Topic "winscpt and ssis task"
mr4100
Hi, I can't seem to figure out the command line syntax to run this software with SSIS execute process task.
Here is what I have so far.
I call the WinScp.exe
I pass this line in as my argument
user@mysite.com /privatekey/ "\\test\f$\Import\scp Keys\OSF priv key.ppk"/script="\\sqltest\e$\SSIStest\Export\sftpscript.txt"
it times out everytime?
Maybe like this:
user@mysite.com /privatekey="\\test\f$\Import\scp Keys\OSF priv key.ppk" /script="\\sqltest\e$\SSIStest\Export\sftpscript.txt"
user@mysite.com /privatekey/ "\\test\f$\Import\scp Keys\OSF priv key.ppk"/script="\\test\a$\SSIStest\Export\sftpscript.txt"
got it!
joney
I have the following script that I wrote to a text file called download.txt:
option batch on
# Disable overwrite confirmations
# Do the work
get file*.zip c:\Folder
# Close and exit
close
I am using an SSIS Execute Process Task with the following settings:
RequireFullFileName: True
Executable: C:\Program Files\WinSCP\WinSCP.exe
Arguments: user@ftp.server.com:2222 /privatekey="c:\Folder\PKey.ppk" /script="c:\Folder\download.txt"
WorkingDirectory: c:\Folder
The rest of the settings are default.
When I execute the task, I receive an [Execute Process Task]Progress: Operation Complete - 100 percent complete. However it did not transfer (get) the zip file from the FTP server. What am I doing wrong?
HoMi
option batch on
# Do the work
# Close and exit
close
I have the same problem Sad
When Im running the command with scriptfile as agrument at the commandshell I get no errormessage, but it downloads nothing Sad
Use /log to enable logging in WinSCP and inspect the log file.
JRB_BMB
Change your arguments from using /script or /key to -script and -key
And call winSCP.COM not the EXE.
Also try to save the connection in winSCP and then open the connection in the script. If you're using a secure server then there shouldn't be an issue with this in terms of security.
I do not think this makes any difference.
JRB_BMB
Well at least this way is tried and tested; so eitherway they can try both and if it doesn't work with '/' then it's an easy change.
I don't know if you have any SSIS experience Martin but it's not exactly a nice experience using it! Razz
Also see guide to using WinSCP from SSIS.
trinath89
now i know how to send the script file location as an argument
please tell me how to send the parameter with it
-script=D:\script.txt -parameter c:\database\templete.xls
and in the script
option batch off
open XXXXXXXXXXXX
put %1% /database/
will the above code work?
Thanks and Regards
Trinath
and in the script
option batch off
open XXXXXXXXXXXX
put %1% /database/
The official syntax is to use slashes:
Though dashes do too.
To make it perfect prepend the parameters with //
/script=D:\script.txt /parameter c:\database\templete.xls
http://winscp.net/eng/docs/commandline#syntax
Also you should better enclose the %1% in double quotes:
put "%1%" /database/
http://winscp.net/eng/docs/scripting#syntax
trinath89
Thanks a lot
