Edit
JPR
Edit
Now when installed a fresh SME 5.6 after Redhat 8.0 I can't edit any file. I change a file and next time it's the same as before! Regardless of which type of file ... F4 -- edit some -- F2 -- ESC. Nothing changed when lock in it again.
Peter
JPR
Re: Edit
[quote="JPR"]Hi,
Peter[/quote
I can edit some files... those not editable are also lighting up save-button when changed but don't flash a save-window when pushing F2. Hmm ... logged in as root.
Peter
Re: Edit
Can you see any differences (for example in filename) for files that cause the problem?
