Topic "Hostkey command"
rocheuser
Can someone provide an example of using the hostkey command line option within a script.
I've been working with this for 2 days and am not getting anywhere.
I'm using version 4.0.7
I have tried the SshHostKeys and Configuration\CDCache values from the ini file with no luck.
I have also tried the value found under Server host key Fingerprint on the Server and Protocol information screen,
bertv
I used this to transfer files
option batch on
open sftp://username:password@55.10.1.21:22 -hostkey="ssh-rsa 1024 e9:8d:64:40:1e:5f:cee9:8d:64:40:1e:5f:ce"
option transfer binary
put -delete C:\temp\* ./outgoing/
close
Hostkey option is supported since 4.1.x only.
option batch on
close
Thanks, It works now.
I was putting the hostkey switch on the command line like /console etc.
