Topic "Cannot login to one site since upgrading to winscp 4.1.6"
pfcomptech
I have recently upgraded from WinSCP v3.8.2 (build 330) to v4.1.6 (build 412). I now find that I cannot connect to one site which I could with v3.8.2. I have not changed any settings since the v3.8.2 version. The error displayed is "Server unexpectedly closed network connection". I have enabled Debug2 level logging but nothing is entered in the log for the session at all.
When I try a connection via telnet hostname 22, I get the banner SSH-2.0-SSHD.
Any assistance in trying to troubleshoot this connectivity problem would be greatly appreciated.
Regards
Paul
Can you try to login with PuTTY 0.60?
Martin
I have checked trying to connect using Putty 0.60 and I receive the same error.
Regards
Paul
OK. So then please check server's log file to see whether you find anything useful there.
[fcomptech
Unfortunately I do not have access to the server so I cannot obtain any logs which might help explain the failed connection.
Paul
So ask your server administrator.
