Topic "Directory named "~""
noec
Version: 4.0.7.; 370. build;
Protocol: all;
Interface: commander (I did not test explorer style);
Bug: Unable to make directory named "~" in my home directory and unable to cd in directories named "~" (when clicking on it, it goes to home directory). For example, unable to make /home/noec/~/ and unable to cd in /hdd/~/.
My e-mail: macs.martins@gmail.com
Can you post a log file?
noec
Sorry, forgot about it. ;-)
This time tried to cd in /www/~/
[code]. 2008-07-24 21:20:33.667 --------------------------------------------------------------------------
. 2008-07-24 21:20:33.667 WinSCP Version 4.0.7 (Build 370) (OS 5.1.2600 Service Pack 2)
. 2008-07-24 21:20:33.667 Login time: ceturtdiena, 2008. gada 24. jыlijs 21:20:33
. 2008-07-24 21:20:33.667 Session name: user@chain
. 2008-07-24 21:20:33.667 Host name: chain (Port: 22)
. 2008-07-24 21:20:33.667 User name: user (Password: Yes, Key file: No)
. 2008-07-24 21:20:33.667 Tunnel: No
. 2008-07-24 21:20:33.667 Transfer Protocol: SFTP (SCP)
. 2008-07-24 21:20:33.667 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-07-24 21:20:33.667 Proxy: none
. 2008-07-24 21:20:33.667 SSH protocol version: 2; Compression: No
. 2008-07-24 21:20:33.667 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-07-24 21:20:33.667 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2008-07-24 21:20:33.667 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-07-24 21:20:33.667 SFTP Bugs: -,-,-
. 2008-07-24 21:20:33.667 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-07-24 21:20:33.667 Shell: default, EOL: 0
. 2008-07-24 21:20:33.667 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-07-24 21:20:33.667 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-07-24 21:20:33.667 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-07-24 21:20:33.667 Cache directory changes: Yes, Permanent: Yes
. 2008-07-24 21:20:33.667 DST mode: 1
. 2008-07-24 21:20:33.683 Looking up host "chain"
. 2008-07-24 21:20:33.683 Connecting to 192.168.1.7 port 22
. 2008-07-24 21:20:33.683 Waiting for the server to continue with the initialisation
. 2008-07-24 21:20:33.683 Detected network event
. 2008-07-24 21:20:33.870 Detected network event
. 2008-07-24 21:20:33.870 Server version: SSH-2.0-OpenSSH_4.7
. 2008-07-24 21:20:33.870 We claim version: SSH-2.0-WinSCP_release_4.0.7
. 2008-07-24 21:20:33.870 Using SSH protocol version 2
. 2008-07-24 21:20:33.870 Waiting for the server to continue with the initialisation
. 2008-07-24 21:20:33.886 Detected network event
. 2008-07-24 21:20:33.886 Doing Diffie-Hellman group exchange
. 2008-07-24 21:20:33.886 Waiting for the server to continue with the initialisation
. 2008-07-24 21:20:33.980 Detected network event
. 2008-07-24 21:20:33.980 Doing Diffie-Hellman key exchange
. 2008-07-24 21:20:34.167 Waiting for the server to continue with the initialisation
. 2008-07-24 21:20:35.058 Detected network event
. 2008-07-24 21:20:35.277 Host key fingerprint is:
. 2008-07-24 21:20:35.277 ssh-rsa 2048 df:25:f5:44:22:e1:4e:a8:35:9e:d5:b5:32:7f:3d:6b
. 2008-07-24 21:20:35.277 Initialised AES-256 client->server encryption
. 2008-07-24 21:20:35.277 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-07-24 21:20:35.277 Initialised AES-256 server->client encryption
. 2008-07-24 21:20:35.277 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-07-24 21:20:35.277 Waiting for the server to continue with the initialisation
. 2008-07-24 21:20:35.277 Detected network event
! 2008-07-24 21:20:35.277 Using username "user".
. 2008-07-24 21:20:35.292 Detected network event
. 2008-07-24 21:20:35.292 Waiting for the server to continue with the initialisation
. 2008-07-24 21:20:35.292 Keyboard-interactive authentication refused
. 2008-07-24 21:20:35.292 Session password prompt (user@chain's password: )
. 2008-07-24 21:20:35.292 Using stored password.
. 2008-07-24 21:20:35.292 Sent password
. 2008-07-24 21:20:35.324 Detected network event
. 2008-07-24 21:20:35.324 Access granted
. 2008-07-24 21:20:35.324 Waiting for the server to continue with the initialisation
. 2008-07-24 21:20:35.339 Detected network event
. 2008-07-24 21:20:35.339 Opened channel for session
. 2008-07-24 21:20:35.339 Waiting for the server to continue with the initialisation
. 2008-07-24 21:20:35.355 Primary command failed; attempting fallback
. 2008-07-24 21:20:35.355 Waiting for the server to continue with the initialisation
. 2008-07-24 21:20:35.370 Detected network event
. 2008-07-24 21:20:35.370 Started a shell/command
. 2008-07-24 21:20:35.370 --------------------------------------------------------------------------
. 2008-07-24 21:20:35.370 Using SCP protocol.
. 2008-07-24 21:20:35.370 Doing startup conversation with host.
. 2008-07-24 21:20:35.370 Skipping host startup message (if any).
. 2008-07-24 21:20:35.370 Sent 36 bytes
. 2008-07-24 21:20:35.370 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.370 Sent 1 bytes
> 2008-07-24 21:20:35.370 echo "WinSCP: this is end-of-file:0"
. 2008-07-24 21:20:35.370 Waiting for another 1 bytes
. 2008-07-24 21:20:35.449 Detected network event
. 2008-07-24 21:20:35.449 Received 30 bytes (0)
. 2008-07-24 21:20:35.449 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.449 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.449 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:35.449 Detecting variable containing return code of last command.
. 2008-07-24 21:20:35.449 Trying "$status".
. 2008-07-24 21:20:35.449 Sent 53 bytes
. 2008-07-24 21:20:35.449 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.449 Sent 1 bytes
> 2008-07-24 21:20:35.449 echo "$status" ; echo "WinSCP: this is end-of-file:0"
. 2008-07-24 21:20:35.449 Waiting for another 1 bytes
. 2008-07-24 21:20:35.464 Detected network event
. 2008-07-24 21:20:35.464 Received 1 bytes (0)
. 2008-07-24 21:20:35.464 Read 1 bytes (0 pending)
. 2008-07-24 21:20:35.464 Waiting for another 1 bytes
. 2008-07-24 21:20:35.464 Received 30 bytes (0)
. 2008-07-24 21:20:35.464 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.464 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.464 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:35.464 Trying "$?".
. 2008-07-24 21:20:35.464 Sent 48 bytes
. 2008-07-24 21:20:35.464 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.464 Sent 1 bytes
> 2008-07-24 21:20:35.464 echo "$?" ; echo "WinSCP: this is end-of-file:0"
. 2008-07-24 21:20:35.495 Detected network event
. 2008-07-24 21:20:35.495 Received 2 bytes (0)
. 2008-07-24 21:20:35.495 Read 1 bytes (1 pending)
. 2008-07-24 21:20:35.495 Read 1 bytes (0 pending)
< 2008-07-24 21:20:35.495 0
. 2008-07-24 21:20:35.495 Waiting for another 1 bytes
. 2008-07-24 21:20:35.495 Received 30 bytes (0)
. 2008-07-24 21:20:35.495 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.495 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.495 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:35.495 Return code variable "$?" selected.
. 2008-07-24 21:20:35.495 Clearing all aliases.
. 2008-07-24 21:20:35.495 Sent 54 bytes
. 2008-07-24 21:20:35.495 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.511 Sent 1 bytes
. 2008-07-24 21:20:35.511 There are 0 bytes remaining in the send buffer
> 2008-07-24 21:20:35.511 unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.511 Waiting for another 1 bytes
. 2008-07-24 21:20:35.542 Detected network event
. 2008-07-24 21:20:35.542 Received 40 bytes (1)
! 2008-07-24 21:20:35.542 -bash: line 4: unalias: echo: not found
. 2008-07-24 21:20:35.542 Waiting for another 1 bytes
. 2008-07-24 21:20:35.542 Received 30 bytes (0)
. 2008-07-24 21:20:35.542 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.542 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.542 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.542 Sent 53 bytes
. 2008-07-24 21:20:35.542 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.542 Sent 1 bytes
> 2008-07-24 21:20:35.542 unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.589 Detected network event
. 2008-07-24 21:20:35.589 Received 39 bytes (1)
! 2008-07-24 21:20:35.589 -bash: line 5: unalias: pwd: not found
. 2008-07-24 21:20:35.589 Waiting for another 1 bytes
. 2008-07-24 21:20:35.589 Received 30 bytes (0)
. 2008-07-24 21:20:35.589 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.589 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.589 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.589 Sent 52 bytes
. 2008-07-24 21:20:35.589 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.589 Sent 1 bytes
> 2008-07-24 21:20:35.589 unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.620 Detected network event
. 2008-07-24 21:20:35.620 Received 38 bytes (1)
! 2008-07-24 21:20:35.620 -bash: line 6: unalias: cd: not found
. 2008-07-24 21:20:35.620 Waiting for another 1 bytes
. 2008-07-24 21:20:35.620 Received 30 bytes (0)
. 2008-07-24 21:20:35.620 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.620 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.620 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.620 Sent 52 bytes
. 2008-07-24 21:20:35.620 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.620 Sent 1 bytes
> 2008-07-24 21:20:35.620 unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.667 Detected network event
. 2008-07-24 21:20:35.667 Received 38 bytes (1)
! 2008-07-24 21:20:35.667 -bash: line 7: unalias: ls: not found
. 2008-07-24 21:20:35.667 Waiting for another 1 bytes
. 2008-07-24 21:20:35.667 Received 30 bytes (0)
. 2008-07-24 21:20:35.667 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.667 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.667 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.667 Sent 56 bytes
. 2008-07-24 21:20:35.667 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.667 Sent 1 bytes
> 2008-07-24 21:20:35.667 unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.699 Detected network event
. 2008-07-24 21:20:35.699 Received 42 bytes (1)
! 2008-07-24 21:20:35.699 -bash: line 8: unalias: groups: not found
. 2008-07-24 21:20:35.699 Waiting for another 1 bytes
. 2008-07-24 21:20:35.699 Received 30 bytes (0)
. 2008-07-24 21:20:35.699 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.699 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.699 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.699 Sent 53 bytes
. 2008-07-24 21:20:35.699 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.699 Sent 1 bytes
> 2008-07-24 21:20:35.699 unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.745 Detected network event
. 2008-07-24 21:20:35.745 Received 39 bytes (1)
! 2008-07-24 21:20:35.745 -bash: line 9: unalias: scp: not found
. 2008-07-24 21:20:35.745 Waiting for another 1 bytes
. 2008-07-24 21:20:35.745 Received 30 bytes (0)
. 2008-07-24 21:20:35.745 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.745 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.745 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.745 Sent 52 bytes
. 2008-07-24 21:20:35.745 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.745 Sent 1 bytes
> 2008-07-24 21:20:35.745 unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.777 Detected network event
. 2008-07-24 21:20:35.777 Received 39 bytes (1)
! 2008-07-24 21:20:35.777 -bash: line 10: unalias: rm: not found
. 2008-07-24 21:20:35.777 Waiting for another 1 bytes
. 2008-07-24 21:20:35.777 Received 30 bytes (0)
. 2008-07-24 21:20:35.777 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.777 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.777 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.777 Sent 52 bytes
. 2008-07-24 21:20:35.777 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.777 Sent 1 bytes
> 2008-07-24 21:20:35.777 unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.824 Detected network event
. 2008-07-24 21:20:35.824 Received 39 bytes (1)
! 2008-07-24 21:20:35.824 -bash: line 11: unalias: mv: not found
. 2008-07-24 21:20:35.824 Waiting for another 1 bytes
. 2008-07-24 21:20:35.824 Received 30 bytes (0)
. 2008-07-24 21:20:35.824 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.824 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.824 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.824 Sent 55 bytes
. 2008-07-24 21:20:35.824 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.824 Sent 1 bytes
> 2008-07-24 21:20:35.824 unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.855 Detected network event
. 2008-07-24 21:20:35.855 Received 42 bytes (1)
! 2008-07-24 21:20:35.855 -bash: line 12: unalias: mkdir: not found
. 2008-07-24 21:20:35.855 Waiting for another 1 bytes
. 2008-07-24 21:20:35.870 Detected network event
. 2008-07-24 21:20:35.870 Received 30 bytes (0)
. 2008-07-24 21:20:35.870 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.870 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.870 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.870 Sent 55 bytes
. 2008-07-24 21:20:35.870 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.870 Sent 1 bytes
> 2008-07-24 21:20:35.870 unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.870 Waiting for another 1 bytes
. 2008-07-24 21:20:35.902 Detected network event
. 2008-07-24 21:20:35.902 Received 42 bytes (1)
! 2008-07-24 21:20:35.902 -bash: line 13: unalias: chmod: not found
. 2008-07-24 21:20:35.902 Waiting for another 1 bytes
. 2008-07-24 21:20:35.902 Received 30 bytes (0)
. 2008-07-24 21:20:35.902 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.902 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.902 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.902 Sent 55 bytes
. 2008-07-24 21:20:35.902 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.902 Sent 1 bytes
> 2008-07-24 21:20:35.902 unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.949 Detected network event
. 2008-07-24 21:20:35.949 Received 42 bytes (1)
! 2008-07-24 21:20:35.949 -bash: line 14: unalias: chgrp: not found
. 2008-07-24 21:20:35.949 Waiting for another 1 bytes
. 2008-07-24 21:20:35.949 Received 30 bytes (0)
. 2008-07-24 21:20:35.949 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.949 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.949 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.949 Sent 55 bytes
. 2008-07-24 21:20:35.949 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.949 Sent 1 bytes
> 2008-07-24 21:20:35.949 unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:35.980 Detected network event
. 2008-07-24 21:20:35.980 Received 42 bytes (1)
! 2008-07-24 21:20:35.980 -bash: line 15: unalias: chown: not found
. 2008-07-24 21:20:35.980 Waiting for another 1 bytes
. 2008-07-24 21:20:35.980 Received 30 bytes (0)
. 2008-07-24 21:20:35.980 Read 1 bytes (29 pending)
. 2008-07-24 21:20:35.980 Read 29 bytes (0 pending)
< 2008-07-24 21:20:35.980 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:35.980 Sent 55 bytes
. 2008-07-24 21:20:35.980 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:35.980 Sent 1 bytes
> 2008-07-24 21:20:35.980 unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.027 Detected network event
. 2008-07-24 21:20:36.027 Received 42 bytes (1)
! 2008-07-24 21:20:36.027 -bash: line 16: unalias: unset: not found
. 2008-07-24 21:20:36.027 Waiting for another 1 bytes
. 2008-07-24 21:20:36.027 Received 30 bytes (0)
. 2008-07-24 21:20:36.027 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.027 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.027 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:36.027 Sent 57 bytes
. 2008-07-24 21:20:36.027 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.027 Sent 1 bytes
> 2008-07-24 21:20:36.027 unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.058 Detected network event
. 2008-07-24 21:20:36.058 Received 44 bytes (1)
! 2008-07-24 21:20:36.058 -bash: line 17: unalias: unalias: not found
. 2008-07-24 21:20:36.058 Waiting for another 1 bytes
. 2008-07-24 21:20:36.058 Received 30 bytes (0)
. 2008-07-24 21:20:36.058 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.058 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.058 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:36.058 Sent 55 bytes
. 2008-07-24 21:20:36.058 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.058 Sent 1 bytes
> 2008-07-24 21:20:36.058 unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.105 Detected network event
. 2008-07-24 21:20:36.105 Received 42 bytes (1)
! 2008-07-24 21:20:36.105 -bash: line 18: unalias: alias: not found
. 2008-07-24 21:20:36.105 Waiting for another 1 bytes
. 2008-07-24 21:20:36.105 Received 30 bytes (0)
. 2008-07-24 21:20:36.105 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.105 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.105 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:36.105 Sent 52 bytes
. 2008-07-24 21:20:36.105 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.105 Sent 1 bytes
> 2008-07-24 21:20:36.105 unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.136 Detected network event
. 2008-07-24 21:20:36.136 Received 39 bytes (1)
! 2008-07-24 21:20:36.136 -bash: line 19: unalias: ln: not found
. 2008-07-24 21:20:36.136 Waiting for another 1 bytes
. 2008-07-24 21:20:36.136 Received 30 bytes (0)
. 2008-07-24 21:20:36.136 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.136 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.136 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:36.136 Sent 52 bytes
. 2008-07-24 21:20:36.136 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.136 Sent 1 bytes
> 2008-07-24 21:20:36.136 unalias "cp" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.183 Detected network event
. 2008-07-24 21:20:36.183 Received 39 bytes (1)
! 2008-07-24 21:20:36.183 -bash: line 20: unalias: cp: not found
. 2008-07-24 21:20:36.183 Waiting for another 1 bytes
. 2008-07-24 21:20:36.183 Received 30 bytes (0)
. 2008-07-24 21:20:36.183 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.183 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.183 WinSCP: this is end-of-file:1
. 2008-07-24 21:20:36.183 Clearing national user variables.
. 2008-07-24 21:20:36.183 Sent 52 bytes
. 2008-07-24 21:20:36.183 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.183 Sent 1 bytes
> 2008-07-24 21:20:36.183 unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.230 Detected network event
. 2008-07-24 21:20:36.230 Received 30 bytes (0)
. 2008-07-24 21:20:36.230 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.230 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.230 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.230 Sent 56 bytes
. 2008-07-24 21:20:36.230 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.230 Sent 1 bytes
> 2008-07-24 21:20:36.230 unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.230 Waiting for another 1 bytes
. 2008-07-24 21:20:36.261 Detected network event
. 2008-07-24 21:20:36.261 Received 30 bytes (0)
. 2008-07-24 21:20:36.261 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.261 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.261 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.261 Sent 56 bytes
. 2008-07-24 21:20:36.261 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.261 Sent 1 bytes
> 2008-07-24 21:20:36.261 unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.261 Waiting for another 1 bytes
. 2008-07-24 21:20:36.308 Detected network event
. 2008-07-24 21:20:36.308 Received 30 bytes (0)
. 2008-07-24 21:20:36.308 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.308 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.308 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.308 Sent 58 bytes
. 2008-07-24 21:20:36.308 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.308 Sent 1 bytes
> 2008-07-24 21:20:36.308 unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.308 Waiting for another 1 bytes
. 2008-07-24 21:20:36.339 Detected network event
. 2008-07-24 21:20:36.339 Received 30 bytes (0)
. 2008-07-24 21:20:36.339 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.339 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.339 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.339 Sent 59 bytes
. 2008-07-24 21:20:36.339 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.339 Sent 1 bytes
> 2008-07-24 21:20:36.339 unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.339 Waiting for another 1 bytes
. 2008-07-24 21:20:36.386 Detected network event
. 2008-07-24 21:20:36.386 Received 30 bytes (0)
. 2008-07-24 21:20:36.386 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.386 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.386 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.386 Sent 58 bytes
. 2008-07-24 21:20:36.386 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.386 Sent 1 bytes
> 2008-07-24 21:20:36.386 unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.386 Waiting for another 1 bytes
. 2008-07-24 21:20:36.417 Detected network event
. 2008-07-24 21:20:36.417 Received 30 bytes (0)
. 2008-07-24 21:20:36.417 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.417 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.417 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.417 Sent 55 bytes
. 2008-07-24 21:20:36.417 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.417 Sent 1 bytes
> 2008-07-24 21:20:36.417 unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.417 Waiting for another 1 bytes
. 2008-07-24 21:20:36.464 Detected network event
. 2008-07-24 21:20:36.464 Received 30 bytes (0)
. 2008-07-24 21:20:36.464 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.464 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.464 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.464 Sent 59 bytes
. 2008-07-24 21:20:36.464 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.464 Sent 1 bytes
> 2008-07-24 21:20:36.464 unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.464 Waiting for another 1 bytes
. 2008-07-24 21:20:36.495 Detected network event
. 2008-07-24 21:20:36.495 Received 30 bytes (0)
. 2008-07-24 21:20:36.495 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.495 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.495 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.495 Sent 54 bytes
. 2008-07-24 21:20:36.495 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.495 Sent 1 bytes
> 2008-07-24 21:20:36.495 unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.495 Waiting for another 1 bytes
. 2008-07-24 21:20:36.542 Detected network event
. 2008-07-24 21:20:36.542 Received 30 bytes (0)
. 2008-07-24 21:20:36.542 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.542 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.542 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.542 Sent 60 bytes
. 2008-07-24 21:20:36.542 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.542 Sent 1 bytes
> 2008-07-24 21:20:36.542 unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.542 Waiting for another 1 bytes
. 2008-07-24 21:20:36.589 Detected network event
. 2008-07-24 21:20:36.589 Received 30 bytes (0)
. 2008-07-24 21:20:36.589 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.589 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.589 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.589 Looking up groups and users.
. 2008-07-24 21:20:36.589 Sent 46 bytes
. 2008-07-24 21:20:36.589 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.589 Sent 1 bytes
> 2008-07-24 21:20:36.589 groups ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.589 Waiting for another 1 bytes
. 2008-07-24 21:20:36.636 Detected network event
. 2008-07-24 21:20:36.636 Received 5 bytes (0)
. 2008-07-24 21:20:36.636 Read 1 bytes (4 pending)
. 2008-07-24 21:20:36.636 Read 4 bytes (0 pending)
< 2008-07-24 21:20:36.636 user
. 2008-07-24 21:20:36.636 Waiting for another 1 bytes
. 2008-07-24 21:20:36.652 Detected network event
. 2008-07-24 21:20:36.652 Received 30 bytes (0)
. 2008-07-24 21:20:36.652 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.652 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.652 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.652 Following groups found:
. 2008-07-24 21:20:36.652 user
. 2008-07-24 21:20:36.652 No users found.
. 2008-07-24 21:20:36.652 Getting current directory name.
. 2008-07-24 21:20:36.652 Sent 43 bytes
. 2008-07-24 21:20:36.652 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.652 Sent 1 bytes
> 2008-07-24 21:20:36.652 pwd ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.652 Waiting for another 1 bytes
. 2008-07-24 21:20:36.683 Detected network event
. 2008-07-24 21:20:36.683 Received 41 bytes (0)
. 2008-07-24 21:20:36.683 Read 1 bytes (40 pending)
. 2008-07-24 21:20:36.683 Read 10 bytes (30 pending)
< 2008-07-24 21:20:36.683 /home/user
. 2008-07-24 21:20:36.683 Read 30 bytes (0 pending)
< 2008-07-24 21:20:36.683 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.683 Listing current directory.
. 2008-07-24 21:20:36.683 Sent 58 bytes
. 2008-07-24 21:20:36.683 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:20:36.683 Sent 1 bytes
> 2008-07-24 21:20:36.683 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:20:36.683 Waiting for another 1 bytes
. 2008-07-24 21:20:36.761 Detected network event
. 2008-07-24 21:20:36.761 Received 296 bytes (0)
. 2008-07-24 21:20:36.761 Read 1 bytes (295 pending)
. 2008-07-24 21:20:36.761 Read 8 bytes (287 pending)
< 2008-07-24 21:20:36.761 total 20
. 2008-07-24 21:20:36.761 Read 66 bytes (221 pending)
< 2008-07-24 21:20:36.761 drwxr-xr-x 2 user user 4096 2008-07-24 21:10:53.000000000 +0300 .
. 2008-07-24 21:20:36.761 Read 67 bytes (154 pending)
< 2008-07-24 21:20:36.761 drwxr-xr-x 7 user user 4096 2008-06-07 00:35:43.000000000 +0300 ..
. 2008-07-24 21:20:36.761 Read 78 bytes (76 pending)
< 2008-07-24 21:20:36.761 -rw------- 1 user user 142 2008-07-22 15:41:53.000000000 +0300 .bash_history
. 2008-07-24 21:20:36.761 Read 76 bytes (0 pending)
< 2008-07-24 21:20:36.761 -r--r--r-- 1 user user 8187 2008-06-07 00:36:28.000000000 +0300 .fishsrv.pl
. 2008-07-24 21:20:36.761 Waiting for another 1 bytes
. 2008-07-24 21:20:36.761 Received 30 bytes (0)
. 2008-07-24 21:20:36.761 Read 1 bytes (29 pending)
. 2008-07-24 21:20:36.761 Read 29 bytes (0 pending)
< 2008-07-24 21:20:36.761 WinSCP: this is end-of-file:0
. 2008-07-24 21:20:36.761 Directory listing with --full-time succeed, next time all errors during directory listing will be displayed immediatelly.
. 2008-07-24 21:20:36.761 Startup conversation with host finished.
. 2008-07-24 21:20:37.417 Session upkeep
. 2008-07-24 21:20:37.917 Session upkeep
. 2008-07-24 21:20:38.417 Session upkeep
. 2008-07-24 21:20:38.933 Session upkeep
. 2008-07-24 21:20:39.449 Session upkeep
. 2008-07-24 21:20:39.949 Session upkeep
. 2008-07-24 21:20:40.449 Session upkeep
. 2008-07-24 21:20:40.949 Session upkeep
. 2008-07-24 21:20:41.449 Session upkeep
. 2008-07-24 21:20:41.949 Session upkeep
. 2008-07-24 21:20:42.449 Session upkeep
. 2008-07-24 21:20:42.949 Session upkeep
. 2008-07-24 21:20:43.449 Session upkeep
. 2008-07-24 21:20:43.949 Session upkeep
. 2008-07-24 21:20:44.449 Session upkeep
. 2008-07-24 21:20:44.949 Session upkeep
. 2008-07-24 21:20:45.449 Session upkeep
. 2008-07-24 21:20:45.949 Session upkeep
. 2008-07-24 21:20:46.449 Session upkeep
. 2008-07-24 21:20:46.949 Session upkeep
. 2008-07-24 21:20:47.449 Session upkeep
. 2008-07-24 21:20:47.949 Session upkeep
. 2008-07-24 21:20:48.449 Session upkeep
. 2008-07-24 21:20:48.949 Session upkeep
. 2008-07-24 21:20:49.449 Session upkeep
. 2008-07-24 21:20:49.949 Session upkeep
. 2008-07-24 21:20:50.449 Session upkeep
. 2008-07-24 21:20:50.949 Session upkeep
. 2008-07-24 21:20:51.449 Session upkeep
. 2008-07-24 21:20:51.949 Session upkeep
. 2008-07-24 21:20:52.449 Session upkeep
. 2008-07-24 21:20:52.949 Session upkeep
. 2008-07-24 21:20:53.449 Session upkeep
. 2008-07-24 21:20:53.949 Session upkeep
. 2008-07-24 21:20:54.449 Session upkeep
. 2008-07-24 21:20:54.949 Session upkeep
. 2008-07-24 21:20:55.449 Session upkeep
. 2008-07-24 21:20:55.949 Session upkeep
. 2008-07-24 21:20:56.449 Session upkeep
. 2008-07-24 21:20:56.949 Session upkeep
. 2008-07-24 21:20:57.449 Session upkeep
. 2008-07-24 21:20:57.949 Session upkeep
. 2008-07-24 21:20:58.449 Session upkeep
. 2008-07-24 21:20:58.949 Session upkeep
. 2008-07-24 21:20:59.449 Session upkeep
. 2008-07-24 21:20:59.949 Session upkeep
. 2008-07-24 21:21:00.449 Session upkeep
. 2008-07-24 21:21:00.949 Session upkeep
. 2008-07-24 21:21:01.449 Session upkeep
. 2008-07-24 21:21:01.949 Session upkeep
. 2008-07-24 21:21:02.449 Session upkeep
. 2008-07-24 21:21:02.949 Session upkeep
. 2008-07-24 21:21:03.386 Cached directory change via "/www" to "/www".
. 2008-07-24 21:21:03.386 Getting current directory name.
. 2008-07-24 21:21:03.386 Listing current directory.
. 2008-07-24 21:21:03.386 Locating to cached directory "/www".
. 2008-07-24 21:21:03.386 Sent 49 bytes
. 2008-07-24 21:21:03.386 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:21:03.386 Sent 1 bytes
> 2008-07-24 21:21:03.386 cd "/www" ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:21:03.386 Waiting for another 1 bytes
. 2008-07-24 21:21:03.417 Detected network event
. 2008-07-24 21:21:03.417 Received 30 bytes (0)
. 2008-07-24 21:21:03.417 Read 1 bytes (29 pending)
. 2008-07-24 21:21:03.417 Read 29 bytes (0 pending)
< 2008-07-24 21:21:03.417 WinSCP: this is end-of-file:0
. 2008-07-24 21:21:03.417 Sent 58 bytes
. 2008-07-24 21:21:03.417 There are 0 bytes remaining in the send buffer
. 2008-07-24 21:21:03.417 Sent 1 bytes
> 2008-07-24 21:21:03.417 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
. 2008-07-24 21:21:03.417 Waiting for another 1 bytes
. 2008-07-24 21:21:03.480 Detected network event
. 2008-07-24 21:21:03.480 Received 435 bytes (0)
. 2008-07-24 21:21:03.480 Read 1 bytes (434 pending)
. 2008-07-24 21:21:03.480 Read 8 bytes (426 pending)
< 2008-07-24 21:21:03.480 total 24
. 2008-07-24 21:21:03.480 Read 67 bytes (359 pending)
< 2008-07-24 21:21:03.480 drwxr-xr-x 3 user user 4096 2008-07-24 17:21:24.000000000 +0300 .
. 2008-07-24 21:21:03.480 Read 68 bytes (291 pending)
< 2008-07-24 21:21:03.480 drwxr-xr-x 18 user user 4096 2008-07-21 17:41:54.000000000 +0300 ..
. 2008-07-24 21:21:03.480 Read 76 bytes (215 pending)
< 2008-07-24 21:21:03.480 -rw-r--r-- 1 user user 762 2008-07-24 20:08:01.000000000 +0300 index.html
. 2008-07-24 21:21:03.480 Read 74 bytes (141 pending)
< 2008-07-24 21:21:03.480 -rw-r--r-- 1 user user 327 2008-07-24 14:38:04.000000000 +0300 last.css
. 2008-07-24 21:21:03.480 Read 74 bytes (67 pending)
< 2008-07-24 21:21:03.480 -rw-r--r-- 1 user user 2416 2008-07-24 14:34:45.000000000 +0300 pika.gif
. 2008-07-24 21:21:03.480 Read 67 bytes (0 pending)
< 2008-07-24 21:21:03.480 drwxr-xr-x 2 user user 4096 2008-07-24 17:21:24.000000000 +0300 ~
. 2008-07-24 21:21:03.480 Waiting for another 1 bytes
. 2008-07-24 21:21:03.495 Detected network event
. 2008-07-24 21:21:03.495 Received 30 bytes (0)
. 2008-07-24 21:21:03.495 Read 1 bytes (29 pending)
. 2008-07-24 21:21:03.495 Read 29 bytes (0 pending)
< 2008-07-24 21:21:03.495 WinSCP: this is end-of-file:0
. 2008-07-24 21:21:03.527 Session upkeep
. 2008-07-24 21:21:03.949 Session upkeep
. 2008-07-24 21:21:04.449 Session upkeep
. 2008-07-24 21:21:04.949 Session upkeep
. 2008-07-24 21:21:05.386 Cached directory change via "~" to "/home/user".
. 2008-07-24 21:21:05.386 Getting current directory name.
. 2008-07-24 21:21:05.402 Directory content loaded from cache.
. 2008-07-24 21:21:05.449 Session upkeep
. 2008-07-24 21:21:05.949 Session upkeep
. 2008-07-24 21:21:06.449 Session upkeep
. 2008-07-24 21:21:06.949 Session upkeep
. 2008-07-24 21:21:07.449 Session upkeep
. 2008-07-24 21:21:07.574 Closing connection.
[/code]
It looks like you previously did "cd ~" manually to get to the home directory. WinSCP remembers that in cache, so now, it does that all the time without asking the server. Clearing the cache should help.
