Topic "Strange problems"
gh
I'm using WinSCP 4.0.7. When I use external editors for the files on the remote box, very odd problem happens. When I try to open two files simulatenously, WinSCP throws me the error "Cannot remove temporary directory c:\..." when I open the second file. It is editable, but I can't save it. I tried to install the latest beta, but after I close it, the process remains and takes a huge amount of recourses (especially RAM). I'm using 32 bit Windows Vista Home Premium. Any help will be appreciated. Smile
GPalmer
This FAQ entry might help you -> https://winscp.net/eng/docs/task_edit
gh
Thanks Smile
