Topic "Unzip with WinSCP"
Gupi
Is it possible to unzip a file using WinSCP? How can I do it?
Thanks & Regards,
Gustavo
What file? Remote or local? What do you want to do with the unzipped contents?
Thanks & Regards,
Gustavo
I want to unzip a local csv file.
With the unzip contents I want to load a table.
The problem is that I cannot load the table without unzipping the file
Is it possible to unzip the file with WinSCP?
Thanks for the support,
Gustavo
Gupi
I forgot to mentionThe extension of the zip file is .zip.
Regards,
Gustavo
WinSCP cannot unzip local file by itself. You have to have external application installed for that. Then you may be able to call it from local file context menu within WinSCP.
Gupi
And if it is a remote file, winscp is able to unzip it?
Thanks & Regards,
Gustavo
Again not directly. but it can use remote application to unzip it without downloading it to local directory.
Gupi
Martin,
thank you for your support.
Regards,
Gustavo
Guy3
How can I unzip a file in a server using WinSCP?
The path is "/home/appladmin/APEX/apex_3.2.zip"
When I double click the file, it opens winzip application and saves unzipped files in temporary directory which seems to be in my local drive.
When I tried to extract those files to a specific folder in the server I see only the folders in my local drive.
Would appreciate step by step instruction.
Guy
You need to use remote command, such as custom command. See some examples too.
djtups
I need to unzipo a password protected file... can be this by WinSCP directly on server ? how ?
As long as you unzip tool allows passing password on command-line.
