Topic "Incoming packet garbled on decryption"
BarrySmoke
4.1.4 brings up a new error under vista.(4.0.7 doesn't do this)
you can log-in, and browse files, but when you try to transfer, you get incoming packet garbled on decryption.
What server are you using? What protocol?
BarrySmoke
globalscape 3.3.1/ sftp
BarrySmoke
I have verified this is only a problem with globalscape,
using sshd server, on linux server works fine
There is known issue with Globalspace server.
StanleyRTP
Globalscape says it is a known issue with WinSCP so I guess we are stuck for awhile until someone backs down.
Well I'm not that experience with SSH. But according to PuTTY developers the problem is different than what GlobalSCAPE claims.
Anyway, this issue is being tracked.
Ruben
You are right; I just read on the following link that the problem was solved in EFT v6.
Details: http://omgili.com/jmp/.0rSU5LtMgwJv.Htxj6iLXDQTLQvshnEHxXXrUEtmSSTHX8fOwErmljrGSCbRVXeEQwuAt7MXXG.9JjZ6kCBaNU.wdF0B6BFHNeOSFkoAwUEw5ZSBKGqqNEwSa9qHCDw.PUNAxfDpQq7P5eJ.wL43Rw75bmMkCrU
