Topic "Error code 3 on some files when syncing"
Ontrack
Operation: Sync local with remote using SFTP
Environment:
REMOTE SERVER- Windows Server 2003 running copSSH
LOCAL- Windows Server 2003 running WinSCP 4.1.0 Build 375
When I attempt to syncronize a local directory with the remote some files transfer fine while others (even in the same folder) cause the following error:
[Background 1] Status/error code: 3, Message: 321283, Server: Permission denied, Language:
[Background 1] (ETerminal) Permission denied.
[Background 1] Error code: 3
[Background 1] Error message from server: Permission denied
[Background 1] Request code: 3
Thanks for any help,
-Ontrack
OK, so it looks like you do not have a permissions to overwrite the files.
hudsonpb
I have a similar problem.
This is my site but I'm not sure how/where do I get permission to place images in my images folder (within the WWW folder)?
