Topic ""Abnormal program termination" error when closing the app"
zero
Just installed v. 4.1.1. Build 385.
This version always gives me the error "Abnormal program termination" when I close the program (regardless what steps I perform after startup).
Thanks for your post. This issue has been added to tracker.
kapkap
I also get every time this error message. I use WinXP SP2.
tony
got this error too whenever i close the program.
my systems is winxp pro sp2
jGuruNew
WinSCP 4.1.1 beta
W2K SP4
mike^
Same problem with Win XP SP3 and SP2.
snerge
I confirm that as well, WinXP english SP2.
unk
I'm also getting the same error message.
Windows XP SP2
axiac
WinSCP 4.1.1 (Build 3.8.5)
Windows 2000, SP4
It displays the "Abnormal program termination" message when one quits the program (after the window closes). It happens always; when "WinSCP login" window is closed (without connecting to a profile) also when the Explorer-style or the NC-style window is closed (a connection is open, of course).
saxa
The same here, on Windows Server 2003 R1 SP2 32bit... Sad
saxa
Martin, on the bug tracker you treat the error as resolved in 4.1.2... Where could we get it, please? Embarassed
QA man
jGuruNew wrote:
WinSCP 4.1.1 beta
W2K SP4
Note please, when this message appears
- winscp.RND file doesn't write
- added custom commands don't save
thank you
It will be released soon.
Alexey Lukin
Version 4.1.2 just crashes when closing.
saxa
Mine closed with the following crash:
Interestingly, after clicking on "OK", I've got the same message once more, and then one more time. I thought, WinSCP couldn't close itself and wanted to use the Process Explorer to kill it, but I saw the error message only trice, and afterwards the WinSCP's process was closed.
I took this picture on W2K3 R1 SP2 32bit, English.
Daver
Same here on winxp-home sp2.
Faulting application winscp412.exe, version 4.1.2.388, faulting module winscp412.exe, version 4.1.2.388, fault address 0x00245ed4.
The 4.1.2 issue is being tracked here.
badboy
I have a problem, when I close winscp. Program crashed only if configuration is saving in ini file. When configuration is in registry, program close without problems.
I have XP SP3, but winscp 4.0 and later working fine.
Tal56
I'm using the stand alone application and have the same problem. Winxp sp3 new install. I think it also has something to do with the writing to ini.
alexalex
It worked fine for me until i insalled this version Sad now it prints Abnormal program termination and after that 3 windows errors ( winscp has encountered an error.... ), one after another.
Exppecting another release.
thanks
Sorry this link gives a permission denied error Confused
Kind regards.
Doing some maintenance on tracker, so it may be offline temporarily. Please retry later.
