Topic "Bug? File transfer window is non-responsive after timeout"
davidhbrown
WinSCP version 4.1.0 (Build 375). (Also in 4.0.7; I installed the beta just to be sure it hadn't changed.)
OS: Vista Ultimate, SP1; UAC is enabled.
Mode: "Commander" (two-pane) style.
Protocol: FTP primarily, but also seen with SCP.
Symptom: after a timeout, I will often actually be done with the server and click OK rather than reconnect, then close the login box as well. This leaves the two-pane file transfer window behind (now showing only the local files). When I try to close that, it is non-responsive and must be force-quit.
I suspect that an appropriate fix might be for the "OK" box on the lost connection dialog to also close the file transfer window.
As there is no communication with a server at the time of the problem, I'm not emailing a log, but I certainly can if it would help. I could also file a bug in the tracker if that is more appropriate. (I have asked for notification of replies.)
davidhbrown
Oh, darn... looks like it's not perfectly reproducible. It just closed both windows (login and file transfer) this time. I will email the log.
I'll send you a debug version in several days.
