Topic "keepuptodate and preserve timestamp"
Parke
Hello!
I am using WinSCP Version 4.1.6 (Build 412). I am using console and scripting to transfer via SCP using a keepuptodate function.
Initially, I was receiving the 'set permissions: not owner'. I wrote -nopermissions in the keepuptodate script to solve this. Then, I received the 'set times: not owner' prompt which I turned off 'Preserve timestamp'. (I exported the .ini file and am using /ini=c:\sysmod\winscp\winscp.ini to reference the config file.) I am still receiving the 'set times: now owner' prompt.
I have attempted option confirm off in the script file, but I'm not sure that applies to keepuptodate.
Is there any other way to turn off preserve timestamp? Also, if I do successfully remove this functionality wouldn't that prevent keepuptodate from checking if this file was actually updated?
Thank so much Martin!
~Parke~
Correct. It makes no sense to turn off preserve timestamps with keepuptodate.
