Topic "Opened Sessions shortcuts"
VLM
I notice that alt-1, alt-2, etc. seem only to work with the qwerty numbers but not with the numpad. Is this correct? I would much prefer to use the latter, if available.
Thanks!
In Windows Alt-NumPad is reserved to typing characters by their codes.
VLM
What about creating a second mapping, as ctrl-1, ctrl-2, etc?
Well I can, but I do not find it that important to occupy another shortcuts, which may be used for new features in future.
VLM
FWIW, I find that this would be one of the half dozen or so shortcuts I'd use the most. Others may differ, if course.
Is there a way to create our own shortcuts/keyboard mapings within the program?
No. This feature request has been added to tracker.
VLM
Thank you very much ... I appreciate your responsiveness!
