How do I enable compress from the command line in Windows?
sm8680
Pittsburgh, PA
"C:\Program Files\WinSCP\WinSCP.Com" -script=C:\AssetLink\Notes\AssetLinkNotes.txt
Would I enable above via a setting or in my AssetLinkNotes.txt script? Please advise. Thanks.
Steve
trailmug
Use -rawsettings compression=1 on the open command.. You'll need to upgrade to WinSCP 5, though, for it to work.
