Topic "Problems with file selection"
Seo
Using norton commander interface I'm unable to unselect elements from local folder pane. This normally be possible clicking away on an empty area as well as on another file.
Actually the only way I got is change folder.
On the same way, if I start dragging to select multiple files, at the end of the selection process no files are selected. The only way is to click on the file I need and eventually use the multiple selection combining mouse action with keyboard (shift or ctrl).
Version used 4.06 and 4.0.7 both in standalone mode.
