Topic ""Invalid access to memory" error (version 4.1.0 Build 375)"
Bar
Since installing latest version (4.1.0 Build 375), every time I login for the first time to any site, an error message pops up stating: "Invalid access to memory". This message repeats three times before actually opening the session. Once logged in, everything runs fine, even opening other sessions.
I'm using Windows XP SP2 and previously had installed version 4.07, which worked flawlessly.
The session log is as follows:
. 2008-04-03 08:09:42.487 --------------------------------------------------------------------------
. 2008-04-03 08:09:42.487 WinSCP Version 4.1.0 (Build 375) (OS 5.1.2600 Service Pack 2)
. 2008-04-03 08:09:42.487 Login time: Thursday, April 03, 2008 8:09:42 AM
. 2008-04-03 08:09:42.487 Session name: 172.18.237.202 (root@cwp-noc-portal)
. 2008-04-03 08:09:42.487 Host name: 172.18.237.202 (Port: 22)
. 2008-04-03 08:09:42.487 User name: root (Password: Yes, Key file: No)
. 2008-04-03 08:09:42.487 Tunnel: No
. 2008-04-03 08:09:42.487 Transfer Protocol: SCP
. 2008-04-03 08:09:42.487 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-04-03 08:09:42.487 Proxy: none
. 2008-04-03 08:09:42.487 SSH protocol version: 2; Compression: No
. 2008-04-03 08:09:42.487 Bypass authentication: No
. 2008-04-03 08:09:42.487 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-04-03 08:09:42.487 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2008-04-03 08:09:42.487 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-04-03 08:09:42.487 SFTP Bugs: -,-
. 2008-04-03 08:09:42.487 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-04-03 08:09:42.487 Shell: default, EOL: 0
. 2008-04-03 08:09:42.487 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-04-03 08:09:42.487 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2008-04-03 08:09:42.487 Local directory: C:\Documents and Settings\RBB05761\Desktop, Remote directory: /root, Update: No, Cache: Yes
. 2008-04-03 08:09:42.487 Cache directory changes: Yes, Permanent: Yes
. 2008-04-03 08:09:42.487 DST mode: 1
. 2008-04-03 08:09:42.565 Looking up host "172.18.237.202"
. 2008-04-03 08:09:42.565 Connecting to 172.18.237.202 port 22
. 2008-04-03 08:09:42.596 Server version: SSH-2.0-OpenSSH_4.3
. 2008-04-03 08:09:42.596 We claim version: SSH-2.0-WinSCP_release_4.1
. 2008-04-03 08:09:42.596 SSPI: acquired credentials for: RBB05761@CWPANAMA.COM
. 2008-04-03 08:09:42.596 Cannot convert IP address to SPN: DNS is not trusted
. 2008-04-03 08:09:42.596 GSSKEX disabled:
. 2008-04-03 08:09:42.596 Using SSH protocol version 2
. 2008-04-03 08:09:42.596 Doing Diffie-Hellman group exchange
. 2008-04-03 08:09:42.643 Doing Diffie-Hellman key exchange with hash SHA-1
. 2008-04-03 08:09:42.940 Host key fingerprint is:
. 2008-04-03 08:09:42.940 ssh-rsa 2048 d7:a7:d3:e2:56:63:ce:80:62:be:bb:73:6f:f9:6f:85
. 2008-04-03 08:09:42.940 Initialised AES-256 SDCTR client->server encryption
. 2008-04-03 08:09:42.940 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-04-03 08:09:42.940 Initialised AES-256 SDCTR server->client encryption
. 2008-04-03 08:09:42.940 Initialised HMAC-SHA1 server->client MAC algorithm
! 2008-04-03 08:09:42.971 Using username "root".
. 2008-04-03 08:09:42.987 Prompt (6, SSH password, , &Password: )
. 2008-04-03 08:09:42.987 Using stored password.
. 2008-04-03 08:09:42.987 Sent password
. 2008-04-03 08:09:43.003 Access granted
. 2008-04-03 08:09:43.003 Opened channel for session
. 2008-04-03 08:09:43.003 Started a shell/command
. 2008-04-03 08:09:43.003 --------------------------------------------------------------------------
. 2008-04-03 08:09:43.003 Using SCP protocol.
. 2008-04-03 08:09:43.003 Doing startup conversation with host.
. 2008-04-03 08:09:43.003 Skipping host startup message (if any).
> 2008-04-03 08:09:43.003 echo "WinSCP: this is end-of-file:0"
< 2008-04-03 08:09:43.081 WinSCP: this is end-of-file:0
. 2008-04-03 08:09:43.081 Detecting variable containing return code of last command.
. 2008-04-03 08:09:43.081 Trying "$status".
> 2008-04-03 08:09:43.081 echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 2008-04-03 08:09:43.237 WinSCP: this is end-of-file:0
. 2008-04-03 08:09:43.237 Trying "$?".
> 2008-04-03 08:09:43.237 echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 2008-04-03 08:09:43.268 0
< 2008-04-03 08:09:43.440 WinSCP: this is end-of-file:0
. 2008-04-03 08:09:43.440 Return code variable "$?" selected.
. 2008-04-03 08:09:43.440 Clearing all aliases.
> 2008-04-03 08:09:43.440 unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:43.471 -bash: line 4: unalias: echo: not found
< 2008-04-03 08:09:43.628 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:43.628 unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:43.675 -bash: line 5: unalias: pwd: not found
< 2008-04-03 08:09:43.831 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:43.831 unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:43.878 -bash: line 6: unalias: cd: not found
< 2008-04-03 08:09:44.034 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:44.034 unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:44.081 -bash: line 7: unalias: groups: not found
< 2008-04-03 08:09:44.237 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:44.237 unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:44.284 -bash: line 8: unalias: scp: not found
< 2008-04-03 08:09:44.440 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:44.440 unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:44.487 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:44.487 unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:44.518 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:44.518 unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:44.565 -bash: line 11: unalias: mkdir: not found
< 2008-04-03 08:09:44.737 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:44.737 unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:44.784 -bash: line 12: unalias: chmod: not found
< 2008-04-03 08:09:44.940 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:44.940 unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:44.987 -bash: line 13: unalias: chgrp: not found
< 2008-04-03 08:09:45.143 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:45.143 unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:45.190 -bash: line 14: unalias: chown: not found
< 2008-04-03 08:09:45.346 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:45.346 unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:45.378 -bash: line 15: unalias: unset: not found
< 2008-04-03 08:09:45.550 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:45.550 unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:45.581 -bash: line 16: unalias: unalias: not found
< 2008-04-03 08:09:45.753 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:45.753 unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
! 2008-04-03 08:09:45.784 -bash: line 17: unalias: ln: not found
< 2008-04-03 08:09:45.956 WinSCP: this is end-of-file:1
> 2008-04-03 08:09:45.956 unalias "cp" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:45.987 WinSCP: this is end-of-file:0
. 2008-04-03 08:09:45.987 Clearing national user variables.
> 2008-04-03 08:09:45.987 unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.034 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:46.034 unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.065 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:46.065 unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.112 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:46.112 unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.143 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:46.143 unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.190 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:46.190 unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.221 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:46.221 unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.268 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:46.268 unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.315 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:46.315 unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.346 WinSCP: this is end-of-file:0
> 2008-04-03 08:09:46.346 unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.393 WinSCP: this is end-of-file:0
. 2008-04-03 08:09:46.393 Looking up groups and users.
> 2008-04-03 08:09:46.393 groups ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.440 root bin daemon sys adm disk wheel
< 2008-04-03 08:09:46.550 WinSCP: this is end-of-file:0
. 2008-04-03 08:09:46.550 Following groups found:
. 2008-04-03 08:09:46.550 root
. 2008-04-03 08:09:46.550 bin
. 2008-04-03 08:09:46.550 daemon
. 2008-04-03 08:09:46.550 sys
. 2008-04-03 08:09:46.550 adm
. 2008-04-03 08:09:46.550 disk
. 2008-04-03 08:09:46.550 wheel
. 2008-04-03 08:09:46.550 No users found.
. 2008-04-03 08:09:46.550 Changing directory to "/root".
> 2008-04-03 08:09:46.550 cd "/root" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.596 WinSCP: this is end-of-file:0
. 2008-04-03 08:09:46.596 Getting current directory name.
> 2008-04-03 08:09:46.596 pwd ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.628 /root
< 2008-04-03 08:09:46.753 WinSCP: this is end-of-file:0
. 2008-04-03 08:09:46.753 Listing current directory.
> 2008-04-03 08:09:46.753 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.800 total 320
< 2008-04-03 08:09:46.800 drwxr-x--- 25 root root 4096 2008-03-31 14:10:52.000000000 -0500 .
< 2008-04-03 08:09:46.800 drwxr-xr-x 25 root root 4096 2006-11-29 12:28:16.000000000 -0500 ..
< 2008-04-03 08:09:46.800 -rw------- 1 root root 354 2007-11-23 09:36:09.000000000 -0500 .ICEauthority
< 2008-04-03 08:09:46.800 drwx------ 2 root root 4096 2006-11-29 12:29:11.000000000 -0500 .Trash
< 2008-04-03 08:09:46.800 -rw------- 1 root root 108 2007-11-23 09:36:06.000000000 -0500 .Xauthority
< 2008-04-03 08:09:46.800 -rw------- 1 root root 19554 2008-04-02 23:25:33.000000000 -0500 .bash_history
< 2008-04-03 08:09:46.800 -rw-r--r-- 1 root root 24 2006-07-12 19:06:42.000000000 -0500 .bash_logout
< 2008-04-03 08:09:46.800 -rw-r--r-- 1 root root 269 2007-11-07 13:31:14.000000000 -0500 .bash_profile
< 2008-04-03 08:09:46.800 -rw-r--r-- 1 root root 176 2006-07-12 19:06:42.000000000 -0500 .bashrc
< 2008-04-03 08:09:46.800 drwx------ 3 root root 4096 2006-12-07 11:51:40.000000000 -0500 .config
< 2008-04-03 08:09:46.800 -rw-r--r-- 1 root root 100 2006-07-12 19:06:42.000000000 -0500 .cshrc
< 2008-04-03 08:09:46.800 -rw------- 1 root root 26 2006-11-29 12:29:08.000000000 -0500 .dmrc
< 2008-04-03 08:09:46.800 drwxr-x--- 2 root root 4096 2006-11-29 12:29:10.000000000 -0500 .eggcups
< 2008-04-03 08:09:46.800 drwx------ 2 root root 4096 2007-11-07 13:36:42.000000000 -0500 .elinks
< 2008-04-03 08:09:46.800 -rw------- 1 root root 16 2007-11-07 12:07:16.000000000 -0500 .esd_auth
< 2008-04-03 08:09:46.800 drwxr-xr-x 3 root root 4096 2007-11-23 09:34:26.000000000 -0500 .evolution
< 2008-04-03 08:09:46.800 drwx------ 5 root root 4096 2007-11-23 09:36:10.000000000 -0500 .gconf
< 2008-04-03 08:09:46.800 drwx------ 2 root root 4096 2007-11-23 10:03:06.000000000 -0500 .gconfd
< 2008-04-03 08:09:46.800 drwxr-xr-x 3 root root 4096 2006-11-29 12:29:10.000000000 -0500 .gnome
< 2008-04-03 08:09:46.800 drwx------ 8 root root 4096 2007-11-23 09:42:48.000000000 -0500 .gnome2
< 2008-04-03 08:09:46.800 drwx------ 2 root root 4096 2006-11-29 12:29:09.000000000 -0500 .gnome2_private
< 2008-04-03 08:09:46.800 drwxr-xr-x 2 root root 4096 2006-11-29 12:29:12.000000000 -0500 .gstreamer-0.10
< 2008-04-03 08:09:46.800 -rw-r--r-- 1 root root 81 2006-11-29 12:29:09.000000000 -0500 .gtkrc-1.2-gnome2
< 2008-04-03 08:09:46.800 -rw------- 1 root root 35 2008-03-31 09:13:08.000000000 -0500 .lesshst
< 2008-04-03 08:09:46.800 drwx------ 3 root root 4096 2006-11-29 12:29:10.000000000 -0500 .metacity
< 2008-04-03 08:09:46.800 drwx------ 3 root root 4096 2006-12-13 17:18:46.000000000 -0500 .mozilla
< 2008-04-03 08:09:46.800 -rw------- 1 root root 12066 2008-03-31 14:10:52.000000000 -0500 .mysql_history
< 2008-04-03 08:09:46.800 drwx------ 4 root root 4096 2007-12-19 11:14:22.000000000 -0500 .mysqlgui
< 2008-04-03 08:09:46.800 drwxr-xr-x 3 root root 4096 2007-11-08 15:42:44.000000000 -0500 .nautilus
< 2008-04-03 08:09:46.800 drwxr-xr-x 3 root root 4096 2006-12-26 12:47:08.000000000 -0500 .openoffice.org2.0
< 2008-04-03 08:09:46.800 -rw-r--r-- 1 root root 15615 2007-11-23 09:42:48.000000000 -0500 .recently-used.xbel
< 2008-04-03 08:09:46.800 drwxr-xr-x 3 root root 4096 2006-11-29 12:29:10.000000000 -0500 .redhat
< 2008-04-03 08:09:46.800 drwx------ 2 root root 4096 2007-08-27 10:26:05.000000000 -0500 .ssh
< 2008-04-03 08:09:46.800 -rw-r--r-- 1 root root 129 2006-07-12 19:06:42.000000000 -0500 .tcshrc
< 2008-04-03 08:09:46.800 drwx------ 3 root root 4096 2006-12-11 13:21:59.000000000 -0500 .thumbnails
< 2008-04-03 08:09:46.800 drwxr-xr-x 2 root root 4096 2006-12-19 11:13:50.000000000 -0500 .virt-manager
< 2008-04-03 08:09:46.800 drwxr-xr-x 2 root root 4096 2007-11-23 09:36:06.000000000 -0500 .vnc
< 2008-04-03 08:09:46.800 drwxr-xr-x 2 root root 4096 2006-12-19 11:10:59.000000000 -0500 .wireshark
< 2008-04-03 08:09:46.800 -rw-r--r-- 1 root root 4604 2007-11-23 09:36:12.000000000 -0500 .xsession-errors
< 2008-04-03 08:09:46.800 drwxr-xr-x 2 root root 4096 2007-11-07 11:27:32.000000000 -0500 Desktop
< 2008-04-03 08:09:46.800 -rw------- 1 root root 1488 2006-11-29 07:40:13.000000000 -0500 anaconda-ks.cfg
< 2008-04-03 08:09:46.800 lrwxrwxrwx 1 root root 13 2006-12-06 08:46:55.000000000 -0500 html -> /var/www/html
< 2008-04-03 08:09:46.800 -rw-r--r-- 1 root root 57837 2006-11-29 07:40:03.000000000 -0500 install.log
< 2008-04-03 08:09:46.800 -rw-r--r-- 1 root root 6020 2006-11-29 07:39:21.000000000 -0500 install.log.syslog
< 2008-04-03 08:09:46.800 WinSCP: this is end-of-file:0
. 2008-04-03 08:09:46.800 Reading symlink "html".
> 2008-04-03 08:09:46.800 ls -la -d "/var/www/html" ; echo "WinSCP: this is end-of-file:$?"
< 2008-04-03 08:09:46.846 drwxrwxrwx 29 root root 4096 Nov 23 08:16 /var/www/html
< 2008-04-03 08:09:46.956 WinSCP: this is end-of-file:0
. 2008-04-03 08:09:46.956 Directory listing with --full-time succeed, next time all errors during directory listing will be displayed immediatelly.
. 2008-04-03 08:09:46.956 Startup conversation with host finished.
* 2008-04-03 08:09:47.112 (EAccessViolation) Access violation at address 00448116 in module 'WinSCP.exe'. Read of address 00000000
* 2008-04-03 08:09:48.065 (EAccessViolation) Access violation at address 00448116 in module 'WinSCP.exe'. Read of address 00000000
* 2008-04-03 08:09:49.206 (EAccessViolation) Access violation at address 00448116 in module 'WinSCP.exe'. Read of address 00000000
. 2008-04-03 08:10:00.346 Closing connection.
Hope you can find the reason to this glitch.
Once again, kudos for your superb application and for your outstanding and unselfish work.
Blessings,
Bar.
Ger
I have the same experience. I hope this will help.
3 errors, as described by Bar, on initial connect followed by a perfectly working application.
My session log is as follows:
[color=darkred]
. 2008-04-03 16:03:15.545 --------------------------------------------------------------------------
. 2008-04-03 16:03:15.545 WinSCP Version 4.1.0 (Build 375) (OS 5.1.2600 Service Pack 2)
. 2008-04-03 16:03:15.545 Login time: Thursday 03 April 2008 16:03:15
. 2008-04-03 16:03:15.545 Session name: SFTP xxxxxxxxxxxxxxxx
. 2008-04-03 16:03:15.545 Host name: xxxxxxxxxxxxxxxx.com (Port: 22)
. 2008-04-03 16:03:15.545 User name: xxxxxxxxxxxxxxxx (Password: Yes, Key file: No)
. 2008-04-03 16:03:15.545 Tunnel: No
. 2008-04-03 16:03:15.545 Transfer Protocol: SFTP (SCP)
. 2008-04-03 16:03:15.545 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-04-03 16:03:15.545 Proxy: none
. 2008-04-03 16:03:15.545 SSH protocol version: 2; Compression: No
. 2008-04-03 16:03:15.545 Bypass authentication: No
. 2008-04-03 16:03:15.545 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-04-03 16:03:15.545 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2008-04-03 16:03:15.545 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-04-03 16:03:15.545 SFTP Bugs: -,-
. 2008-04-03 16:03:15.545 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-04-03 16:03:15.545 Shell: default, EOL: 0
. 2008-04-03 16:03:15.545 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-04-03 16:03:15.545 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2008-04-03 16:03:15.545 Local directory: c:\data\xxxxxxxxxxxxxxxx, Remote directory: home, Update: No, Cache: Yes
. 2008-04-03 16:03:15.545 Cache directory changes: Yes, Permanent: Yes
. 2008-04-03 16:03:15.545 DST mode: 1
. 2008-04-03 16:03:15.592 Looking up host "xxxxxxxxxxxxxxxx.com"
. 2008-04-03 16:03:15.607 Connecting to 10.225.96.176 port 22
. 2008-04-03 16:03:15.670 Server version: SSH-1.99-OpenSSH_3.9p1
. 2008-04-03 16:03:15.670 We claim version: SSH-2.0-WinSCP_release_4.1
. 2008-04-03 16:03:15.670 SSPI: acquired credentials for: xxxxxxxxxxxxxxxx
. 2008-04-03 16:03:15.670 Constructed service principal name 'host/xxxxxxxxxxxxxxxx.com'
. 2008-04-03 16:03:15.779 GSSKEX disabled: The specified target is unknown or unreachable
. 2008-04-03 16:03:15.779 Using SSH protocol version 2
. 2008-04-03 16:03:15.779 Doing Diffie-Hellman group exchange
. 2008-04-03 16:03:15.873 Doing Diffie-Hellman key exchange with hash SHA-1
. 2008-04-03 16:03:16.060 Host key fingerprint is:
. 2008-04-03 16:03:16.060 ssh-rsa 1024 xxxxxxxxxxxxxxxx
. 2008-04-03 16:03:16.060 Initialised AES-256 SDCTR client->server encryption
. 2008-04-03 16:03:16.060 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-04-03 16:03:16.060 Initialised AES-256 SDCTR server->client encryption
. 2008-04-03 16:03:16.060 Initialised HMAC-SHA1 server->client MAC algorithm
! 2008-04-03 16:03:16.154 Using username "xxxxxxxxxxxxxxxx".
. 2008-04-03 16:03:16.185 Prompt (6, SSH password, , &Password: )
. 2008-04-03 16:03:16.185 Using stored password.
. 2008-04-03 16:03:16.185 Sent password
. 2008-04-03 16:03:16.217 Access granted
. 2008-04-03 16:03:16.248 Opened channel for session
. 2008-04-03 16:03:16.279 Started a shell/command
. 2008-04-03 16:03:16.279 --------------------------------------------------------------------------
. 2008-04-03 16:03:16.279 Using SFTP protocol.
. 2008-04-03 16:03:16.279 Doing startup conversation with host.
> 2008-04-03 16:03:16.279 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2008-04-03 16:03:16.310 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2008-04-03 16:03:16.310 SFTP version 3 negotiated.
. 2008-04-03 16:03:16.310 We believe the server has signed timestamps bug
. 2008-04-03 16:03:16.310 We will use UTF-8 strings for status messages only
. 2008-04-03 16:03:16.310 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2008-04-03 16:03:16.310 Getting current directory name.
. 2008-04-03 16:03:16.310 Getting real path for '.'
> 2008-04-03 16:03:16.310 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2008-04-03 16:03:16.342 Type: SSH_FXP_NAME, Size: 63, Number: 16
. 2008-04-03 16:03:16.342 Real path is '/home/xxxxxxxxxxxxxxxx'
. 2008-04-03 16:03:16.342 Listing directory "/home/xxxxxxxxxxxxxxxx".
> 2008-04-03 16:03:16.342 Type: SSH_FXP_OPENDIR, Size: 30, Number: 267
< 2008-04-03 16:03:16.373 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2008-04-03 16:03:16.373 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2008-04-03 16:03:16.388 Type: SSH_FXP_NAME, Size: 2111, Number: 524
> 2008-04-03 16:03:16.388 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2008-04-03 16:03:16.420 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2008-04-03 16:03:16.420 Status/error code: 1
> 2008-04-03 16:03:16.420 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2008-04-03 16:03:16.420 Startup conversation with host finished.
* 2008-04-03 16:03:17.451 (EAccessViolation) Access violation at address 00448116 in module 'WinSCP.exe'. Read of address 00000000
* 2008-04-03 16:03:18.498 (EAccessViolation) Access violation at address 00448116 in module 'WinSCP.exe'. Read of address 00000000
* 2008-04-03 16:03:19.076 (EAccessViolation) Access violation at address 00448116 in module 'WinSCP.exe'. Read of address 00000000
. 2008-04-03 16:03:24.810 Closing connection.[/color]
Thanks for a superb program!
G
Thanks. I'll send you a debug version soon.
halabund
I, too, have the same experience. Since I updated to the beta version (4.1) this morning, whenever I log in, an "Invalid access to memory" dialogue pops up just before the main window would appear. Afterwards, everything seems to be working correctly.
davidhbrown
This may be the first thing where Vista works better than XP, but I'm getting only 1 "Invalid access to memory" dialog.
(Vista "Ultimate" SP1; UAC turned on; DEP in hardware and enabled for everything.)
Oh, I forgot to say that only get the message once, on WinXP SP2.
Bar
Martin:
I've sent the winscp.log file to your e-mail.
Thanks.
Blessings,
Bar.
Just reposting link to tracker.
