Topic "Script "call" cmd improperly checks WinSCP-specific switches"
andrewvog
I recently upgraded from WinSCP 3.8 to 4.x (I experienced the following failure on both 4.0.7 and 4.1.3beta). The problem I'm seeing is that WinSCP looks for and also validates switches on the script "call" command. This is improper, because "call" invokes a remote command that has nothing to do with WinSCP's internal script syntax.
This is a serious issue for me; it prevents me from using the call command for anything but running a remote script that doesn't take parameters.
An example of a command that will (currently) fail every time is the example given in WinSCP's own site:
call mysqldump --opt -u USERNAME --password=PASSWORD --all-databases > all_databases.sql
I downloaded the source, and think I have found this bug (copied below, from Script.cpp). Note that the expression "if (!Switches ...)" seems like it should really be: "if (Switches...)".
void __fastcall TScriptCommands::CheckParams(TOptions * Parameters,
  bool Switches)
  AnsiString Switch;
  if (!Switches && Parameters->UnusedSwitch(Switch))
    throw Exception(FMTLOAD(SCRIPT_UNKNOWN_SWITCH, (Switch)));
Thanks. This bug has been added to tracker.
landau351
I found the same issue and am keen to see it fixed as well!
It should be working in the latest stable release (4.0.7).
AdamA
I also found this bug in version 4.1. I downgraded WINSCP to previous stable version: 4.0.7 and call command works fine however in this version in scripting mode I can not use switches for example:
put --preservertime ....
or
synchronize .... --criteria=both
is it possible to fix both bugs (call command) and (switches) in one version ?
Please wait for the next release.
sto
I would like to know what is the last version of WinSCP where this bug does not appear?
Thank you,
David
The latest stable, 4.0.7.
Sto
I'm sorry but this does not work...
When I call synchronize -delete remote . /home/user, I get a "Too many parameters for command 'synchronize'." error, event with WinSCP 4.0.7 .
David
OK, so what were you asking for? The thread is about bug in handling of switches in "call" command.
This bug was introduced in 4.1.x, with introduction of switches.
On the other hand, if you want to use switches, you have to use 4.1.x.
Owww, sorry... -__-'
I did not read carefully, I thought the problem with switches was global...
So I'm going to try 4.1.x !!
Thanks again,
David
sto
Sorry, another question.
I realize that, at the moment, there is no mean to use at the same time switches for synchronize, and switches inside call, as there is no WinSCP version that supports these two features.
Am I wrong?
David
That's correct. You can workaround that, by creating script on the server-side with the command you need to execute, so you can use the script from "call" command (without switches).
