Topic "synchronize"
linus-johannes
hello,
i want to synchronize the local files with the remote dir, by using a skript.
so i try
option batch on
open test@test.de
option transfer automatic
synchronize remote  /TEST "C:\Inforce\SQL_Server\Datenexport_test\transfer"
close
in the connection it opens the right folders on local and remote, so i thought
synchronize remote
is the right code ....
i try a few things but nothing works.
sometimes it transfers 1 file. I dont want to delete files or rename.
could anyone help me and tell the skript code i need ?
sorry for my bad englisch....
linus
You should do:
Quote:
synchronize remote "C:\Inforce\SQL_Server\Datenexport_test\transfer" /TEST
