Windows Vista Hangs
Seo
Abruzzo
Windows Vista Hangs
When WinSCP goes on timeout, if you don't reconnect to a web site, so close the popup message, then close the saved session and then try to close the app, WinSCP hangs.
Seo
Abruzzo
Re: Windows Vista Hangs
4.07
but this bug is older. I got it since the first time I started to use it, so at least another two previous version.
Bye
Andrea
Seo wrote:
I don't get anything. What did you send me, a mail message? What's the address in the from field?.
Yes, email. Address is:
martin (...) prikryl (...) cz
