Topic "Can't get log or output"
lefevre.10
Hey all -
I'm setting up WinSCP to download our webhost files to an office PC.
I'm writing a script to have an automated download every morning, but I'm having problems testing and troubleshooting it. The files aren't being downloaded, and I can't figure out why. Furthermore, I can't get logging to work, which is really the problem.
I'm using the /log switch, but I don't see any log file created. I did a windows search, but if it turned up, I didn't see it in all the results. I also tried outputing the results to a text file, as the documentation recommends, but the output file is empty.
C:\Program Files\WinSCP>winscp.exe /log /script=download_backups.txt > output.txt
C:\Program Files\WinSCP>dir output.txt
04/22/2008 09:49a 0 output.txt
1 File(s) 0 bytes
Where is the log file located?
1) You have to specify filename after /log. E.g winscp /log=c:\winscp.log
2) Only output of winscp.com (not winscp.exe) can be redirected.
lefevre.10
Wonderful!
There is a place where the documentation should be updated. The Scripting FAQ says you should save a log to troubleshoot, by using /log .
https://winscp.net/eng/docs/guide_automation#results
"Checking script results
To check results of the script your can:
* Check exit code of WinSCP. See example below and another FAQ.
* Save and inspect log file. Use command-line parameter /log.
However, it doesn't indicate that you need to specify a log file.
I did overlook the part about output re-direction only being available in winscp.com Wink
It is indicated in the linked page.
lefevre.10
Where is it located?
Using the search function in firefox, the only reference to the log switch I could find was this:
"Save and inspect log file. Use command-line parameter /log"
Sure. And there is a link leading to Command-line Options.
chuck_ne
I seem to be having trouble getting the log file to be created if winscp3.com is invoked from a batch file. If I type this command at the CMD prompt, it works. ???
@echo off
WinSCP3.com /log=foo /script=XFER /ini=WinSCP3.ini
if errorlevel 1 goto myerror
goto continue
:myerror
Echo There was an error
goto end
:continue
cscript timeone.vbs
:end
I'm not able to reproduce that. What version of WinSCP are you using? Can you try the latest one?
