Topic "Swedish"
prikryl
Swedish translation topic.
Feel free to use Swedish in the discussion, but do not expect me to answer Smile
user
The translation file is not working!
prikryl
What does it do?
Sara
Hello, do I need the country specific plugin in order to use country specific characters in the login password?
Kind Regards
Sara
prikryl
Generally no. Though the answer is more complicated. Are you having some problem? What protocol?
Hello, thank you for your answer.
Yes, if I use a password containing the Swedish characters å,ä,ö
connection is refused. I have checked that the password is set correctly on the server.
Still, it could be a server side issue?
prikryl
Again, what protocol?
Sorry for my late answer, to much to do.. Confused
The protocol is ftp
Kind regards
farrington
If anybody wonder about the answer to Swedish characters in passwords, check out this topic:
http://winscp.net/forum/viewtopic.php?t=8265
(Swedish)
Och för att ta det på svenska, om någon undrar så fungerar det inte alls att använda svenska tecken i lösenorden. Bugg i WinSCP, men man jobbar på det... men problemet är inte helt lätt att lösa vad jag förstår det som. Se tråden jag länkade till ovan.
Search winscp.net
Associations
Site design by Black Gate
