Topic "Winscp scripting language"
ranajit.bhol
I am trying to use Winscp in Test automation and is trying to get it recognized by QTP. Could you please let me know the platform(e.g. .NET) on which WinScp is built so that i can use the required add-ins?
Regards,
Ranajit
There's no platform. WinSCP is self contained application.
ranajit.bhol
Thanks for your response.
What about the GUI components or the windows interface? How is that developed, it has to be some windows framework. Please correct me if i am wrong.
It uses standard WinAPI.
Regards,
Ranajit
Ranajit!
Have you been able to find a solution on this? If yes, Could you please help?
Thanks Much,
Swathi
This has been answered already. What more do you want to know?
Let me explain.... for QTP to be able to recognize the objects on Winscp we need to have the addin associated with the technology that Winscp has been developed on. only then it can recognize the objects. SO if this is a developed on Java we will need a java addin. So I want to know what technology it has been developed on. I did not understand what exactly you meant when you said "it is a self contained application" can you please explain??
Thanks Much,
Swathi
I do not know what QTP is. So I do not know what kind of objects do you mean. But I doubt that it will work. There are no externally available objects (like Java, COM or .NET) in WinSCP.
QTP --> Quick Test Professional.
It is a product from HP.
For example, a web page will have lot elements like tables, text boxes, links which are all available in the page. These elements are so called Objects.
Similarly, when we are taking about this tool Win SCP, we want to know what is the hierarchy or the language that you are used to develop this tool?
"WinSCP is self contained application" what I understand from this quote is that Win SCP is developed using an unique technology which you have developed to design this tool.
Please correct me if I am wrong.
Thanks in Advance,
Lingesh
WinSCP is developed in Borland C++ Builder.
Hi Ranjit,
Did you able to find the solution for automate winsap using QTP..???
