Topic "Connecting server"
nash
I tried to connect one SFTP server through this application.
I am getting following error..
Host has not answered for more than 15 seconds.Still waiting.
Warning: Aborting this operation will close connection!.
I can access this server through another application[File Zilla ]
Through file zilla i cant make script.so i need to access through this application.
Can anyone help me regarding this...[/quote][/url]
Are you sure you are using the same protocol in WinSCP and FileZilla? Note that WinSCP uses SFTP by default, while FileZilla uses FTP.
nash
I tried to use FTP protocol.
Now i am getting another error..
Error listing directory'/'.
Can u help me about this.
thanks
Please press More and post a full error message. Or use Ctrl+C.
nash
i click more and got this error message
Error
Error listing directory '/'.
Illegal PORT command.
OK Help
Try to connect using passive mode or post a log file.
jonathanharriot@...
I stumbled upon this via a search engine and the passive mode helped out, thanks!
Chandan
Hi Im facing an issue while trying to connect to ftp. my subject shows that message..
sending you the logfile too.... please help
Chandan
011-01-28 04:05:05.641 Using FTP protocol.
. 2011-01-28 04:05:05.641 Doing startup conversation with host.
> 2011-01-28 04:05:05.641 PWD
< 2011-01-28 04:05:05.968 257 "/" is the current directory
. 2011-01-28 04:05:05.968 Getting current directory name.
. 2011-01-28 04:05:05.968 Retrieving directory listing...
> 2011-01-28 04:05:05.983 TYPE A
< 2011-01-28 04:05:06.279 200 Type set to A
> 2011-01-28 04:05:06.279 PORT 172,31,9,29,18,187
< 2011-01-28 04:05:06.575 500 Illegal PORT command
. 2011-01-28 04:05:06.575 Could not retrieve directory listing
. 2011-01-28 04:05:06.590 Retrieving directory listing...
> 2011-01-28 04:05:06.590 TYPE A
< 2011-01-28 04:05:06.902 200 Type set to A
> 2011-01-28 04:05:06.902 PORT 172,31,9,29,18,189
< 2011-01-28 04:05:07.213 500 Illegal PORT command
. 2011-01-28 04:05:07.213 Could not retrieve directory listing
* 2011-01-28 04:05:07.213 (ECommand) Error listing directory '/'.
* 2011-01-28 04:05:07.213 Could not retrieve directory listing
* 2011-01-28 04:05:07.213 Illegal PORT command
please help
Try switching to passive mode.
Estava com o mesmo problema e o modo passivo resolveu. Muito Obrigado!
Daniel Cassimiro
