Topic "Disable Resume from Command Line?"
bigusdadius
How can I disable resume from a command line or script? Ive been unable to find this answer in any previous posts.
Build
Version 4.0.7 (Build 307)
Protocol
Using SCP protocol
Interface
Using answer file with script
Error
Transfer was successfully finished, but temporary transfer file 'scsi0-0-0-xxxx-s001.vmdk.filepart' could not be renamed to target file name 'scsi0-0-0- xxxx-s001.vmdk'. If the problem persists, you may try to turn off transfer resume support.
Permission denied.
Error code: 3
Error message from server: Permission denied
Request code: 18
I guess you are using SFTP, not SCP. Please read FAQ. If that does not help, come back.
bigusdadius
Does WinSCP use SFTP by default?
Nevermind. I found this answer.
jme
Can you explian how did you resolve this issue as I'm also facing the same kind of issue.
Thanks in advance,
Jme
Have you read the referenced FAQ?
jme
I have read the FAQ, because I'm getting host name, username and password dynamically. Can you tell was there any way to set ResumeSupport using commandline?
Jme
No. Only using predefined configuration (INI file) as described in the FAQ.
Read more about the error:
http://winscp.net/eng/docs/message_transfer_finished_could_not_rename
