Topic "WinSCP FAR plugin 0.1.1"
GerhardW
Hello Martin!
Found your FAR plugin.
http://sourceforge.net/project/showfiles.php?group_id=85589&release_id=175776
Since I use only FAR it should be very cool with puttys single sign on. But I've a problem with it. It shows my sessions but when clicking on any session I get an error: EAccessViolation, OK. Looks like a dangling pointer.
I use putty agent and putty, version is 2003-3-23.
FAR is FAR 1.70B4.
BTW: Where can I find the source of the plugin. Maybe I can fix it.
BTW2: Do you plan to update to the CVS putty version from time to time?
Thank you for the answer.
Ciao,
Gerhard
I've never tried the plugin with Putty agent, so it may be the problem. Can you try it without the agent?
It is not available yet.
I've already done it, wait for the next release.
GerhardW
It still crashes with putty agent disabled.
When do you plan to release the source code?
Thnx.
Ciao,
Gerhard
New version of the plugin will be released at the end of this week (including source code).
GerhardW
Thank you.
Ciao,
Gerhard
GerhardW
Thank you.
Ciao,
Gerhard
Is it already available?
Ciao,
Gerhard
I should have been. In fact I've already released version 1.0 this morning. But minute after I've discovered serious bug Embarassed (plugin fatally fails after file transfer completes), so I've hidden the release. Next attempt will be this evening or tomorrow. My apologies.
But anyway, please try to at least connect with it (using pageant).
These direct download links should work: winscpfar100.zip or winscpfar100setup.exe.
Information about plugin.
GerhardW
Is the source of 1.01 also available?
Thnx.
Ciao,
Gerhard
Please, be patient. Source code archive of 1.0.1 will be released tomorrow. In fact there are only about 5 lines difference to 1.0.0, which you may download from sourceforge. On project CVS, 1.0.1 is already available.
Gerhard
OK, thank you. CVS is ok Smile
BTW: With some first tests it looks really nice Smile
Ciao,
Gerhard
GerhardW
Hello Martin!
I just looked at the CVS and didn't find anything for the FAR plugin.
Any ideas?
Ciao,
Gerhard
You've probably looked on CVS on SourceForge. The far plugin is not there, because the web site was not updated for at least one week. There is missing even WinSCP 3.3 source code. You must use CVS client to get the plugin code. Module name is "far".
GerhardW
prikryl wrote:
You've probably looked on http://cvs.sourceforge.net/cgi-bin/viewcvs.cgi/winscp/. The far plugin is not there, because the web site was not updated for at least one week. There is missing even WinSCP 3.3 source code. You must use CVS client to get the plugin code. Module name is "far".
Ok, I tried it to get with the CVS client.
Do you have a complete CVSROOT?
I got
cvspserver server: cannot find module `far' - ignored
cvs [checkout aborted]: cannot expand modules
Ciao,
Gerhard
guest
Have the same problem as in the first message. have you found a workaround. Far 1.70b4 windows 2000 sp3. do I need to download anything but the far plugin to make it working?
GerhardW
The Latest Version (1.01) worked well for mit with FAR 1.70B5, W2k Sp3.
Ciao,
Gerhard
I got
I've just read on SF, that they've moved anonymous CVS to backup server, where WinSCP plugin is obviously not present yet. They are having some serious performance problems with CVS, it would probably take at least one more week to fix. However, I've already released source packed, so you may download it.
Are you using version 1.0.1 of the plugin?
