Windows XP - Copy files on system locally
Abrasax
Johannesburg
Hi there,
Is there a way to copy files on your local system using WinSCP after you've transferred that file from a remote server?
My scenario is that I have one file sitting on a UNIX box that I want copied to two Windows Directories without having to copy the file over the network twice.
Is there a way to do this?
Kind Regards,
A
Re: Windows XP - Copy files on system locally
You can drag it from the local panel to another directory in local panel directory tree or to Windows Explorer.
