only; Compression: Yes
. 2008-03-09 21:10:30.687 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-03-09 21:10:30.687 Ciphers: blowfish,aes,3des,WARN,des; Ssh2DES: No
. 2008-03-09 21:10:30.687 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-03-09 21:10:30.687 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-03-09 21:10:30.687 SFTP Bugs: -,-,-
. 2008-03-09 21:10:30.687 Proxy: none
. 2008-03-09 21:10:30.687 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-03-09 21:10:30.687 Shell: default, EOL: 0
. 2008-03-09 21:10:30.687 Local directory: default, Remote directory: /cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full, Update: No, Cache: Yes
. 2008-03-09 21:10:30.687 Cache directory changes: Yes, Permanent: Yes
. 2008-03-09 21:10:30.687 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-03-09 21:10:30.687 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-03-09 21:10:30.687 Looking up host "xxx.xxx.xxx"
. 2008-03-09 21:10:30.687 Connecting to xxx.xxx.xxx.xx port 22
. 2008-03-09 21:10:30.703 Server version: SSH-1.99-OpenSSH_3.9p1
. 2008-03-09 21:10:30.703 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2008-03-09 21:10:30.703 Using SSH protocol version 2
. 2008-03-09 21:10:30.703 Doing Diffie-Hellman group exchange
. 2008-03-09 21:10:30.750 Doing Diffie-Hellman key exchange
. 2008-03-09 21:10:30.828 Host key fingerprint is:
. 2008-03-09 21:10:30.828 ssh-rsa 1024 5e:a6:fc:76:75:70:62:50:e7:c5:ee:49:a1:cc:1b:b1
. 2008-03-09 21:10:30.828 Initialised Blowfish client->server encryption
. 2008-03-09 21:10:30.843 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 21:10:30.843 Initialised zlib (RFC1950) compression
. 2008-03-09 21:10:30.843 Initialised Blowfish server->client encryption
. 2008-03-09 21:10:30.843 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 21:10:30.843 Initialised zlib (RFC1950) decompression
! 2008-03-09 21:10:30.859 Using username "xxxxxxx".
. 2008-03-09 21:10:30.859 Session password prompt (xxxxxxx@xxx.xxx.xxx's password: )
. 2008-03-09 21:10:30.859 Using stored password.
! 2008-03-09 21:10:30.859 Authenticating with pre-entered password.
. 2008-03-09 21:10:30.859 Sent password
. 2008-03-09 21:10:45.860 Waiting for data timed out, asking user what to do.
. 2008-03-09 21:10:45.860 Asking user:
. 2008-03-09 21:10:45.860 Host has not answered for 15 seconds.
. 2008-03-09 21:10:45.860 Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. 2008-03-09 21:10:45.860 Attempt to close connection due to fatal exception:
* 2008-03-09 21:10:45.860 Terminated by user.
. 2008-03-09 21:10:45.860 Closing connection.
. 2008-03-09 21:10:47.860 --------------------------------------------------------------------------
. 2008-03-09 21:10:47.860 WinSCP Version 3.8.2 (Build 330) (OS 5.2.3790 Service Pack 2)
. 2008-03-09 21:10:47.860 Login time: Sunday, March 09, 2008 9:10:47 PM
. 2008-03-09 21:10:47.860 Session name: xxxxxxx
. 2008-03-09 21:10:47.860 Host name: xxx.xxx.xxx (Port: 22)
. 2008-03-09 21:10:47.860 User name: xxxxxxx (Password: Yes, Key file: No)
. 2008-03-09 21:10:47.860 Transfer Protocol: SFTP
. 2008-03-09 21:10:47.860 SSH protocol version: 2 only; Compression: Yes
. 2008-03-09 21:10:47.860 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-03-09 21:10:47.860 Ciphers: blowfish,aes,3des,WARN,des; Ssh2DES: No
. 2008-03-09 21:10:47.860 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-03-09 21:10:47.860 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-03-09 21:10:47.860 SFTP Bugs: -,-,-
. 2008-03-09 21:10:47.860 Proxy: none
. 2008-03-09 21:10:47.860 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-03-09 21:10:47.860 Shell: default, EOL: 0
. 2008-03-09 21:10:47.860 Local directory: default, Remote directory: /cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full, Update: No, Cache: Yes
. 2008-03-09 21:10:47.860 Cache directory changes: Yes, Permanent: Yes
. 2008-03-09 21:10:47.860 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-03-09 21:10:47.860 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-03-09 21:10:47.860 Looking up host "xxx.xxx.xxx"
. 2008-03-09 21:10:47.860 Connecting to xxx.xxx.xxx.xx port 22
. 2008-03-09 21:10:47.875 Server version: SSH-1.99-OpenSSH_3.9p1
. 2008-03-09 21:10:47.875 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2008-03-09 21:10:47.875 Using SSH protocol version 2
. 2008-03-09 21:10:47.875 Doing Diffie-Hellman group exchange
. 2008-03-09 21:10:47.922 Doing Diffie-Hellman key exchange
. 2008-03-09 21:10:48.000 Host key fingerprint is:
. 2008-03-09 21:10:48.000 ssh-rsa 1024 5e:a6:fc:76:75:70:62:50:e7:c5:ee:49:a1:cc:1b:b1
. 2008-03-09 21:10:48.000 Initialised Blowfish client->server encryption
. 2008-03-09 21:10:48.000 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 21:10:48.000 Initialised zlib (RFC1950) compression
. 2008-03-09 21:10:48.000 Initialised Blowfish server->client encryption
. 2008-03-09 21:10:48.000 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 21:10:48.000 Initialised zlib (RFC1950) decompression
! 2008-03-09 21:10:48.032 Using username "xxxxxxx".
. 2008-03-09 21:10:48.032 Session password prompt (xxxxxxx@xxx.xxx.xxx's password: )
. 2008-03-09 21:10:48.032 Using stored password.
! 2008-03-09 21:10:48.032 Authenticating with pre-entered password.
. 2008-03-09 21:10:48.032 Sent password
. 2008-03-09 21:11:03.032 Waiting for data timed out, asking user what to do.
. 2008-03-09 21:11:03.032 Asking user:
. 2008-03-09 21:11:03.032 Host has not answered for 15 seconds.
. 2008-03-09 21:11:03.032 Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. 2008-03-09 21:11:03.032 Attempt to close connection due to fatal exception:
* 2008-03-09 21:11:03.032 Terminated by user.
. 2008-03-09 21:11:03.032 Closing connection.
. 2008-03-09 21:11:05.032 --------------------------------------------------------------------------
. 2008-03-09 21:11:05.032 WinSCP Version 3.8.2 (Build 330) (OS 5.2.3790 Service Pack 2)
. 2008-03-09 21:11:05.032 Login time: Sunday, March 09, 2008 9:11:05 PM
. 2008-03-09 21:11:05.032 Session name: xxxxxxx
. 2008-03-09 21:11:05.032 Host name: xxx.xxx.xxx (Port: 22)
. 2008-03-09 21:11:05.032 User name: xxxxxxx (Password: Yes, Key file: No)
. 2008-03-09 21:11:05.032 Transfer Protocol: SFTP
. 2008-03-09 21:11:05.032 SSH protocol version: 2 only; Compression: Yes
. 2008-03-09 21:11:05.032 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-03-09 21:11:05.032 Ciphers: blowfish,aes,3des,WARN,des; Ssh2DES: No
. 2008-03-09 21:11:05.032 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-03-09 21:11:05.032 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-03-09 21:11:05.032 SFTP Bugs: -,-,-
. 2008-03-09 21:11:05.032 Proxy: none
. 2008-03-09 21:11:05.032 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-03-09 21:11:05.032 Shell: default, EOL: 0
. 2008-03-09 21:11:05.032 Local directory: default, Remote directory: /cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full, Update: No, Cache: Yes
. 2008-03-09 21:11:05.032 Cache directory changes: Yes, Permanent: Yes
. 2008-03-09 21:11:05.032 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-03-09 21:11:05.032 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-03-09 21:11:05.032 Looking up host "xxx.xxx.xxx"
. 2008-03-09 21:11:05.032 Connecting to xxx.xxx.xxx.xx port 22
. 2008-03-09 21:11:05.048 Server version: SSH-1.99-OpenSSH_3.9p1
. 2008-03-09 21:11:05.048 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2008-03-09 21:11:05.048 Using SSH protocol version 2
. 2008-03-09 21:11:05.048 Doing Diffie-Hellman group exchange
. 2008-03-09 21:11:05.095 Doing Diffie-Hellman key exchange
. 2008-03-09 21:11:05.173 Host key fingerprint is:
. 2008-03-09 21:11:05.173 ssh-rsa 1024 5e:a6:fc:76:75:70:62:50:e7:c5:ee:49:a1:cc:1b:b1
. 2008-03-09 21:11:05.173 Initialised Blowfish client->server encryption
. 2008-03-09 21:11:05.173 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 21:11:05.173 Initialised zlib (RFC1950) compression
. 2008-03-09 21:11:05.173 Initialised Blowfish server->client encryption
. 2008-03-09 21:11:05.173 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 21:11:05.173 Initialised zlib (RFC1950) decompression
! 2008-03-09 21:11:05.204 Using username "xxxxxxx".
. 2008-03-09 21:11:05.204 Session password prompt (xxxxxxx@xxx.xxx.xxx's password: )
. 2008-03-09 21:11:05.204 Using stored password.
! 2008-03-09 21:11:05.204 Authenticating with pre-entered password.
. 2008-03-09 21:11:05.204 Sent password
. 2008-03-09 21:11:13.986 Access granted
. 2008-03-09 21:11:14.376 Opened channel for session
. 2008-03-09 21:11:14.376 Started a shell/command
. 2008-03-09 21:11:14.376 --------------------------------------------------------------------------
. 2008-03-09 21:11:14.376 Doing startup conversation with host.
. 2008-03-09 21:11:14.376 3591271 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-03-09 21:11:14.376 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2008-03-09 21:11:14.642 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2008-03-09 21:11:14.642 SFTP version 3 negotiated.
. 2008-03-09 21:11:14.642 We believe the server has signed timestamps bug
. 2008-03-09 21:11:14.642 We will use UTF-8 strings for status messages only
. 2008-03-09 21:11:14.642 Limiting packet size to OpenSSH limit of 262148 bytes
. 2008-03-09 21:11:14.642 Changing directory to "/cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full".
. 2008-03-09 21:11:14.642 Getting real path for '/cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full'
> 2008-03-09 21:11:14.642 Type: SSH_FXP_REALPATH, Size: 66, Number: 459684112
< 2008-03-09 21:11:14.954 Type: SSH_FXP_NAME, Size: 135, Number: 459684112
. 2008-03-09 21:11:14.954 Real path is '/cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full'
. 2008-03-09 21:11:14.954 Trying to open directory "/cos3/hpss/x/x/xxxxxxx/Weekly_Backups/xxxxxxxxxxxxxx/Full".
> 2008-03-09 21:11:14.954 Type: SSH_FXP_LSTAT, Size: 66, Number: 459684359
< 2008-03-09 21:11:15.001 Type: SSH_FXP_ATTRS, Size: 37, Number: 459684359
. 2008-03-09 21:11:15.001 Getting current directory name.
. 2008-03-09 21:11:15.001 Startup conversation with host finished.
. 2008-03-09 21:11:15.001 File: "F:\backup\2008-03-09_xxxxxxxxxxxxxx_Copy.bkf"
. 2008-03-09 21:11:15.001 Copying "F:\backup\2008-03-09_xxxxxxxxxxxxxx_Copy.bkf" to remote directory started.
. 2008-03-09 21:11:15.001 Binary transfer mode selected.
. 2008-03-09 21:11:15.001 Opening remote file.
> 2008-03-09 21:11:15.001 Type: SSH_FXP_OPEN, Size: 117, Number: 459684611
< 2008-03-09 21:11:17.939 Type: SSH_FXP_HANDLE, Size: 13, Number: 459684611
> 2008-03-09 21:11:17.955 Type: SSH_FXP_WRITE, Size: 4121, Number: 459685126
. 2008-03-09 21:25:59.270 Initiating key re-exchange (too much data sent)
. 2008-03-09 21:25:59.270 Doing Diffie-Hellman group exchange
. 2008-03-09 21:25:59.270 Doing Diffie-Hellman key exchange
. 2008-03-09 21:25:59.363 Initialised Blowfish client->server encryption
. 2008-03-09 21:25:59.363 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 21:25:59.363 Initialised zlib (RFC1950) compression
. 2008-03-09 21:25:59.395 Initialised Blowfish server->client encryption
. 2008-03-09 21:25:59.395 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 21:25:59.395 Initialised zlib (RFC1950) decompression
. 2008-03-09 21:38:15.689 Initiating key re-exchange (too much data sent)
. 2008-03-09 21:38:15.689 Doing Diffie-Hellman group exchange
. 2008-03-09 21:38:15.704 Doing Diffie-Hellman key exchange
. 2008-03-09 21:38:15.782 Initialised Blowfish client->server encryption
. 2008-03-09 21:38:15.782 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 21:38:15.782 Initialised zlib (RFC1950) compression
. 2008-03-09 21:38:15.814 Initialised Blowfish server->client encryption
. 2008-03-09 21:38:15.814 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 21:38:15.814 Initialised zlib (RFC1950) decompression
. 2008-03-09 21:53:45.256 Initiating key re-exchange (too much data sent)
. 2008-03-09 21:53:45.256 Doing Diffie-Hellman group exchange
. 2008-03-09 21:53:45.302 Doing Diffie-Hellman key exchange
. 2008-03-09 21:53:45.381 Initialised Blowfish client->server encryption
. 2008-03-09 21:53:45.381 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 21:53:45.381 Initialised zlib (RFC1950) compression
. 2008-03-09 21:53:45.427 Initialised Blowfish server->client encryption
. 2008-03-09 21:53:45.427 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 21:53:45.427 Initialised zlib (RFC1950) decompression
. 2008-03-09 22:03:57.388 Initiating key re-exchange (too much data sent)
. 2008-03-09 22:03:57.388 Doing Diffie-Hellman group exchange
. 2008-03-09 22:03:57.404 Doing Diffie-Hellman key exchange
. 2008-03-09 22:03:57.482 Initialised Blowfish client->server encryption
. 2008-03-09 22:03:57.482 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 22:03:57.482 Initialised zlib (RFC1950) compression
. 2008-03-09 22:03:57.529 Initialised Blowfish server->client encryption
. 2008-03-09 22:03:57.529 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 22:03:57.529 Initialised zlib (RFC1950) decompression
. 2008-03-09 22:14:23.803 Initiating key re-exchange (too much data sent)
. 2008-03-09 22:14:23.803 Doing Diffie-Hellman group exchange
. 2008-03-09 22:14:23.850 Doing Diffie-Hellman key exchange
. 2008-03-09 22:14:23.928 Initialised Blowfish client->server encryption
. 2008-03-09 22:14:23.928 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 22:14:23.928 Initialised zlib (RFC1950) compression
. 2008-03-09 22:14:23.959 Initialised Blowfish server->client encryption
. 2008-03-09 22:14:23.959 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 22:14:23.959 Initialised zlib (RFC1950) decompression
. 2008-03-09 22:24:51.187 Initiating key re-exchange (too much data sent)
. 2008-03-09 22:24:51.202 Doing Diffie-Hellman group exchange
. 2008-03-09 22:24:51.249 Doing Diffie-Hellman key exchange
. 2008-03-09 22:24:51.327 Initialised Blowfish client->server encryption
. 2008-03-09 22:24:51.327 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 22:24:51.327 Initialised zlib (RFC1950) compression
. 2008-03-09 22:24:51.374 Initialised Blowfish server->client encryption
. 2008-03-09 22:24:51.374 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 22:24:51.374 Initialised zlib (RFC1950) decompression
. 2008-03-09 22:35:40.745 Initiating key re-exchange (too much data sent)
. 2008-03-09 22:35:40.745 Doing Diffie-Hellman group exchange
. 2008-03-09 22:35:40.761 Doing Diffie-Hellman key exchange
. 2008-03-09 22:35:40.839 Initialised Blowfish client->server encryption
. 2008-03-09 22:35:40.839 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 22:35:40.839 Initialised zlib (RFC1950) compression
. 2008-03-09 22:35:40.870 Initialised Blowfish server->client encryption
. 2008-03-09 22:35:40.870 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 22:35:40.870 Initialised zlib (RFC1950) decompression
. 2008-03-09 22:45:09.706 Initiating key re-exchange (too much data sent)
. 2008-03-09 22:45:09.706 Doing Diffie-Hellman group exchange
. 2008-03-09 22:45:09.753 Doing Diffie-Hellman key exchange
. 2008-03-09 22:45:09.831 Initialised Blowfish client->server encryption
. 2008-03-09 22:45:09.831 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 22:45:09.831 Initialised zlib (RFC1950) compression
. 2008-03-09 22:45:09.878 Initialised Blowfish server->client encryption
. 2008-03-09 22:45:09.878 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 22:45:09.878 Initialised zlib (RFC1950) decompression
. 2008-03-09 22:54:57.762 Initiating key re-exchange (too much data sent)
. 2008-03-09 22:54:57.762 Doing Diffie-Hellman group exchange
. 2008-03-09 22:54:57.809 Doing Diffie-Hellman key exchange
. 2008-03-09 22:54:57.887 Initialised Blowfish client->server encryption
. 2008-03-09 22:54:57.887 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 22:54:57.887 Initialised zlib (RFC1950) compression
. 2008-03-09 22:54:57.918 Initialised Blowfish server->client encryption
. 2008-03-09 22:54:57.918 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 22:54:57.918 Initialised zlib (RFC1950) decompression
. 2008-03-09 23:05:14.050 Initiating key re-exchange (too much data sent)
. 2008-03-09 23:05:14.082 Doing Diffie-Hellman group exchange
. 2008-03-09 23:05:14.097 Doing Diffie-Hellman key exchange
. 2008-03-09 23:05:14.160 Initialised Blowfish client->server encryption
. 2008-03-09 23:05:14.160 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 23:05:14.160 Initialised zlib (RFC1950) compression
. 2008-03-09 23:05:14.222 Initialised Blowfish server->client encryption
. 2008-03-09 23:05:14.222 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 23:05:14.222 Initialised zlib (RFC1950) decompression
. 2008-03-09 23:19:31.802 Initiating key re-exchange (too much data sent)
. 2008-03-09 23:19:31.802 Doing Diffie-Hellman group exchange
. 2008-03-09 23:19:31.849 Doing Diffie-Hellman key exchange
. 2008-03-09 23:19:31.927 Initialised Blowfish client->server encryption
. 2008-03-09 23:19:31.927 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 23:19:31.927 Initialised zlib (RFC1950) compression
. 2008-03-09 23:19:31.943 Initialised Blowfish server->client encryption
. 2008-03-09 23:19:31.943 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 23:19:31.943 Initialised zlib (RFC1950) decompression
. 2008-03-09 23:31:08.235 Initiating key re-exchange (too much data sent)
. 2008-03-09 23:31:08.282 Doing Diffie-Hellman group exchange
. 2008-03-09 23:31:08.282 Doing Diffie-Hellman key exchange
. 2008-03-09 23:31:08.360 Initialised Blowfish client->server encryption
. 2008-03-09 23:31:08.360 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 23:31:08.360 Initialised zlib (RFC1950) compression
. 2008-03-09 23:31:08.391 Initialised Blowfish server->client encryption
. 2008-03-09 23:31:08.391 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 23:31:08.391 Initialised zlib (RFC1950) decompression
. 2008-03-09 23:41:55.697 Initiating key re-exchange (too much data sent)
. 2008-03-09 23:41:55.713 Doing Diffie-Hellman group exchange
. 2008-03-09 23:41:55.713 Doing Diffie-Hellman key exchange
. 2008-03-09 23:41:55.791 Initialised Blowfish client->server encryption
. 2008-03-09 23:41:55.791 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 23:41:55.791 Initialised zlib (RFC1950) compression
. 2008-03-09 23:41:55.807 Initialised Blowfish server->client encryption
. 2008-03-09 23:41:55.807 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 23:41:55.807 Initialised zlib (RFC1950) decompression
. 2008-03-09 23:53:39.662 Initiating key re-exchange (too much data sent)
. 2008-03-09 23:53:39.662 Doing Diffie-Hellman group exchange
. 2008-03-09 23:53:39.709 Doing Diffie-Hellman key exchange
. 2008-03-09 23:53:39.787 Initialised Blowfish client->server encryption
. 2008-03-09 23:53:39.787 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-09 23:53:39.787 Initialised zlib (RFC1950) compression
. 2008-03-09 23:53:39.818 Initialised Blowfish server->client encryption
. 2008-03-09 23:53:39.818 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-09 23:53:39.818 Initialised zlib (RFC1950) decompression
. 2008-03-10 00:04:39.297 Initiating key re-exchange (too much data sent)
. 2008-03-10 00:04:39.297 Doing Diffie-Hellman group exchange
. 2008-03-10 00:04:39.297 Doing Diffie-Hellman key exchange
. 2008-03-10 00:04:39.406 Initialised Blowfish client->server encryption
. 2008-03-10 00:04:39.406 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 00:04:39.406 Initialised zlib (RFC1950) compression
. 2008-03-10 00:04:39.437 Initialised Blowfish server->client encryption
. 2008-03-10 00:04:39.437 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 00:04:39.437 Initialised zlib (RFC1950) decompression
. 2008-03-10 00:15:55.619 Initiating key re-exchange (too much data sent)
. 2008-03-10 00:15:55.619 Doing Diffie-Hellman group exchange
. 2008-03-10 00:15:55.666 Doing Diffie-Hellman key exchange
. 2008-03-10 00:15:55.744 Initialised Blowfish client->server encryption
. 2008-03-10 00:15:55.744 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 00:15:55.744 Initialised zlib (RFC1950) compression
. 2008-03-10 00:15:55.776 Initialised Blowfish server->client encryption
. 2008-03-10 00:15:55.776 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 00:15:55.776 Initialised zlib (RFC1950) decompression
. 2008-03-10 00:28:07.616 Initiating key re-exchange (too much data sent)
. 2008-03-10 00:28:07.663 Doing Diffie-Hellman group exchange
. 2008-03-10 00:28:07.663 Doing Diffie-Hellman key exchange
. 2008-03-10 00:28:07.741 Initialised Blowfish client->server encryption
. 2008-03-10 00:28:07.741 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 00:28:07.741 Initialised zlib (RFC1950) compression
. 2008-03-10 00:28:07.773 Initialised Blowfish server->client encryption
. 2008-03-10 00:28:07.773 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 00:28:07.773 Initialised zlib (RFC1950) decompression
. 2008-03-10 00:39:32.908 Initiating key re-exchange (too much data sent)
. 2008-03-10 00:39:32.908 Doing Diffie-Hellman group exchange
. 2008-03-10 00:39:32.955 Doing Diffie-Hellman key exchange
. 2008-03-10 00:39:33.033 Initialised Blowfish client->server encryption
. 2008-03-10 00:39:33.033 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 00:39:33.033 Initialised zlib (RFC1950) compression
. 2008-03-10 00:39:33.064 Initialised Blowfish server->client encryption
. 2008-03-10 00:39:33.064 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 00:39:33.064 Initialised zlib (RFC1950) decompression
. 2008-03-10 00:50:30.668 Initiating key re-exchange (too much data sent)
. 2008-03-10 00:50:30.668 Doing Diffie-Hellman group exchange
. 2008-03-10 00:50:30.715 Doing Diffie-Hellman key exchange
. 2008-03-10 00:50:30.793 Initialised Blowfish client->server encryption
. 2008-03-10 00:50:30.793 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 00:50:30.793 Initialised zlib (RFC1950) compression
. 2008-03-10 00:50:30.840 Initialised Blowfish server->client encryption
. 2008-03-10 00:50:30.840 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 00:50:30.840 Initialised zlib (RFC1950) decompression
. 2008-03-10 01:06:30.767 Initiating key re-exchange (too much data sent)
. 2008-03-10 01:06:30.798 Doing Diffie-Hellman group exchange
. 2008-03-10 01:06:30.814 Doing Diffie-Hellman key exchange
. 2008-03-10 01:06:30.892 Initialised Blowfish client->server encryption
. 2008-03-10 01:06:30.892 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 01:06:30.892 Initialised zlib (RFC1950) compression
. 2008-03-10 01:06:30.908 Initialised Blowfish server->client encryption
. 2008-03-10 01:06:30.908 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 01:06:30.908 Initialised zlib (RFC1950) decompression
. 2008-03-10 01:20:54.988 Initiating key re-exchange (too much data sent)
. 2008-03-10 01:20:54.988 Doing Diffie-Hellman group exchange
. 2008-03-10 01:20:55.004 Doing Diffie-Hellman key exchange
. 2008-03-10 01:20:55.082 Initialised Blowfish client->server encryption
. 2008-03-10 01:20:55.082 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 01:20:55.082 Initialised zlib (RFC1950) compression
. 2008-03-10 01:20:55.097 Initialised Blowfish server->client encryption
. 2008-03-10 01:20:55.097 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 01:20:55.097 Initialised zlib (RFC1950) decompression
. 2008-03-10 01:32:37.452 Initiating key re-exchange (too much data sent)
. 2008-03-10 01:32:37.499 Doing Diffie-Hellman group exchange
. 2008-03-10 01:32:37.499 Doing Diffie-Hellman key exchange
. 2008-03-10 01:32:37.577 Initialised Blowfish client->server encryption
. 2008-03-10 01:32:37.577 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 01:32:37.577 Initialised zlib (RFC1950) compression
. 2008-03-10 01:32:37.609 Initialised Blowfish server->client encryption
. 2008-03-10 01:32:37.609 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 01:32:37.609 Initialised zlib (RFC1950) decompression
. 2008-03-10 01:42:14.053 Initiating key re-exchange (too much data sent)
. 2008-03-10 01:42:14.053 Doing Diffie-Hellman group exchange
. 2008-03-10 01:42:14.100 Doing Diffie-Hellman key exchange
. 2008-03-10 01:42:14.178 Initialised Blowfish client->server encryption
. 2008-03-10 01:42:14.178 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 01:42:14.178 Initialised zlib (RFC1950) compression
. 2008-03-10 01:42:14.209 Initialised Blowfish server->client encryption
. 2008-03-10 01:42:14.209 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 01:42:14.209 Initialised zlib (RFC1950) decompression
. 2008-03-10 01:53:54.376 Initiating key re-exchange (too much data sent)
. 2008-03-10 01:53:54.423 Doing Diffie-Hellman group exchange
. 2008-03-10 01:53:54.423 Doing Diffie-Hellman key exchange
. 2008-03-10 01:53:54.501 Initialised Blowfish client->server en
gotdoxies
The log appears to have been to long and was truncated. Is there a way to put up a text file? -Tom
You have posted a log for number of sessions. I believe that if you post a log of single session, it would fit into the limit.
gotdoxies
Oh, I'm sorry. I have the script repeat several times until it gets an exit errorlevel of zero (0). Here's just the last session. As you can see, all the internal "Status error/code"s are zero (0), but the exit errorlevel is one (1):
. 2008-03-10 01:53:54.501 Initialised Blowfish client->server encryption
. 2008-03-10 01:53:54.501 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 01:53:54.501 Initialised zlib (RFC1950) compression
. 2008-03-10 01:53:54.533 Initialised Blowfish server->client encryption
. 2008-03-10 01:53:54.533 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 01:53:54.533 Initialised zlib (RFC1950) decompression
. 2008-03-10 02:03:37.289 Initiating key re-exchange (too much data sent)
. 2008-03-10 02:03:37.289 Doing Diffie-Hellman group exchange
. 2008-03-10 02:03:37.336 Doing Diffie-Hellman key exchange
. 2008-03-10 02:03:37.414 Initialised Blowfish client->server encryption
. 2008-03-10 02:03:37.414 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 02:03:37.414 Initialised zlib (RFC1950) compression
. 2008-03-10 02:03:37.446 Initialised Blowfish server->client encryption
. 2008-03-10 02:03:37.446 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 02:03:37.446 Initialised zlib (RFC1950) decompression
. 2008-03-10 02:13:15.249 Initiating key re-exchange (too much data sent)
. 2008-03-10 02:13:15.265 Doing Diffie-Hellman group exchange
. 2008-03-10 02:13:15.265 Doing Diffie-Hellman key exchange
. 2008-03-10 02:13:15.343 Initialised Blowfish client->server encryption
. 2008-03-10 02:13:15.343 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 02:13:15.343 Initialised zlib (RFC1950) compression
. 2008-03-10 02:13:15.374 Initialised Blowfish server->client encryption
. 2008-03-10 02:13:15.374 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 02:13:15.374 Initialised zlib (RFC1950) decompression
. 2008-03-10 02:24:31.556 Initiating key re-exchange (too much data sent)
. 2008-03-10 02:24:31.556 Doing Diffie-Hellman group exchange
. 2008-03-10 02:24:31.588 Doing Diffie-Hellman key exchange
. 2008-03-10 02:24:31.666 Initialised Blowfish client->server encryption
. 2008-03-10 02:24:31.666 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 02:24:31.666 Initialised zlib (RFC1950) compression
. 2008-03-10 02:24:31.713 Initialised Blowfish server->client encryption
. 2008-03-10 02:24:31.713 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 02:24:31.713 Initialised zlib (RFC1950) decompression
. 2008-03-10 02:35:11.597 Initiating key re-exchange (too much data sent)
. 2008-03-10 02:35:11.643 Doing Diffie-Hellman group exchange
. 2008-03-10 02:35:11.643 Doing Diffie-Hellman key exchange
. 2008-03-10 02:35:11.722 Initialised Blowfish client->server encryption
. 2008-03-10 02:35:11.722 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 02:35:11.722 Initialised zlib (RFC1950) compression
. 2008-03-10 02:35:11.768 Initialised Blowfish server->client encryption
. 2008-03-10 02:35:11.768 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 02:35:11.768 Initialised zlib (RFC1950) decompression
. 2008-03-10 02:45:41.386 Initiating key re-exchange (too much data sent)
. 2008-03-10 02:45:41.386 Doing Diffie-Hellman group exchange
. 2008-03-10 02:45:41.433 Doing Diffie-Hellman key exchange
. 2008-03-10 02:45:41.511 Initialised Blowfish client->server encryption
. 2008-03-10 02:45:41.511 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 02:45:41.511 Initialised zlib (RFC1950) compression
. 2008-03-10 02:45:41.543 Initialised Blowfish server->client encryption
. 2008-03-10 02:45:41.543 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 02:45:41.543 Initialised zlib (RFC1950) decompression
. 2008-03-10 02:56:14.645 Initiating key re-exchange (too much data sent)
. 2008-03-10 02:56:14.661 Doing Diffie-Hellman group exchange
. 2008-03-10 02:56:14.692 Doing Diffie-Hellman key exchange
. 2008-03-10 02:56:14.770 Initialised Blowfish client->server encryption
. 2008-03-10 02:56:14.770 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 02:56:14.770 Initialised zlib (RFC1950) compression
. 2008-03-10 02:56:14.817 Initialised Blowfish server->client encryption
. 2008-03-10 02:56:14.817 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 02:56:14.817 Initialised zlib (RFC1950) decompression
. 2008-03-10 03:07:32.828 Initiating key re-exchange (too much data sent)
. 2008-03-10 03:07:32.875 Doing Diffie-Hellman group exchange
. 2008-03-10 03:07:32.875 Doing Diffie-Hellman key exchange
. 2008-03-10 03:07:32.953 Initialised Blowfish client->server encryption
. 2008-03-10 03:07:32.953 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 03:07:32.953 Initialised zlib (RFC1950) compression
. 2008-03-10 03:07:33.015 Initialised Blowfish server->client encryption
. 2008-03-10 03:07:33.015 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 03:07:33.015 Initialised zlib (RFC1950) decompression
. 2008-03-10 03:21:01.201 Initiating key re-exchange (too much data sent)
. 2008-03-10 03:21:01.248 Doing Diffie-Hellman group exchange
. 2008-03-10 03:21:01.248 Doing Diffie-Hellman key exchange
. 2008-03-10 03:21:01.326 Initialised Blowfish client->server encryption
. 2008-03-10 03:21:01.326 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 03:21:01.326 Initialised zlib (RFC1950) compression
. 2008-03-10 03:21:01.342 Initialised Blowfish server->client encryption
. 2008-03-10 03:21:01.342 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 03:21:01.342 Initialised zlib (RFC1950) decompression
. 2008-03-10 03:33:51.637 Initiating key re-exchange (too much data sent)
. 2008-03-10 03:33:51.653 Doing Diffie-Hellman group exchange
. 2008-03-10 03:33:51.653 Doing Diffie-Hellman key exchange
. 2008-03-10 03:33:51.731 Initialised Blowfish client->server encryption
. 2008-03-10 03:33:51.731 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 03:33:51.731 Initialised zlib (RFC1950) compression
. 2008-03-10 03:33:51.778 Initialised Blowfish server->client encryption
. 2008-03-10 03:33:51.778 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 03:33:51.778 Initialised zlib (RFC1950) decompression
. 2008-03-10 03:47:06.136 Initiating key re-exchange (too much data sent)
. 2008-03-10 03:47:06.182 Doing Diffie-Hellman group exchange
. 2008-03-10 03:47:06.182 Doing Diffie-Hellman key exchange
. 2008-03-10 03:47:06.261 Initialised Blowfish client->server encryption
. 2008-03-10 03:47:06.261 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 03:47:06.261 Initialised zlib (RFC1950) compression
. 2008-03-10 03:47:06.308 Initialised Blowfish server->client encryption
. 2008-03-10 03:47:06.308 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 03:47:06.308 Initialised zlib (RFC1950) decompression
. 2008-03-10 03:56:48.845 Initiating key re-exchange (too much data sent)
. 2008-03-10 03:56:48.877 Doing Diffie-Hellman group exchange
. 2008-03-10 03:56:48.892 Doing Diffie-Hellman key exchange
. 2008-03-10 03:56:48.971 Initialised Blowfish client->server encryption
. 2008-03-10 03:56:48.971 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 03:56:48.971 Initialised zlib (RFC1950) compression
. 2008-03-10 03:56:49.002 Initialised Blowfish server->client encryption
. 2008-03-10 03:56:49.002 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 03:56:49.002 Initialised zlib (RFC1950) decompression
. 2008-03-10 04:06:35.009 Initiating key re-exchange (too much data sent)
. 2008-03-10 04:06:35.056 Doing Diffie-Hellman group exchange
. 2008-03-10 04:06:35.056 Doing Diffie-Hellman key exchange
. 2008-03-10 04:06:35.134 Initialised Blowfish client->server encryption
. 2008-03-10 04:06:35.134 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 04:06:35.134 Initialised zlib (RFC1950) compression
. 2008-03-10 04:06:35.181 Initialised Blowfish server->client encryption
. 2008-03-10 04:06:35.181 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 04:06:35.181 Initialised zlib (RFC1950) decompression
. 2008-03-10 04:16:13.343 Initiating key re-exchange (too much data sent)
. 2008-03-10 04:16:13.390 Doing Diffie-Hellman group exchange
. 2008-03-10 04:16:13.390 Doing Diffie-Hellman key exchange
. 2008-03-10 04:16:13.468 Initialised Blowfish client->server encryption
. 2008-03-10 04:16:13.468 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 04:16:13.468 Initialised zlib (RFC1950) compression
. 2008-03-10 04:16:13.500 Initialised Blowfish server->client encryption
. 2008-03-10 04:16:13.500 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 04:16:13.500 Initialised zlib (RFC1950) decompression
. 2008-03-10 04:26:07.007 Initiating key re-exchange (too much data sent)
. 2008-03-10 04:26:07.007 Doing Diffie-Hellman group exchange
. 2008-03-10 04:26:07.054 Doing Diffie-Hellman key exchange
. 2008-03-10 04:26:07.116 Initialised Blowfish client->server encryption
. 2008-03-10 04:26:07.116 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 04:26:07.116 Initialised zlib (RFC1950) compression
. 2008-03-10 04:26:07.163 Initialised Blowfish server->client encryption
. 2008-03-10 04:26:07.163 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 04:26:07.163 Initialised zlib (RFC1950) decompression
. 2008-03-10 04:36:31.234 Initiating key re-exchange (too much data sent)
. 2008-03-10 04:36:31.437 Doing Diffie-Hellman group exchange
. 2008-03-10 04:36:31.437 Doing Diffie-Hellman key exchange
. 2008-03-10 04:36:31.515 Initialised Blowfish client->server encryption
. 2008-03-10 04:36:31.515 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 04:36:31.515 Initialised zlib (RFC1950) compression
. 2008-03-10 04:36:31.562 Initialised Blowfish server->client encryption
. 2008-03-10 04:36:31.562 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 04:36:31.562 Initialised zlib (RFC1950) decompression
. 2008-03-10 04:46:55.602 Initiating key re-exchange (too much data sent)
. 2008-03-10 04:46:55.602 Doing Diffie-Hellman group exchange
. 2008-03-10 04:46:55.648 Doing Diffie-Hellman key exchange
. 2008-03-10 04:46:55.727 Initialised Blowfish client->server encryption
. 2008-03-10 04:46:55.727 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 04:46:55.727 Initialised zlib (RFC1950) compression
. 2008-03-10 04:46:55.773 Initialised Blowfish server->client encryption
. 2008-03-10 04:46:55.773 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 04:46:55.773 Initialised zlib (RFC1950) decompression
. 2008-03-10 04:56:27.389 Initiating key re-exchange (too much data sent)
. 2008-03-10 04:56:27.420 Doing Diffie-Hellman group exchange
. 2008-03-10 04:56:27.436 Doing Diffie-Hellman key exchange
. 2008-03-10 04:56:27.514 Initialised Blowfish client->server encryption
. 2008-03-10 04:56:27.514 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 04:56:27.514 Initialised zlib (RFC1950) compression
. 2008-03-10 04:56:27.561 Initialised Blowfish server->client encryption
. 2008-03-10 04:56:27.561 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 04:56:27.561 Initialised zlib (RFC1950) decompression
. 2008-03-10 05:07:02.851 Initiating key re-exchange (too much data sent)
. 2008-03-10 05:07:02.898 Doing Diffie-Hellman group exchange
. 2008-03-10 05:07:02.898 Doing Diffie-Hellman key exchange
. 2008-03-10 05:07:02.976 Initialised Blowfish client->server encryption
. 2008-03-10 05:07:02.976 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 05:07:02.976 Initialised zlib (RFC1950) compression
. 2008-03-10 05:07:03.023 Initialised Blowfish server->client encryption
. 2008-03-10 05:07:03.023 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 05:07:03.023 Initialised zlib (RFC1950) decompression
. 2008-03-10 05:18:34.174 Initiating key re-exchange (too much data sent)
. 2008-03-10 05:18:34.221 Doing Diffie-Hellman group exchange
. 2008-03-10 05:18:34.221 Doing Diffie-Hellman key exchange
. 2008-03-10 05:18:34.299 Initialised Blowfish client->server encryption
. 2008-03-10 05:18:34.299 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 05:18:34.299 Initialised zlib (RFC1950) compression
. 2008-03-10 05:18:34.346 Initialised Blowfish server->client encryption
. 2008-03-10 05:18:34.346 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 05:18:34.346 Initialised zlib (RFC1950) decompression
. 2008-03-10 05:31:47.705 Initiating key re-exchange (too much data sent)
. 2008-03-10 05:31:47.752 Doing Diffie-Hellman group exchange
. 2008-03-10 05:31:47.752 Doing Diffie-Hellman key exchange
. 2008-03-10 05:31:47.830 Initialised Blowfish client->server encryption
. 2008-03-10 05:31:47.830 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 05:31:47.830 Initialised zlib (RFC1950) compression
. 2008-03-10 05:31:47.877 Initialised Blowfish server->client encryption
. 2008-03-10 05:31:47.877 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 05:31:47.877 Initialised zlib (RFC1950) decompression
. 2008-03-10 05:45:36.565 Initiating key re-exchange (too much data sent)
. 2008-03-10 05:45:36.612 Doing Diffie-Hellman group exchange
. 2008-03-10 05:45:36.612 Doing Diffie-Hellman key exchange
. 2008-03-10 05:45:36.690 Initialised Blowfish client->server encryption
. 2008-03-10 05:45:36.690 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 05:45:36.690 Initialised zlib (RFC1950) compression
. 2008-03-10 05:45:36.721 Initialised Blowfish server->client encryption
. 2008-03-10 05:45:36.721 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 05:45:36.721 Initialised zlib (RFC1950) decompression
. 2008-03-10 05:56:05.542 Initiating key re-exchange (too much data sent)
. 2008-03-10 05:56:05.542 Doing Diffie-Hellman group exchange
. 2008-03-10 05:56:05.589 Doing Diffie-Hellman key exchange
. 2008-03-10 05:56:05.667 Initialised Blowfish client->server encryption
. 2008-03-10 05:56:05.667 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 05:56:05.667 Initialised zlib (RFC1950) compression
. 2008-03-10 05:56:05.714 Initialised Blowfish server->client encryption
. 2008-03-10 05:56:05.714 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 05:56:05.714 Initialised zlib (RFC1950) decompression
. 2008-03-10 06:10:58.748 Initiating key re-exchange (too much data sent)
. 2008-03-10 06:10:58.748 Doing Diffie-Hellman group exchange
. 2008-03-10 06:10:58.748 Doing Diffie-Hellman key exchange
. 2008-03-10 06:10:58.842 Initialised Blowfish client->server encryption
. 2008-03-10 06:10:58.842 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 06:10:58.842 Initialised zlib (RFC1950) compression
. 2008-03-10 06:10:58.905 Initialised Blowfish server->client encryption
. 2008-03-10 06:10:58.905 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 06:10:58.905 Initialised zlib (RFC1950) decompression
. 2008-03-10 06:28:51.930 Initiating key re-exchange (too much data sent)
. 2008-03-10 06:28:51.930 Doing Diffie-Hellman group exchange
. 2008-03-10 06:28:51.946 Doing Diffie-Hellman key exchange
. 2008-03-10 06:28:52.024 Initialised Blowfish client->server encryption
. 2008-03-10 06:28:52.024 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 06:28:52.024 Initialised zlib (RFC1950) compression
. 2008-03-10 06:28:52.071 Initialised Blowfish server->client encryption
. 2008-03-10 06:28:52.071 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 06:28:52.071 Initialised zlib (RFC1950) decompression
. 2008-03-10 06:46:56.722 Initiating key re-exchange (too much data sent)
. 2008-03-10 06:46:56.769 Doing Diffie-Hellman group exchange
. 2008-03-10 06:46:56.769 Doing Diffie-Hellman key exchange
. 2008-03-10 06:46:56.862 Initialised Blowfish client->server encryption
. 2008-03-10 06:46:56.862 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 06:46:56.862 Initialised zlib (RFC1950) compression
. 2008-03-10 06:46:56.956 Initialised Blowfish server->client encryption
. 2008-03-10 06:46:56.956 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 06:46:56.956 Initialised zlib (RFC1950) decompression
. 2008-03-10 07:07:00.815 Initiating key re-exchange (too much data sent)
. 2008-03-10 07:07:00.862 Doing Diffie-Hellman group exchange
. 2008-03-10 07:07:00.862 Doing Diffie-Hellman key exchange
. 2008-03-10 07:07:00.956 Initialised Blowfish client->server encryption
. 2008-03-10 07:07:00.956 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 07:07:00.956 Initialised zlib (RFC1950) compression
. 2008-03-10 07:07:01.049 Initialised Blowfish server->client encryption
. 2008-03-10 07:07:01.049 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 07:07:01.049 Initialised zlib (RFC1950) decompression
. 2008-03-10 07:23:58.948 Initiating key re-exchange (too much data sent)
. 2008-03-10 07:23:58.995 Doing Diffie-Hellman group exchange
. 2008-03-10 07:23:58.995 Doing Diffie-Hellman key exchange
. 2008-03-10 07:23:59.088 Initialised Blowfish client->server encryption
. 2008-03-10 07:23:59.088 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 07:23:59.088 Initialised zlib (RFC1950) compression
. 2008-03-10 07:23:59.151 Initialised Blowfish server->client encryption
. 2008-03-10 07:23:59.151 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 07:23:59.151 Initialised zlib (RFC1950) decompression
. 2008-03-10 07:41:20.189 Initiating key re-exchange (too much data sent)
. 2008-03-10 07:41:20.189 Doing Diffie-Hellman group exchange
. 2008-03-10 07:41:20.189 Doing Diffie-Hellman key exchange
. 2008-03-10 07:41:20.283 Initialised Blowfish client->server encryption
. 2008-03-10 07:41:20.283 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 07:41:20.283 Initialised zlib (RFC1950) compression
. 2008-03-10 07:41:20.377 Initialised Blowfish server->client encryption
. 2008-03-10 07:41:20.377 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 07:41:20.377 Initialised zlib (RFC1950) decompression
. 2008-03-10 08:04:16.504 Initiating key re-exchange (too much data sent)
. 2008-03-10 08:04:16.504 Doing Diffie-Hellman group exchange
. 2008-03-10 08:04:16.504 Doing Diffie-Hellman key exchange
. 2008-03-10 08:04:16.582 Initialised Blowfish client->server encryption
. 2008-03-10 08:04:16.582 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 08:04:16.582 Initialised zlib (RFC1950) compression
. 2008-03-10 08:04:16.644 Initialised Blowfish server->client encryption
. 2008-03-10 08:04:16.644 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 08:04:16.644 Initialised zlib (RFC1950) decompression
. 2008-03-10 08:25:31.613 Initiating key re-exchange (too much data sent)
. 2008-03-10 08:25:31.644 Doing Diffie-Hellman group exchange
. 2008-03-10 08:25:31.676 Doing Diffie-Hellman key exchange
. 2008-03-10 08:25:31.754 Initialised Blowfish client->server encryption
. 2008-03-10 08:25:31.754 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 08:25:31.754 Initialised zlib (RFC1950) compression
. 2008-03-10 08:25:31.785 Initialised Blowfish server->client encryption
. 2008-03-10 08:25:31.785 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 08:25:31.785 Initialised zlib (RFC1950) decompression
. 2008-03-10 08:37:28.625 Initiating key re-exchange (too much data sent)
. 2008-03-10 08:37:28.672 Doing Diffie-Hellman group exchange
. 2008-03-10 08:37:28.672 Doing Diffie-Hellman key exchange
. 2008-03-10 08:37:28.750 Initialised Blowfish client->server encryption
. 2008-03-10 08:37:28.750 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 08:37:28.750 Initialised zlib (RFC1950) compression
. 2008-03-10 08:37:28.781 Initialised Blowfish server->client encryption
. 2008-03-10 08:37:28.781 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 08:37:28.781 Initialised zlib (RFC1950) decompression
. 2008-03-10 08:48:53.667 Initiating key re-exchange (too much data sent)
. 2008-03-10 08:48:53.698 Doing Diffie-Hellman group exchange
. 2008-03-10 08:48:53.714 Doing Diffie-Hellman key exchange
. 2008-03-10 08:48:53.792 Initialised Blowfish client->server encryption
. 2008-03-10 08:48:53.792 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 08:48:53.792 Initialised zlib (RFC1950) compression
. 2008-03-10 08:48:53.823 Initialised Blowfish server->client encryption
. 2008-03-10 08:48:53.823 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 08:48:53.823 Initialised zlib (RFC1950) decompression
. 2008-03-10 09:00:04.818 Initiating key re-exchange (too much data sent)
. 2008-03-10 09:00:04.818 Doing Diffie-Hellman group exchange
. 2008-03-10 09:00:04.865 Doing Diffie-Hellman key exchange
. 2008-03-10 09:00:04.943 Initialised Blowfish client->server encryption
. 2008-03-10 09:00:04.943 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 09:00:04.943 Initialised zlib (RFC1950) compression
. 2008-03-10 09:00:04.990 Initialised Blowfish server->client encryption
. 2008-03-10 09:00:04.990 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 09:00:04.990 Initialised zlib (RFC1950) decompression
. 2008-03-10 09:18:01.406 Initiating key re-exchange (too much data sent)
. 2008-03-10 09:18:01.453 Doing Diffie-Hellman group exchange
. 2008-03-10 09:18:01.453 Doing Diffie-Hellman key exchange
. 2008-03-10 09:18:01.531 Initialised Blowfish client->server encryption
. 2008-03-10 09:18:01.531 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 09:18:01.531 Initialised zlib (RFC1950) compression
. 2008-03-10 09:18:01.578 Initialised Blowfish server->client encryption
. 2008-03-10 09:18:01.578 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 09:18:01.578 Initialised zlib (RFC1950) decompression
. 2008-03-10 09:32:55.581 Initiating key re-exchange (too much data sent)
. 2008-03-10 09:32:55.581 Doing Diffie-Hellman group exchange
. 2008-03-10 09:32:55.628 Doing Diffie-Hellman key exchange
. 2008-03-10 09:32:55.706 Initialised Blowfish client->server encryption
. 2008-03-10 09:32:55.706 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 09:32:55.706 Initialised zlib (RFC1950) compression
. 2008-03-10 09:32:55.737 Initialised Blowfish server->client encryption
. 2008-03-10 09:32:55.737 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 09:32:55.753 Initialised zlib (RFC1950) decompression
. 2008-03-10 10:07:46.271 Initiating key re-exchange (too much data sent)
. 2008-03-10 10:07:46.318 Doing Diffie-Hellman group exchange
. 2008-03-10 10:07:46.318 Doing Diffie-Hellman key exchange
. 2008-03-10 10:07:46.396 Initialised Blowfish client->server encryption
. 2008-03-10 10:07:46.396 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 10:07:46.396 Initialised zlib (RFC1950) compression
. 2008-03-10 10:07:46.411 Initialised Blowfish server->client encryption
. 2008-03-10 10:07:46.411 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 10:07:46.411 Initialised zlib (RFC1950) decompression
. 2008-03-10 10:20:11.143 Initiating key re-exchange (too much data sent)
. 2008-03-10 10:20:11.143 Doing Diffie-Hellman group exchange
. 2008-03-10 10:20:11.190 Doing Diffie-Hellman key exchange
. 2008-03-10 10:20:11.268 Initialised Blowfish client->server encryption
. 2008-03-10 10:20:11.268 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 10:20:11.268 Initialised zlib (RFC1950) compression
. 2008-03-10 10:20:11.315 Initialised Blowfish server->client encryption
. 2008-03-10 10:20:11.315 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 10:20:11.315 Initialised zlib (RFC1950) decompression
. 2008-03-10 10:31:33.482 Initiating key re-exchange (too much data sent)
. 2008-03-10 10:31:33.497 Doing Diffie-Hellman group exchange
. 2008-03-10 10:31:33.529 Doing Diffie-Hellman key exchange
. 2008-03-10 10:31:33.607 Initialised Blowfish client->server encryption
. 2008-03-10 10:31:33.607 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 10:31:33.607 Initialised zlib (RFC1950) compression
. 2008-03-10 10:31:33.638 Initialised Blowfish server->client encryption
. 2008-03-10 10:31:33.638 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 10:31:33.638 Initialised zlib (RFC1950) decompression
. 2008-03-10 10:42:23.397 Initiating key re-exchange (too much data sent)
. 2008-03-10 10:42:23.413 Doing Diffie-Hellman group exchange
. 2008-03-10 10:42:23.444 Doing Diffie-Hellman key exchange
. 2008-03-10 10:42:23.522 Initialised Blowfish client->server encryption
. 2008-03-10 10:42:23.522 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 10:42:23.522 Initialised zlib (RFC1950) compression
. 2008-03-10 10:42:23.554 Initialised Blowfish server->client encryption
. 2008-03-10 10:42:23.554 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 10:42:23.554 Initialised zlib (RFC1950) decompression
. 2008-03-10 10:54:04.424 Initiating key re-exchange (too much data sent)
. 2008-03-10 10:54:04.471 Doing Diffie-Hellman group exchange
. 2008-03-10 10:54:04.471 Doing Diffie-Hellman key exchange
. 2008-03-10 10:54:04.549 Initialised Blowfish client->server encryption
. 2008-03-10 10:54:04.549 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 10:54:04.549 Initialised zlib (RFC1950) compression
. 2008-03-10 10:54:04.596 Initialised Blowfish server->client encryption
. 2008-03-10 10:54:04.596 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 10:54:04.596 Initialised zlib (RFC1950) decompression
. 2008-03-10 11:03:56.259 Initiating key re-exchange (too much data sent)
. 2008-03-10 11:03:56.259 Doing Diffie-Hellman group exchange
. 2008-03-10 11:03:56.306 Doing Diffie-Hellman key exchange
. 2008-03-10 11:03:56.384 Initialised Blowfish client->server encryption
. 2008-03-10 11:03:56.384 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 11:03:56.384 Initialised zlib (RFC1950) compression
. 2008-03-10 11:03:56.416 Initialised Blowfish server->client encryption
. 2008-03-10 11:03:56.416 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 11:03:56.416 Initialised zlib (RFC1950) decompression
. 2008-03-10 11:15:55.990 Initiating key re-exchange (too much data sent)
. 2008-03-10 11:15:55.990 Doing Diffie-Hellman group exchange
. 2008-03-10 11:15:56.037 Doing Diffie-Hellman key exchange
. 2008-03-10 11:15:56.115 Initialised Blowfish client->server encryption
. 2008-03-10 11:15:56.115 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 11:15:56.115 Initialised zlib (RFC1950) compression
. 2008-03-10 11:15:56.162 Initialised Blowfish server->client encryption
. 2008-03-10 11:15:56.162 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 11:15:56.162 Initialised zlib (RFC1950) decompression
. 2008-03-10 11:28:12.237 Initiating key re-exchange (too much data sent)
. 2008-03-10 11:28:12.237 Doing Diffie-Hellman group exchange
. 2008-03-10 11:28:12.284 Doing Diffie-Hellman key exchange
. 2008-03-10 11:28:12.362 Initialised Blowfish client->server encryption
. 2008-03-10 11:28:12.362 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 11:28:12.362 Initialised zlib (RFC1950) compression
. 2008-03-10 11:28:12.409 Initialised Blowfish server->client encryption
. 2008-03-10 11:28:12.409 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 11:28:12.409 Initialised zlib (RFC1950) decompression
. 2008-03-10 11:37:57.525 Initiating key re-exchange (too much data sent)
. 2008-03-10 11:37:57.572 Doing Diffie-Hellman group exchange
. 2008-03-10 11:37:57.572 Doing Diffie-Hellman key exchange
. 2008-03-10 11:37:57.650 Initialised Blowfish client->server encryption
. 2008-03-10 11:37:57.650 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 11:37:57.650 Initialised zlib (RFC1950) compression
. 2008-03-10 11:37:57.697 Initialised Blowfish server->client encryption
. 2008-03-10 11:37:57.697 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 11:37:57.697 Initialised zlib (RFC1950) decompression
. 2008-03-10 11:49:08.489 Initiating key re-exchange (too much data sent)
. 2008-03-10 11:49:08.489 Doing Diffie-Hellman group exchange
. 2008-03-10 11:49:08.504 Doing Diffie-Hellman key exchange
. 2008-03-10 11:49:08.582 Initialised Blowfish client->server encryption
. 2008-03-10 11:49:08.582 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 11:49:08.582 Initialised zlib (RFC1950) compression
. 2008-03-10 11:49:08.660 Initialised Blowfish server->client encryption
. 2008-03-10 11:49:08.660 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 11:49:08.660 Initialised zlib (RFC1950) decompression
. 2008-03-10 12:00:25.061 Initiating key re-exchange (too much data sent)
. 2008-03-10 12:00:25.093 Doing Diffie-Hellman group exchange
. 2008-03-10 12:00:25.093 Doing Diffie-Hellman key exchange
. 2008-03-10 12:00:25.171 Initialised Blowfish client->server encryption
. 2008-03-10 12:00:25.171 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 12:00:25.171 Initialised zlib (RFC1950) compression
. 2008-03-10 12:00:25.218 Initialised Blowfish server->client encryption
. 2008-03-10 12:00:25.218 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 12:00:25.218 Initialised zlib (RFC1950) decompression
. 2008-03-10 12:11:07.133 Initiating key re-exchange (too much data sent)
. 2008-03-10 12:11:07.164 Doing Diffie-Hellman group exchange
. 2008-03-10 12:11:07.164 Doing Diffie-Hellman key exchange
. 2008-03-10 12:11:07.242 Initialised Blowfish client->server encryption
. 2008-03-10 12:11:07.242 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 12:11:07.242 Initialised zlib (RFC1950) compression
. 2008-03-10 12:11:07.289 Initialised Blowfish server->client encryption
. 2008-03-10 12:11:07.289 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 12:11:07.289 Initialised zlib (RFC1950) decompression
. 2008-03-10 12:22:03.106 Initiating key re-exchange (too much data sent)
. 2008-03-10 12:22:03.106 Doing Diffie-Hellman group exchange
. 2008-03-10 12:22:03.122 Doing Diffie-Hellman key exchange
. 2008-03-10 12:22:03.200 Initialised Blowfish client->server encryption
. 2008-03-10 12:22:03.200 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 12:22:03.200 Initialised zlib (RFC1950) compression
. 2008-03-10 12:22:03.231 Initialised Blowfish server->client encryption
. 2008-03-10 12:22:03.231 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 12:22:03.231 Initialised zlib (RFC1950) decompression
. 2008-03-10 12:33:21.154 Initiating key re-exchange (too much data sent)
. 2008-03-10 12:33:21.154 Doing Diffie-Hellman group exchange
. 2008-03-10 12:33:21.170 Doing Diffie-Hellman key exchange
. 2008-03-10 12:33:21.248 Initialised Blowfish client->server encryption
. 2008-03-10 12:33:21.248 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 12:33:21.248 Initialised zlib (RFC1950) compression
. 2008-03-10 12:33:21.279 Initialised Blowfish server->client encryption
. 2008-03-10 12:33:21.279 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 12:33:21.279 Initialised zlib (RFC1950) decompression
. 2008-03-10 12:44:04.924 Initiating key re-exchange (too much data sent)
. 2008-03-10 12:44:04.924 Doing Diffie-Hellman group exchange
. 2008-03-10 12:44:04.971 Doing Diffie-Hellman key exchange
. 2008-03-10 12:44:05.049 Initialised Blowfish client->server encryption
. 2008-03-10 12:44:05.049 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 12:44:05.049 Initialised zlib (RFC1950) compression
. 2008-03-10 12:44:05.080 Initialised Blowfish server->client encryption
. 2008-03-10 12:44:05.080 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 12:44:05.080 Initialised zlib (RFC1950) decompression
. 2008-03-10 12:53:53.728 Initiating key re-exchange (too much data sent)
. 2008-03-10 12:53:53.775 Doing Diffie-Hellman group exchange
. 2008-03-10 12:53:53.775 Doing Diffie-Hellman key exchange
. 2008-03-10 12:53:53.853 Initialised Blowfish client->server encryption
. 2008-03-10 12:53:53.853 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 12:53:53.853 Initialised zlib (RFC1950) compression
. 2008-03-10 12:53:53.900 Initialised Blowfish server->client encryption
. 2008-03-10 12:53:53.900 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 12:53:53.900 Initialised zlib (RFC1950) decompression
. 2008-03-10 13:03:44.579 Initiating key re-exchange (too much data sent)
. 2008-03-10 13:03:44.641 Doing Diffie-Hellman group exchange
. 2008-03-10 13:03:44.641 Doing Diffie-Hellman key exchange
. 2008-03-10 13:03:44.719 Initialised Blowfish client->server encryption
. 2008-03-10 13:03:44.719 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 13:03:44.719 Initialised zlib (RFC1950) compression
. 2008-03-10 13:03:44.766 Initialised Blowfish server->client encryption
. 2008-03-10 13:03:44.766 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 13:03:44.766 Initialised zlib (RFC1950) decompression
. 2008-03-10 13:13:38.149 Initiating key re-exchange (too much data sent)
. 2008-03-10 13:13:38.149 Doing Diffie-Hellman group exchange
. 2008-03-10 13:13:38.195 Doing Diffie-Hellman key exchange
. 2008-03-10 13:13:38.274 Initialised Blowfish client->server encryption
. 2008-03-10 13:13:38.274 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 13:13:38.274 Initialised zlib (RFC1950) compression
. 2008-03-10 13:13:38.305 Initialised Blowfish server->client encryption
. 2008-03-10 13:13:38.305 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 13:13:38.305 Initialised zlib (RFC1950) decompression
. 2008-03-10 13:23:41.812 Initiating key re-exchange (too much data sent)
. 2008-03-10 13:23:41.859 Doing Diffie-Hellman group exchange
. 2008-03-10 13:23:41.859 Doing Diffie-Hellman key exchange
. 2008-03-10 13:23:41.937 Initialised Blowfish client->server encryption
. 2008-03-10 13:23:41.937 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 13:23:41.937 Initialised zlib (RFC1950) compression
. 2008-03-10 13:23:41.984 Initialised Blowfish server->client encryption
. 2008-03-10 13:23:41.984 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 13:23:41.984 Initialised zlib (RFC1950) decompression
. 2008-03-10 13:34:35.384 Initiating key re-exchange (too much data sent)
. 2008-03-10 13:34:35.431 Doing Diffie-Hellman group exchange
. 2008-03-10 13:34:35.431 Doing Diffie-Hellman key exchange
. 2008-03-10 13:34:35.509 Initialised Blowfish client->server encryption
. 2008-03-10 13:34:35.509 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 13:34:35.509 Initialised zlib (RFC1950) compression
. 2008-03-10 13:34:35.541 Initialised Blowfish server->client encryption
. 2008-03-10 13:34:35.541 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 13:34:35.541 Initialised zlib (RFC1950) decompression
. 2008-03-10 13:44:50.705 Initiating key re-exchange (too much data sent)
. 2008-03-10 13:44:50.705 Doing Diffie-Hellman group exchange
. 2008-03-10 13:44:50.752 Doing Diffie-Hellman key exchange
. 2008-03-10 13:44:50.830 Initialised Blowfish client->server encryption
. 2008-03-10 13:44:50.830 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 13:44:50.830 Initialised zlib (RFC1950) compression
. 2008-03-10 13:44:50.861 Initialised Blowfish server->client encryption
. 2008-03-10 13:44:50.861 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 13:44:50.861 Initialised zlib (RFC1950) decompression
. 2008-03-10 13:54:34.118 Initiating key re-exchange (too much data sent)
. 2008-03-10 13:54:34.118 Doing Diffie-Hellman group exchange
. 2008-03-10 13:54:34.149 Doing Diffie-Hellman key exchange
. 2008-03-10 13:54:34.227 Initialised Blowfish client->server encryption
. 2008-03-10 13:54:34.227 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-03-10 13:54:34.227 Initialised zlib (RFC1950) compression
. 2008-03-10 13:54:34.274 Initialised Blowfish server->client encryption
. 2008-03-10 13:54:34.274 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-03-10 13:54:34.274 Initialised zlib (RFC1950) decompression
. 2008-03-10 13:57:35.062 8717705 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-03-10 13:57:35.062 Type: SSH_FXP_CLOSE, Size: 13, Number: 1575551748
> 2008-03-10 13:57:35.062 Type: SSH_FXP_SETSTAT, Size: 113, Number: 459684873
< 2008-03-10 13:57:35.062 Type: SSH_FXP_STATUS, Size: 24, Number: 1575551238
< 2008-03-10 13:57:35.094 Type: SSH_FXP_STATUS, Size: 24, Number: 1575551494
< 2008-03-10 13:57:35.250 Type: SSH_FXP_STATUS, Size: 24, Number: 1575551748
< 2008-03-10 13:57:35.250 Status/error code: 0
< 2008-03-10 13:57:35.469 Type: SSH_FXP_STATUS, Size: 24, Number: 459684873
< 2008-03-10 13:57:35.469 Status/error code: 0
. 2008-03-10 13:57:35.484 Closing connection.
Exited With an Errorlevel of 1
2008-03-10
01:57 PM
Sorry, I still do not see any problem. Can you also post a script file and the batch file your are using to run the script?
