Topic "How can I stop my script from aborting after 15 seconds?"
BobJames
I want my script to keep trying to connect but it is Aborting after 15 seconds? Are there settings that can fix this?
Host has not answered for more than 15 seconds. Still waiting...
Warning: Aborting this operation will close connection!
(A)bort: Abort
Terminated by user.
I'm currently using Option Batch Continue and Option Confirm Off
Since 4.1 you can use -timeout switch with open command.
Stewart Dickson
In version 4.0.0.342 I find some bad behavior if the connection times out.
Past 15 seconds, the "Confirm"/[Abort] dialog ["Host has not answered for more than 15 seconds. Still Waiting... Warning: Aborting this operation will close connection!"] cannot be closed.
The host has answered: The "'user@host.dom' session password:" TextField has appeared in the "Password - user@host.dom" dialog.
However, because the "Confirm"/[Abort] dialog is still posted, you cannot type into the
Password TextField. Now, the "Confirm"/[Abort] dialog will not respond to the [Abort] PushButton and you cannot close the "Confirm"/[Abort] dialog. The application is wedged.
At this point, nothing short of rebooting the system will kill WinSCP. (That I know of.)
I will try upgrading to a more recent version ("Since 4.1" and see if this behavior improves.) Thanks,
-Stewart http://us.imdb.com/Name?Stewart+Dickson
Visualization Research Programmer, Integrated Systems Laboratory http://www.isl.uiuc.edu/~sdickson
4355 Beckman Institute, 405 N Mathews Avenue, Urbana, IL 61801 USA +1(217)333-3923
http://emsh.calarts.edu/~mathart/MathArt_siteMap.html
I hope that this has been fixed in 4.0.6:
Quote:
Bug fix: WinSCP hanged when authentication prompt was displayed while timeout message was shown.
