Topic "Terminal functionnality"
Marc Meurrens
I am since a long time a happy Very Happy user of
WinSCP 2.3.0.146 under W2K.
While not strictly necessary (I have allways also
a PuTTY terminal Idea opened for interactive command),
I found usefull the Terminal functionality
(CTRL-T , Home Black Icon) for many non-interactive
commands (such as compiling a table, immediately
after uploading its data, etc).
Unfortunately Crying or Very sad , I moved to WinXP
and I decided btw to download the latest version.
A fresh new from sunday Aug 24 2003: version 3.2.1.174 !!!
The "Home Black Icon" is still there, but inactive...
and it seems Question that the Terminal functionnality
is not available anymore???
A change between 2.3 and 3.2 Question a bug Question
a problem with WinXP v. Win2K Question
It should work. Please make sure that you connect using SCP protocol. Terminal feature is not available with SFTP (see Supported protocols).
Marc Meurrens
prikryl wrote:
Please make sure that you connect using SCP protocol. (see Supported protocols).
Thanks Martin ! it works Very Happy
Meza
I opened a terminal window and executed a Ping...
eg
ping yahoo.co.uk
and it just continually filled the terminal screen repeating that ping every second, WinSCP locked up and there was no way I could quit it without CTRL+ALT+DEling
Any ideas?
Meza
baltner@...
When I first loaded WinSCP3 the terminal window (cntrl-T) worked great but now the option is grayed out. I updated to WinSCP3.5.6 to see if this would fix it but it hasn't. I did not knowlingly change any config. options. Any ideas?
Bruce Altner
eg
ping yahoo.co.uk
On Terminal windows, there is warning:
"Do NOT execute commands that require user-input".
You may do for example:
"ping yahoo.co.uk -c 5"
to do only 5 attempts.
Please read documentation:
https://winscp.net/eng/docs/protocols
