Topic "Problems automating put command"
Zuzuroatl
Hi there!
I need some help please. I'm trying to automate putting a file on an ftp server with put command. Everything works fine if I do it manually using the UI. When trying to run a script I get this error message:
Upload of file 'FileName.txt' was succesful, but error occured while setting the permissions and/or timestamp. If problem persists, turn on 'Ignore permission errors' option.
The server does not support the operation.
Error code:8
Error message from server <en>:Operation unsupported
Request code:9
<A>bort, <R>etry,<S>kip,Ski<p> all:
This is the .bat file:
winscp.exe /console /script="pathtoscriptfile" /log="pathtologfile"
This is the script file:
open username:pwd@ftpsite
cd pathtohomefolder
option echo on
option batch abort
# Local directory listing
lls
# Remote directory listing
ls
put "pathtofiletobetranferred"
close
This is the log file:
. 2008-05-29 16:59:08.984 --------------------------------------------------------------------------
. 2008-05-29 16:59:08.999 WinSCP Version 4.0.6 (Build 358) (OS 5.1.2600 Service Pack 2)
. 2008-05-29 16:59:08.999 Login time: Thursday, May 29, 2008 4:59:08 PM
. 2008-05-29 16:59:08.999 --------------------------------------------------------------------------
. 2008-05-29 16:59:08.999 Session name: username@ftpsite
. 2008-05-29 16:59:08.999 Host name: hostname (Port: 22)
. 2008-05-29 16:59:08.999 User name: username (Password: Yes, Key file: No)
. 2008-05-29 16:59:08.999 Tunnel: No
. 2008-05-29 16:59:08.999 Transfer Protocol: SFTP (SCP)
. 2008-05-29 16:59:08.999 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-05-29 16:59:08.999 Proxy: none
. 2008-05-29 16:59:08.999 SSH protocol version: 2; Compression: No
. 2008-05-29 16:59:08.999 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-05-29 16:59:08.999 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2008-05-29 16:59:08.999 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-05-29 16:59:08.999 SFTP Bugs: -,-,-
. 2008-05-29 16:59:08.999 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-05-29 16:59:08.999 Shell: default, EOL: 0
. 2008-05-29 16:59:08.999 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-05-29 16:59:08.999 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-05-29 16:59:08.999 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-05-29 16:59:08.999 Cache directory changes: Yes, Permanent: Yes
. 2008-05-29 16:59:08.999 DST mode: 1
. 2008-05-29 16:59:08.999 Looking up host "hostname"
. 2008-05-29 16:59:09.062 Connecting to IPAddress port 22
. 2008-05-29 16:59:09.202 Server version: SSH-2.0-0
. 2008-05-29 16:59:09.202 We claim version: SSH-2.0-WinSCP_release_4.0.6
. 2008-05-29 16:59:09.202 Using SSH protocol version 2
. 2008-05-29 16:59:09.202 Doing Diffie-Hellman group exchange
. 2008-05-29 16:59:09.483 Doing Diffie-Hellman key exchange
. 2008-05-29 16:59:10.062 Host key fingerprint is:
. 2008-05-29 16:59:10.062 ssh-dss 1024
. 2008-05-29 16:59:10.062 Initialised AES-256 client->server encryption
. 2008-05-29 16:59:10.062 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-05-29 16:59:10.062 Initialised AES-256 server->client encryption
. 2008-05-29 16:59:10.062 Initialised HMAC-SHA1 server->client MAC algorithm
! 2008-05-29 16:59:10.280 Using username "username".
. 2008-05-29 16:59:10.327 Session password prompt (username@ftpsite's password: )
. 2008-05-29 16:59:10.327 Using stored password.
. 2008-05-29 16:59:10.327 Sent password
. 2008-05-29 16:59:15.202 Access granted
. 2008-05-29 16:59:15.233 Opened channel for session
. 2008-05-29 16:59:15.296 Started a shell/command
. 2008-05-29 16:59:15.312 --------------------------------------------------------------------------
. 2008-05-29 16:59:15.312 Using SFTP protocol.
. 2008-05-29 16:59:15.327 Doing startup conversation with host.
> 2008-05-29 16:59:15.343 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2008-05-29 16:59:15.390 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2008-05-29 16:59:15.390 SFTP version 3 negotiated.
. 2008-05-29 16:59:15.390 We believe the server has signed timestamps bug
. 2008-05-29 16:59:15.390 We will use UTF-8 strings for status messages only
. 2008-05-29 16:59:15.390 Getting current directory name.
. 2008-05-29 16:59:15.390 Getting real path for '.'
> 2008-05-29 16:59:15.390 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2008-05-29 16:59:15.437 Type: SSH_FXP_NAME, Size: 57, Number: 16
. 2008-05-29 16:59:15.437 Real path is 'path'
. 2008-05-29 16:59:15.437 Startup conversation with host finished.
. 2008-05-29 16:59:15.452 Cached directory change via "path" to "path".
. 2008-05-29 16:59:15.452 Getting current directory name.
. 2008-05-29 16:59:15.483 Listing directory "path".
> 2008-05-29 16:59:15.483 Type: SSH_FXP_OPENDIR, Size: 40, Number: 267
< 2008-05-29 16:59:15.562 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2008-05-29 16:59:15.562 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2008-05-29 16:59:15.608 Type: SSH_FXP_STATUS, Size: 30, Number: 524
< 2008-05-29 16:59:15.608 Status/error code: 1
. 2008-05-29 16:59:15.608 Listing file "path..".
> 2008-05-29 16:59:15.608 Type: SSH_FXP_LSTAT, Size: 43, Number: 775
< 2008-05-29 16:59:15.640 Type: SSH_FXP_ATTRS, Size: 37, Number: 775
> 2008-05-29 16:59:15.655 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2008-05-29 16:59:15.671 Copying 1 files/directories to remote directory "path"
. 2008-05-29 16:59:15.671 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: N (102400); CalcS: No; Mask:
. 2008-05-29 16:59:15.671 TM: M; ClAr: No; ExclM(No):
. 2008-05-29 16:59:15.671 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2008-05-29 16:59:15.671 File: "path\Test_20080529_.txt"
. 2008-05-29 16:59:15.686 Copying "path\Test_20080529_.txt" to remote directory started.
. 2008-05-29 16:59:15.686 Ascii transfer mode selected.
. 2008-05-29 16:59:15.686 Opening remote file.
> 2008-05-29 16:59:15.686 Type: SSH_FXP_OPEN, Size: 75, Number: 1283
< 2008-05-29 16:59:15.702 Type: SSH_FXP_STATUS, Size: 26, Number: 1028
. 2008-05-29 16:59:15.702 Discarding reserved response
< 2008-05-29 16:59:15.827 Type: SSH_FXP_HANDLE, Size: 13, Number: 1283
> 2008-05-29 16:59:15.827 Type: SSH_FXP_WRITE, Size: 30, Number: 1798
> 2008-05-29 16:59:15.827 Type: SSH_FXP_CLOSE, Size: 13, Number: 2052
> 2008-05-29 16:59:15.827 Type: SSH_FXP_SETSTAT, Size: 71, Number: 1545
< 2008-05-29 16:59:15.858 Type: SSH_FXP_STATUS, Size: 26, Number: 1798
< 2008-05-29 16:59:15.968 Type: SSH_FXP_STATUS, Size: 26, Number: 2052
< 2008-05-29 16:59:15.968 Status/error code: 0
< 2008-05-29 16:59:15.968 Type: SSH_FXP_STATUS, Size: 40, Number: 1545
< 2008-05-29 16:59:15.968 Status/error code: 8, Message: 1545, Server: Operation unsupported, Language: en
* 2008-05-29 16:59:15.968 (ETerminal) The server does not support the operation.
* 2008-05-29 16:59:15.968 Error code: 8
* 2008-05-29 16:59:15.968 Error message from server (en): Operation unsupported
* 2008-05-29 16:59:15.968 Request code: 9
. 2008-05-29 16:59:15.968 Asking user:
. 2008-05-29 16:59:15.968 Upload of file 'Test_20080529_.txt' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option. ("The server does not support the operation.
. 2008-05-29 16:59:15.968 Error code: 8
. 2008-05-29 16:59:15.968 Error message from server (en): Operation unsupported
. 2008-05-29 16:59:15.968 Request code: 9")
* 2008-05-29 16:59:17.952 (EScpSkipFile) Upload of file 'Test_20080529_.txt' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option.
* 2008-05-29 16:59:17.952 The server does not support the operation.
* 2008-05-29 16:59:17.952 Error code: 8
* 2008-05-29 16:59:17.952 Error message from server (en): Operation unsupported
* 2008-05-29 16:59:17.952 Request code: 9
. 2008-05-29 16:59:17.952 Closing connection.
I have disabled resume support in preferences (like it was suggested in different post) and it's still not working.
Thank you!
As suggested, turn on 'Ignore permission errors'. This FAQ will show you how.
Zuzuroatl
Hi prikryl!
I went to Options -> Preferences ->Transfers and I checked the: 'Ignore permission errors' check box and still not working. Is this what I needed to do? I also tried to transfer the file by using the GUI but I get the same message. When I use the GUI though, if I click on the Skip button, the file get's transferred.
Thank you.
Zuzuroatl
OK
I made it work when using the GUI. In addition to checking the 'Ignore permission errors' check box have also unchecked the "Preserve Time Stam" chekbox. But it's still not working when using the script. I don't get any error messages now, the file is just not transferred.
Here is the log:
. 2008-06-04 17:31:18.752 --------------------------------------------------------------------------
. 2008-06-04 17:31:18.752 WinSCP Version 4.0.6 (Build 358) (OS 5.1.2600 Service Pack 2)
. 2008-06-04 17:31:18.752 Login time: Wednesday, June 04, 2008 5:31:18 PM
. 2008-06-04 17:31:18.752 Session name: session
. 2008-06-04 17:31:18.752 Host name: host (Port: 22)
. 2008-06-04 17:31:18.752 User name: user (Password: Yes, Key file: No)
. 2008-06-04 17:31:18.752 Tunnel: No
. 2008-06-04 17:31:18.752 Transfer Protocol: SFTP (SCP)
. 2008-06-04 17:31:18.752 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-06-04 17:31:18.752 Proxy: none
. 2008-06-04 17:31:18.752 SSH protocol version: 2; Compression: No
. 2008-06-04 17:31:18.752 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-06-04 17:31:18.752 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2008-06-04 17:31:18.752 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-06-04 17:31:18.752 SFTP Bugs: -,-,-
. 2008-06-04 17:31:18.752 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-06-04 17:31:18.752 Shell: default, EOL: 0
. 2008-06-04 17:31:18.752 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-06-04 17:31:18.752 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-06-04 17:31:18.752 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-06-04 17:31:18.752 Cache directory changes: Yes, Permanent: Yes
. 2008-06-04 17:31:18.752 DST mode: 1
. 2008-06-04 17:31:18.752 Looking up host "host"
. 2008-06-04 17:31:18.752 Connecting to 111.11.11.11 port 22
. 2008-06-04 17:31:19.018 Server version: SSH-2.0-0
. 2008-06-04 17:31:19.018 We claim version: SSH-2.0-WinSCP_release_4.0.6
. 2008-06-04 17:31:19.018 Using SSH protocol version 2
. 2008-06-04 17:31:19.018 Doing Diffie-Hellman group exchange
. 2008-06-04 17:31:19.456 Doing Diffie-Hellman key exchange
. 2008-06-04 17:31:20.065 Host key fingerprint is:
. 2008-06-04 17:31:20.065 ssh-dss 1024 54:bc:73:0f:aa:b0:fa:37:ef:d1:cd:97:be:d6:e1:55
. 2008-06-04 17:31:20.081 Initialised AES-256 client->server encryption
. 2008-06-04 17:31:20.081 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-06-04 17:31:20.081 Initialised AES-256 server->client encryption
. 2008-06-04 17:31:20.081 Initialised HMAC-SHA1 server->client MAC algorithm
! 2008-06-04 17:31:20.284 Using username "user".
. 2008-06-04 17:31:20.331 Session password prompt ( password: )
. 2008-06-04 17:31:20.331 Using stored password.
. 2008-06-04 17:31:20.331 Sent password
. 2008-06-04 17:31:20.644 Access granted
. 2008-06-04 17:31:20.691 Opened channel for session
. 2008-06-04 17:31:20.738 Started a shell/command
. 2008-06-04 17:31:20.738 --------------------------------------------------------------------------
. 2008-06-04 17:31:20.738 Using SFTP protocol.
. 2008-06-04 17:31:20.738 Doing startup conversation with host.
> 2008-06-04 17:31:20.738 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2008-06-04 17:31:20.784 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2008-06-04 17:31:20.784 SFTP version 3 negotiated.
. 2008-06-04 17:31:20.784 We believe the server has signed timestamps bug
. 2008-06-04 17:31:20.784 We will use UTF-8 strings for status messages only
. 2008-06-04 17:31:20.784 Getting current directory name.
. 2008-06-04 17:31:20.784 Getting real path for '.'
> 2008-06-04 17:31:20.784 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2008-06-04 17:31:20.816 Type: SSH_FXP_NAME, Size: 57, Number: 16
. 2008-06-04 17:31:20.816 Real path is 'path'
. 2008-06-04 17:31:20.816 Startup conversation with host finished.
. 2008-06-04 17:31:20.816 Cached directory change via "path" to "path".
. 2008-06-04 17:31:20.816 Getting current directory name.
. 2008-06-04 17:31:20.831 Listing directory "path".
> 2008-06-04 17:31:20.831 Type: SSH_FXP_OPENDIR, Size: 40, Number: 267
< 2008-06-04 17:31:20.910 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2008-06-04 17:31:20.910 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2008-06-04 17:31:20.956 Type: SSH_FXP_STATUS, Size: 30, Number: 524
< 2008-06-04 17:31:20.956 Status/error code: 1
. 2008-06-04 17:31:20.956 Listing file "path".
> 2008-06-04 17:31:20.956 Type: SSH_FXP_LSTAT, Size: 43, Number: 775
< 2008-06-04 17:31:20.988 Type: SSH_FXP_ATTRS, Size: 37, Number: 775
> 2008-06-04 17:31:20.988 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2008-06-04 17:31:21.003 Copying 1 files/directories to remote directory "path"
. 2008-06-04 17:31:21.003 PrTime: No; PrRO: Yes; Rght: rwxrwxrwx; PrR: No (Yes); FnCs: N; RIC: 01; Resume: N (102400); CalcS: No; Mask:
. 2008-06-04 17:31:21.003 TM: M; ClAr: No; ExclM(No):
. 2008-06-04 17:31:21.003 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2008-06-04 17:31:21.003 File: "C:\Projects\PutFileOnFtp\Test_20080529_.txt"
. 2008-06-04 17:31:21.003 Copying "C:\Projects\PutFileOnFtp\Test_20080529_.txt" to remote directory started.
. 2008-06-04 17:31:21.003 Ascii transfer mode selected.
. 2008-06-04 17:31:21.003 Opening remote file.
> 2008-06-04 17:31:21.003 Type: SSH_FXP_OPEN, Size: 75, Number: 1283
< 2008-06-04 17:31:21.035 Type: SSH_FXP_STATUS, Size: 26, Number: 1028
. 2008-06-04 17:31:21.035 Discarding reserved response
< 2008-06-04 17:31:21.113 Type: SSH_FXP_HANDLE, Size: 13, Number: 1283
> 2008-06-04 17:31:21.113 Type: SSH_FXP_WRITE, Size: 30, Number: 1798
> 2008-06-04 17:31:21.128 Type: SSH_FXP_CLOSE, Size: 13, Number: 2052
< 2008-06-04 17:31:21.160 Type: SSH_FXP_STATUS, Size: 26, Number: 1798
< 2008-06-04 17:31:21.269 Type: SSH_FXP_STATUS, Size: 26, Number: 2052
< 2008-06-04 17:31:21.269 Status/error code: 0
. 2008-06-04 17:31:21.269 Closing connection.
Zuzuroatl wrote:
Here is the log:
The log does not show any error. Maybe you have posted wrong one?
Zuzuroatl
Hi!
I tried again. I don't get any error messages but still, when I connect to the remote site the file I want to transfer is not there. I can't figure out why the file is not on the remote site. Please help if you have any suggestions. Here is the log.
. 2008-08-13 11:33:50.574 --------------------------------------------------------------------------
. 2008-08-13 11:33:50.574 WinSCP Version 4.0.6 (Build 358) (OS 5.1.2600 Service Pack 2)
. 2008-08-13 11:33:50.574 Login time: Wednesday, August 13, 2008 11:33:50 AM
. 2008-08-13 11:33:50.574 Session name: sessionname
. 2008-08-13 11:33:50.574 Host name: host (Port: 22)
. 2008-08-13 11:33:50.574 User name: usr (Password: Yes, Key file: No)
. 2008-08-13 11:33:50.574 Tunnel: No
. 2008-08-13 11:33:50.574 Transfer Protocol: SFTP (SCP)
. 2008-08-13 11:33:50.574 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-08-13 11:33:50.574 Proxy: none
. 2008-08-13 11:33:50.574 SSH protocol version: 2; Compression: No
. 2008-08-13 11:33:50.574 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-08-13 11:33:50.574 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2008-08-13 11:33:50.574 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-08-13 11:33:50.574 SFTP Bugs: -,-,-
. 2008-08-13 11:33:50.574 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-08-13 11:33:50.574 Shell: default, EOL: 0
. 2008-08-13 11:33:50.574 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-08-13 11:33:50.574 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-08-13 11:33:50.574 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-08-13 11:33:50.574 Cache directory changes: Yes, Permanent: Yes
. 2008-08-13 11:33:50.574 DST mode: 1
. 2008-08-13 11:33:50.574 Looking up host "host"
. 2008-08-13 11:33:50.574 Connecting to ipaddress port 22
. 2008-08-13 11:33:50.793 Server version: SSH-2.0-0
. 2008-08-13 11:33:50.793 We claim version: SSH-2.0-WinSCP_release_4.0.6
. 2008-08-13 11:33:50.793 Using SSH protocol version 2
. 2008-08-13 11:33:50.793 Doing Diffie-Hellman group exchange
. 2008-08-13 11:33:53.722 Doing Diffie-Hellman key exchange
. 2008-08-13 11:33:56.620 Host key fingerprint is:
. 2008-08-13 11:33:56.620 ssh-dss 1024 54:bc:73:0f:aa:b0:fa:37:ef:d1:cd:97:be:d6:e1:55
. 2008-08-13 11:33:56.620 Initialised AES-256 client->server encryption
. 2008-08-13 11:33:56.620 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-08-13 11:33:56.620 Initialised AES-256 server->client encryption
. 2008-08-13 11:33:56.620 Initialised HMAC-SHA1 server->client MAC algorithm
! 2008-08-13 11:33:56.886 Using username "usr".
. 2008-08-13 11:33:56.949 Session password prompt (jsmithlanier@secure.unum.com's password: )
. 2008-08-13 11:33:56.949 Using stored password.
. 2008-08-13 11:33:56.949 Sent password
. 2008-08-13 11:34:02.150 Access granted
. 2008-08-13 11:34:02.197 Opened channel for session
. 2008-08-13 11:34:02.244 Started a shell/command
. 2008-08-13 11:34:02.244 --------------------------------------------------------------------------
. 2008-08-13 11:34:02.244 Using SFTP protocol.
. 2008-08-13 11:34:02.244 Doing startup conversation with host.
> 2008-08-13 11:34:02.244 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2008-08-13 11:34:02.275 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2008-08-13 11:34:02.291 SFTP version 3 negotiated.
. 2008-08-13 11:34:02.291 We believe the server has signed timestamps bug
. 2008-08-13 11:34:02.291 We will use UTF-8 strings for status messages only
. 2008-08-13 11:34:02.291 Getting current directory name.
. 2008-08-13 11:34:02.291 Getting real path for '.'
> 2008-08-13 11:34:02.291 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2008-08-13 11:34:02.322 Type: SSH_FXP_NAME, Size: 57, Number: 16
. 2008-08-13 11:34:02.322 Real path is '/Home/jsmithlanier'
. 2008-08-13 11:34:02.322 Startup conversation with host finished.
. 2008-08-13 11:34:02.322 Cached directory change via "/Home/jsmithlanier/CapitalCB/In/" to "/Home/jsmithlanier/CapitalCB/In".
. 2008-08-13 11:34:02.322 Getting current directory name.
. 2008-08-13 11:34:02.322 Copying 1 files/directories to remote directory "/Home/jsmithlanier/CapitalCB/In"
. 2008-08-13 11:34:02.322 PrTime: No; PrRO: Yes; Rght: rwxrwxrwx; PrR: No (Yes); FnCs: N; RIC: 01; Resume: N (102400); CalcS: No; Mask:
. 2008-08-13 11:34:02.322 TM: B; ClAr: No; ExclM(No):
. 2008-08-13 11:34:02.338 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2008-08-13 11:34:02.338 File: "C:\Projects\PutFileOnFtp\Test_20080813_.txt"
. 2008-08-13 11:34:02.338 Copying "C:\Projects\PutFileOnFtp\Test_20080813_.txt" to remote directory started.
. 2008-08-13 11:34:02.338 Binary transfer mode selected.
. 2008-08-13 11:34:02.338 Opening remote file.
> 2008-08-13 11:34:02.338 Type: SSH_FXP_OPEN, Size: 75, Number: 259
< 2008-08-13 11:34:02.432 Type: SSH_FXP_HANDLE, Size: 13, Number: 259
> 2008-08-13 11:34:02.432 Type: SSH_FXP_WRITE, Size: 4121, Number: 774
. 2008-08-13 11:35:01.581 734 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-08-13 11:35:01.581 Type: SSH_FXP_CLOSE, Size: 13, Number: 95236
< 2008-08-13 11:35:01.643 Type: SSH_FXP_STATUS, Size: 26, Number: 94470
< 2008-08-13 11:35:01.784 Type: SSH_FXP_STATUS, Size: 26, Number: 94726
< 2008-08-13 11:35:01.847 Type: SSH_FXP_STATUS, Size: 26, Number: 94982
< 2008-08-13 11:35:01.910 Type: SSH_FXP_STATUS, Size: 26, Number: 95236
< 2008-08-13 11:35:01.910 Status/error code: 0
. 2008-08-13 11:35:01.910 Closing connection.
Zuzuroatl
I think it's working. I think I figured out what was wrong. Thanks!!!
what was wrong?
