Topic "Invalid Access to memory"
Susanne
On some PCs I've the problem, that the message "Ungltiger Zugriff auf den Speicher / Invalid access to memory" arises when starting WinSCP as normal User. After clicking "ok" everthing works fine (sftp). When I start WinSCP as Admin-User via Netop on the same PC I don't get this error. We've tried to reproduce the error on a test-PC, but we didn't get it. On all Pcs Windows XP Professional SP3 is installed, WinSCP is 4.0.7.370. We've tried to delete the User-Profile => no success. It's no Proxy or Firewallproblem. The Logfile says:
2008-06-03 15:15:03.248 --------------------------------------------------------------------------
. 2008-06-03 15:15:03.248 WinSCP Version 4.0.7 (Build 370) (OS 5.1.2600 Service Pack 3)
. 2008-06-03 15:15:03.248 Login time: Dienstag, 03. Juni 2008 15:15:03
. 2008-06-03 15:15:03.248 --------------------------------------------------------------------------
. 2008-06-03 15:15:03.248 Session name: kplus@kondor1
. 2008-06-03 15:15:03.248 Host name: kondor1 (Port: 22)
. 2008-06-03 15:15:03.264 User name: kplus (Password: Yes, Key file: No)
. 2008-06-03 15:15:03.264 Tunnel: No
. 2008-06-03 15:15:03.264 Transfer Protocol: SFTP (SCP)
. 2008-06-03 15:15:03.264 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-06-03 15:15:03.264 Proxy: none
. 2008-06-03 15:15:03.264 SSH protocol version: 2; Compression: No
. 2008-06-03 15:15:03.264 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-06-03 15:15:03.264 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2008-06-03 15:15:03.264 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-06-03 15:15:03.264 SFTP Bugs: -,-,-
. 2008-06-03 15:15:03.264 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-06-03 15:15:03.264 Shell: default, EOL: 0
. 2008-06-03 15:15:03.264 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-06-03 15:15:03.264 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-06-03 15:15:03.264 Local directory: C:\Temp, Remote directory: /var/tmp, Update: No, Cache: Yes
. 2008-06-03 15:15:03.264 Cache directory changes: Yes, Permanent: Yes
. 2008-06-03 15:15:03.264 DST mode: 1
. 2008-06-03 15:15:03.264 --------------------------------------------------------------------------
. 2008-06-03 15:15:03.280 Looking up host "kondor1"
. 2008-06-03 15:15:03.686 Using SFTP protocol.
. 2008-06-03 15:15:03.686 Doing startup conversation with host.
> 2008-06-03 15:15:03.686 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2008-06-03 15:15:03.748 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2008-06-03 15:15:03.748 SFTP version 3 negotiated.
. 2008-06-03 15:15:03.748 We believe the server has signed timestamps bug
. 2008-06-03 15:15:03.748 We will use UTF-8 strings for status messages only
. 2008-06-03 15:15:03.748 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2008-06-03 15:15:03.748 Changing directory to "/var/tmp".
. 2008-06-03 15:15:03.748 Getting real path for '/var/tmp'
> 2008-06-03 15:15:03.748 Type: SSH_FXP_REALPATH, Size: 17, Number: 16
< 2008-06-03 15:15:03.748 Type: SSH_FXP_NAME, Size: 37, Number: 16
. 2008-06-03 15:15:03.748 Real path is '/var/tmp'
. 2008-06-03 15:15:03.748 Trying to open directory "/var/tmp".
> 2008-06-03 15:15:03.748 Type: SSH_FXP_LSTAT, Size: 17, Number: 263
< 2008-06-03 15:15:03.748 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2008-06-03 15:15:03.748 Getting current directory name.
. 2008-06-03 15:15:03.748 Listing directory "/var/tmp".
> 2008-06-03 15:15:03.748 Type: SSH_FXP_OPENDIR, Size: 17, Number: 523
< 2008-06-03 15:15:03.764 Type: SSH_FXP_HANDLE, Size: 13, Number: 523
> 2008-06-03 15:15:03.764 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2008-06-03 15:15:03.764 Type: SSH_FXP_NAME, Size: 4951, Number: 780
> 2008-06-03 15:15:03.764 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< 2008-06-03 15:15:03.764 Type: SSH_FXP_STATUS, Size: 28, Number: 1036
< 2008-06-03 15:15:03.764 Status/error code: 1
> 2008-06-03 15:15:03.764 Type: SSH_FXP_CLOSE, Size: 13, Number: 1284
. 2008-06-03 15:15:03.764 Startup conversation with host finished.
* 2008-06-03 15:15:03.826 (EAccessViolation) Access violation at address 004441C1 in module 'WinSCP.exe'. Read of address 0000023C
Can you try that with 4.1.3 beta?
