Topic "How to put the date usual format in Winscp script?"
Tom_shen
I use winscp script to get file from server.
normal file is ok. but i met some file with the date in the file name. such as 20080708abcd.txt.
could i use any funcation to get this kind of file?
could winscp script sopport this?
See examples.
tom_shen
If i do not have PHP tool on my side, Any other method to download the file.
The file name format is YYYYMMDD_xxxxxxx.XLS
What is your side? You can use any other scripting language anyway.
steve
get realdate.com from www.huweb.hu/maques/realdate.htm
then call winscp from a batch file thus :-
for /f %%i in ('realdate.com /d') do (set DT=%%i)
"C:\Program Files\WinSCP\WinSCP.exe" /console /script=m:/app/cron/auto.ftp
Then in your ftp script get a date in the form 20080724 using %DT% Very Happy
Thanks for the hint. I have added it to example.
o5tech
Thanks for the example but I cannot use %DT% in my script.
My script is something like:
put C:\%DT%\*.* /tmp
And I have the following error:
File or folder 'C:\%DT%\*.*' does not exist.
What I have to do?
Thanks!!!
First make sure that you have the latest version of WinSCP. Also you may need to enable windows shell extensions for the advanced usage of for command.
The error was that I had not the latest version of WinSCP.
Thanks!
ritika
I need to download file(filename with today's date in it) from Linux server using winscp.I am using WINSCP.COM /script and running it by batch script.how can I specify current date with its proper formatting(dd_mm_yyyy) in winscp.com so it downloads desired file.
get /path/prefix%TIMESTAMP#dd_mm_yyyy%suffix c:\path\
See http://winscp.net/eng/docs/scripting#timestamp
