Topic "Chance File extension after Transfer"
Kornelis
Hi All,
i have to transfer CSV Files from a FTP Server. But unfortunetly,
they are not saves as .csv files but as .dat files. So i have always to
rename the extension after the transfer.
Is there any way to implement an automation to rename the files after download?
Best Regards
Kornelis
No.
But if you are downloading more files at once, you can rename them while downloading by changing the operation mask on download options dialog from *.* to *.csv
