Topic "CPU Utilization has sporatic high peaks"
Richard @ GE
Greetings,
I have noticed several ssh and sshd spikes that I believe are associated with WinSCP, either when logging in or during the session.
Is there any way to relax that sporatic activity as there are sensitive applications that are getting clobbered and in some cases broken, causing the CPU to reset
Sorry, there is no such option.
richard.hooker@...
Thank You Prikryl.
Is the reason known for occassional high CPU spikes?
Are you one of the WinSCP developers?
Am I the only one seeing this?
we also see putty logins that create small avi files for the login duration.
I am very interesting in any settings for these tools or one we can purchase that does not have these issues...
Regards,
Richard
dj
Hello everybody,
need help for WinSCP Version 4.04.
I scripted a sFTP connection and trigger it using
commandfile "doit.cmd"( winscp.exe /script=c:\conSAP.txt /log=c:\conSAP.log )
Everything is working fine except the logfile. I would like to
overwrite the logfile, but it appends all connections.
What do I have to do to overwrite, please help, thanks.
regards dj
If it happens in the middle of session (even idle one), it can be caused by key re-exchange. It can be disabled, with potential impact on security.
This can be configured in GUI only. You can also remove the log file from .cmd. If you have further questions, please start new topic.
Thank you for this Information! Although it doesn't realy satisfied me Wink
