Topic "Pipe is readable only when WinSCP has finished"
Mercury
I use WinSCP as a part of a larger program. It calls WinSCP.com in such a manner:
    SECURITY_ATTRIBUTES sa;
      // Security attributes
    sa.nLength = sizeof(SECURITY_ATTRIBUTES);
    sa.lpSecurityDescriptor = NULL;
    sa.bInheritHandle = true;
    SECURITY_DESCRIPTOR sd;
    if (IsWinNT())
        InitializeSecurityDescriptor(&sd,SECURITY_DESCRIPTOR_REVISION);
        SetSecurityDescriptorDacl(&sd, true, NULL, false);
        sa.lpSecurityDescriptor = &sd;
    // Stdout/stderr pipe
    // read = outside, write = inside
    CreatePipe(&hStdOutOutside, &hStdOutInside, &sa, 1024*10);
    // Stdin pipe
    // read = inside, write = outside
    CreatePipe(&hStdInInside, &hStdInOutside, &sa, 1024*10);
    // Startup info
    STARTUPINFO si;
    ZeroMemory(&si, sizeof(si));
    si.cb = sizeof(si);
    si.dwFlags |= STARTF_USESTDHANDLES | STARTF_USESHOWWINDOW;
    si.hStdOutput = hStdOutInside;
    si.hStdError = hStdOutInside;
    si.hStdInput = hStdInInside;
    si.wShowWindow = SW_HIDE;
    // cmdline
    xchar* cmdl = new xchar[1024]; //xstrlen(aFname)+xstrlen(aCmdLine) + 10];
    xsprintf(cmdl, "\"%s\" %s", aFname, aCmdLine);
    // process info
    PROCESS_INFORMATION pi;
    CreateProcessA(
            NULL,           // lpApplicationName
            cmdl,           // lpCommandLine
            NULL,           // lpProcessAttributes
            NULL,           // lpThreadAttributes
            true,           // bInheritHandles
            0,              // dwCreationFlags
            NULL,           // lpEnvironment
            NULL,           // lpCurrentDirectory
            &si,            // lpStartupInfo
            &pi );          // lpProcessInformation
To read the output, I use such an instruction...
    unsigned long nbr, nbr2, nba, nbl;
    PeekNamedPipe(
            hStdOutOutside, aBuf, aLength,
            &nbr, &nba, &nbl);
    if (nbr>0)
        ReadFile(
            hStdOutOutside, aBuf, nbr, &nbr2, NULL);
        return nbr2;
    } else return 0;
The output appears on my end of pipe only after WinSCP has finished => the program cannot interact with WinSCP (it can only feed predefined scripts). Other programs (for example, cmd.exe) seem to be OK.
What to do? Maybe, wrong code?
What do you do in your script?
Mercury
I don't use script. I try to pass these commands using stdin:
open someconnection
close
(no real interaction by now, but there'll be.)
Mercury
The same happens to files. I write
WinSCP.com /script=somelongscript.sc >file.txt
F3 - the file is empty
F3 - it's empty again!!
F3 - empty!!!
After some tries, all the information appears in file.txt in one piece.
Thanks for your post. This issue has been added to tracker.
