I tryed it to 4.19 version... but it seems work only with beta
when are you including finnish in beta/new installation process?
| Author | Message |
prikryl
Posts: 16448 Location: Prague, Czech republic |
Posted: 8 Apr 2008
Finnish translation topic.
Feel free to use Finnish in the discussion, but do not expect me to answer _________________ Martin Prikryl |
| Advertisements |
kuideon
Guest |
Posted: 17 Sep 2009 19:06
hi,
can someone do this for latest release? because the one with the installer does NOT work. is there a file that I can translate to finnish?? |
prikryl
Posted: 18 Sep 2009
If you want translation for the latest beta release, download it here.
kuideon
Guest |
Posted: 18 Sep 2009 12:39
ok,
I tryed it to 4.19 version... but it seems work only with beta when are you including finnish in beta/new installation process? |
prikryl
Posted: 21 Sep 2009
kuideon wrote: I tryed it to 4.19 version... but it seems work only with beta
when are you including finnish in beta/new installation process? Finnish translation for 4.1.9 is included in installation package. _________________ Martin Prikryl |
tpeland
Translator
Posts: 11 Location: Finland |
Posted: 22 Sep 2009 12:48
prikryl wrote: Finnish translation for 4.1.9 is included in installation package. Just a quick note. None of the translations in 4.1.9 or 4.1.7 work in Windows 7 64-bit. The same files work in Windows Vista 64-bit. Winscp 4.2.3 translations do work in Windows 7. Both are tested with a clean Windows 7 (enterprise 64-bit english) installation without any other programs. At start of winscp: File: 'C:\Users\atk-top\Desktop\WinSCP419\WinSCP.FI' does not contain translation for this product version. Please remove the file. Otherwise the application will not work correctly. <OK> When trying to change language to Swedish: File 'C:\Users\atk-top\Desktop\WinSCP419\WinSCP.SV' does not contain translation for this product version. <OK> <Help> |
prikryl
Posted: 23 Sep 2009
tpeland wrote: Just a quick note.
None of the translations in 4.1.9 or 4.1.7 work in Windows 7 64-bit. The same files work in Windows Vista 64-bit. Winscp 4.2.3 translations do work in Windows 7. Both are tested with a clean Windows 7 (enterprise 64-bit english) installation without any other programs. Translations work on Windows 7 since 4.2.2 only. See tracker. |
| Advertisements |
Site design by Black Gate
