Topic "Error listing directory '/var/root'."
rethesh
I am using WinSCP to connect my iphone to the windows. Following is the error I get. Have tried reinstalling and newer versions. Same error.
Operating System : Windows xp
WinSCP Version : 4.0.4
File Protocol : SCP
Interface : Commander
Error : Error listing directory '/var/root'.
Command 'ls -la '
failed with return code 133 and error message
dyld: Library not loaded: /usr/local/arm-apple-darwin/lib/libgcc_s.1.dylib
Referenced from: /bin/ls
Reason: image not found.
I am not able to get the folders of the iphone, though i can see all the folders on the left pane of the commader interface.
Regards,
Rethesh
That is server (iphone)-side problem. Have you tried using SFTP instead of SCP?
rethesh
Thanks...
Not tried SFTP, will try and let u know if it works or not.
pjain
Rethesh,
Did it work ?
Can you tell me how you got it working as I am slo facing same issue.
It did not work. Still trying to figure out.
pjain wrote:
Rethesh,
Did it work ?
Use SFTP and TICK Allow SCP fallback, it worked for me
